Traction Battery Cooler
Discussion in 'Prime Main Forum (2017-2022)' started by Sgt Bill, Sep 30, 2021.
  1. Sgt Bill
    Sgt Bill Member
    42
    35
    St.Louis Mo.
    Hi everyone ;
    We have had our 2021 PP about six months now and when I turn the vehicle off a display comes on the screen titled Traction Battery Cooler and ask if the ac should be turned on yes or no when charging.I am somewhat confused, should I select yes or no.Past chats have also been confusing.My concern is that if I choose no then when the car is hot the battery will not charge.Is the answer to select yes and the cooler will come on,or no.
  2. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    After reading the manual I interpret it to say if the battery might be hot when charging starts turn the A/C on to cool the battery during the charge. If you know the battery will be cool because, say, you'll charge overnight it would be safe to reply no. If you'll be charging immediately and it's hot outside or will be hot outside when charging begins I would reply yes. If you're concerned the car might not charge due to the possibility of it being hot then the safe answer of course is yes.
    #2 schja01, Sep 30, 2021
  3. CharlesH
    2,798
    1,166
    Roseville, CA
    I think the consensus about that option is that the folks who put it in partied too much the night before. It just doesn't make any sense. If the battery is hot when you turn off the car, it asks if you want the battery cooler to come on the next time it is charged. Which may well be your next scheduled charging session at 5am. And the option defaults to NO after a few seconds, with no way to change the default. Useless.
  4. Sgt Bill
    Sgt Bill Member
    42
    35
    St.Louis Mo.
    That’s why it is confusing to me.I have just been leaving it on no and it charges ok.Lately the past couple three days the charging has stopped after an hour or so.(No the weather has not been that warm.)The charging starts up after I restart it and it charges completely.Does anyone see any problem with putting on yes and let it do it’s thing.
  5. Ovation
    Ovation Active Member
    156
    130
    Quebec
    I always respond yes when I see it. Figure it can’t hurt anything.
    DOHCtor likes this.
  6. KYBlue
    KYBlue Active Member
    227
    112
    I wish you could default it to yes.... It doesn't always come up, and if any passengers open the door before you respond it defaults to no....
  7. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    Yeah it is very strange.
    I think (from other previous posts/threads here) the only considerable reason why the option is there is
    First, only when outdoor temp is above a certain amount 75f? or somewhere...(maybe even battery temp)
    and Second, if you push yes and then plug in, it will take a good 10-20 min to cool (and delaying start of charge)
    So that is major if you are waiting on that charge, or esp if you are paying for that charge.
    Obviously, if you are scheduling the charge or not charging atm, the battery is cooling on its on time.
    I imagine the Prime is programmed to not have the battery overheat. (shutdown, run on ICE only, etc)
    Salamander_King likes this.
  8. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    In our climate, I rarely see the Traction Battery Cooler pop-up. My understanding is that it is there to protect the battery if the temperature of the battery is high and you try to charge it while it is still hot. But since the default is "NO" and it is often very hard to answer "YES" on time, my feeling is that the car will not allow the charge to start until the battery temp is cooler even if you do not use the Battery Cooler function. That of course makes the waiting time before the charging starts to be longer. I have never tested this hypothesis, as I almost never see the traction battery getting that hot in my climate.
    If your answer to the Battery Cooler pop-up question is always NO as default or if you always ignore it, then you can turn off the pop-up from the meter customization shown below. I have all of the pop-ups turned off except the traction battery cooler, but I still hardly ever see the Battery Cooler pop-up in my climate.
    dig4dirt likes this.
  9. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    As I understand it, the cooler won't work if you instant charge, which is weird. I would think that's when you want the cooler to operate. I think it will charge at a lower rate if the battery is too hot.
    iPhone ? Pro
  10. Salamander_King
    11,024
    8,978
    New England
    Really? I thought the cooler function is more for the "Charge Now" situation. If you are scheduling the next charge, then the traction battery will be cooled by itself. The manual says nothing bout not functioning with the "Charge Now" charging.
    #10 Salamander_King, Oct 1, 2021
  11. Ovation
    156
    130
    Quebec
    It does function with Charge Now. I’ve witnessed it several times this summer. I once parked somewhere and planned to stay for awhile and use the public L2 charger. I’d said yes to the cooler option. Unexpectedly, I had to leave early (after 30 mins—very hot day) and I discovered two things—1) my car was nice and cool inside, and 2) my battery showed a 2% SOC after 30 mins.
    DOHCtor and Salamander_King like this.
  12. vvillovv
    vvillovv Senior Member
    4,337
    1,518
    NY
    I see the message on the MID about 5 times every summer. I've missed switching the screen to Yes several times each year. My thoughts are that if the battery and cabin are hot enough to have the message displayed I want the Prime to use the A/C. If I miss switching the message to yes, I'll open the windows and sometimes wait till the outside temps go down before I'll start the charge.
    Not asked about so I'll be brief, there is also a traction pack heater option that may be switch on/off in the vehicle settings on the MID. It may be in the off position by default. I switch it off in the summer and on in the winter, if for no other reason than to remember where the settings are.
  13. MikeDee
    1,581
    597
    There is a 2017 thread called "Traction battery cooler." The owners manual states that the cooler does not operate in the Charge now mode. I tried it and mine doesn't, as documented in that thread. I remember something about if there is no scheduled charge programmed, it will work. It's also possible that Toyota changed the function on the newer models. Mine is a 2017.
    iPhone ? Pro
  14. Sgt Bill
    Sgt Bill Member
    42
    35
    St.Louis Mo.
    Thanks everyone for the input .After.all the responses and info I think I understand the pop up.If the car is hot hit yes if not leave it on no.
    Thanks .
  15. DOHCtor
    DOHCtor Active Member
    170
    103
    Levis (Quebec city's south shore)
    2024 Prius Prime
    SE
    If it asks and you have your sweet time, say yes. Charging a battery that is cool will increase it's life. If you're in a hurry however, say no as it takes time to cool it and it won't charge until it's cool. Battery heater function will just work near/under freeze point so it makes no sense to put it to off.
    vvillovv likes this.
