Traction battery died. Red Triangle P0A80 code
Discussion in 'Gen 2 Prius Main Forum' started by SuperDave, Mar 24, 2014.
  1. SuperDave
    SuperDave Member
    104
    22
    Anderson, In.
    I have been searching the forum for ideas, although helpful many threads appear to be older addressing this issue.
    I am looking for low cost options to replace my battery. What I would like know is, who have people gotten replacement batteries from and cost? I live in Indiana. I have the ability to replace it out myself if needed.
    Any suggestions?? Thanks
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ...not the expert, but the lower cost options start with Dorman Hybrid battery, previously known as ReInvolt, then you can talk getting one from a wreck, or buy some cells on EBay and try to rebuilt it (takes time).
  3. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
  4. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Go with the folks nh70 recommended. They are well known, and in your area.
  5. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Since you are in Indiana, Steve at Prius hybrids sales and service Scottsburg Indiana is a reliable, low-cost, independent Prius rebuilder in southern Indiana. He can supply a good HV battery at a reasonable cost.
    JeffD
  6. bisco
    52,671
    if you can diy it, check with salvage yards and ebay for a low cost replacement.
  7. SuperDave
    SuperDave Member
    104
    22
    Anderson, In.
    Thanks , I have talked with Steve a few years back when I was looking for a Prius, I will give him a call in the morning.
    I looked on Feebay, there are a few listed just didn't see anything that stood out deal wise. I will also call the Local yards tomorrow.
  8. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    ...again I am not the expert but you if you are going to call local yards, see if Gen3 is OK too...seem to recall it is a better battery
  9. johnjamis
    johnjamis Junior Member
    79
    KY
  10. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Gen3 modules will fit in a Gen2 battery, but you need to do the swap as the Gen3 battery is not directly compatible with a Gen2 Prius - too many changes.
    JeffD
    wjtracy likes this.
  11. SuperDave
    SuperDave Member
    104
    22
    Anderson, In.
    I just got off the phone from speaking with Steve (autobeyours), he was very helpful and informative. he took the time to answer all my questions and gave some good advice.
