Traction Battery drops 1.2 instantly when AC is turned on
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by lewiscole, Aug 13, 2015.
  1. lewiscole
    lewiscole Junior Member
    Santa Monica
    2015 Prius Plug-in
    But adds 1.2 when you turn it off. Is this normal for a 2015 pip? I'm wondering if it's just me and I haven't noticed it before. Thanks everyone.
  2. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    I assume you mean 1.2 miles of estimated range? If so, then yes an estimated reduction in range is normal when you draw more from the battery. The a/c is electric. Asking for heat will show an even greater reduction. Seat heaters typically won't register a reduction in range.
  3. mrbigh
    3,686
    699
    Long Island, NY
    It is normal, with the AC and Heat on
  4. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    The Prius assums that you'll keep the AC on. So it calculates/estimates the electric draw over the next 1? miles and subtract that from the current EV estimated range. You get a similar reduction in estimated EV miles when you turn the fan on (no AC).
  5. bisco
    51,155
    these are all incorrect. you get a reduction (not necessarily 1.2 miles, when you turn the fan on, and get it back when you turn the fan off. it has nothing to do with a/c or heat. it's just toyota's very poor way of letting you know that you may get reduced miles. but of course, only the a/c will actually reduce your range, not the fan, and definitely not the heat, since the engine has to run to provide that.
