Traction Battery Failure at 107,000, need help wtih dealer
Discussion in 'Gen 2 Prius Technical Discussion' started by wadecaldwell, May 3, 2009.
  1. wadecaldwell
    wadecaldwell New Member
    Daytona Beach, FL
    I am looking for help here, as I think the dealer is covering up a mistake on their part, but I'm not sure. (Sorry for the length, but there are a lot of factors here.)
    I have an 06 that gets driven back and forth between Daytona Beach and Atlanta (435 miles at about 75 mph averge) a minimum of 2 times a month for the past 3 years. I have 107,000 miles currently and have always logged my mileage/miles per tank on the gas receipts, so I am very conscious of mileage. Since I have been doing the trip so long, I know the mileage range on the trip up and back - always between 45 and 47.
    At 84k I replaced all 4 tires (dealer didn't have Goodyears in stock) and I noticed a slight mileage drop. I investigated here and found that new tires that are not original Goodyears can have a higher rolling resistance. Between 84k and 95k, my mileage continued to drop and would usually be between 35 and 38 on the long trip.
    When I took it in for service at 95k, I asked them to check the batteries as it seemed like I was having to rely more on the gas engine than in the past. They said everything was fine.
    12k miles later and I get the dreaded lights of death and the dealer tells me the battery and ECU computer are both dead - estimate is $5,600. I balk and wait a few days, have to rent a car to make Atlanta trip, and they call and say based on Toyota "good wlll" they will give me 50% off - $2,500.
    After researching here and other places and finding detailed listings about gas mileage dropping off the table being the biggest indicator of impending battery failure, I go dig my mileage receipts and service records out of the car at the dealer lot and explain that I don't feel I should have to pay anything for the repair, as it seemed they ignored my requests at the 95k mile service and just yessed me. They have come back and offered 75% off - around $1,430.
    What still makes me mad is that the original estimate showed the battery at $3,895 and the ECU at $895. I found a November press release that stated Toyota had dropped the price of the battery from around $2,800 to 2,200 because they just weren't seeing the failure rate they had expected. So they were inflating their estimate from the start. I also read that when the battery dies, it kills the ECU.
    I am going to go back and push them to reduce it to 0 or closer to it and point out the 50% discrepancy in the price of the battery they quoted. Am I on the right track or am I asking too much? Are there any other arguments I can pile on? Any help would be most appreciated.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,193
    Nixa, MO
    I think you should ask to see the records of the visit where you specifically asked them to check the battery. If they can produce them and then I think I'd take that 75% off offer (which is probably only about 50% off of what they should be charging) and run. A brand new battery in a car with that many miles...you could go another 200k on that car.
    That said, it's a little sketch that they wanted to simultaneously replace the battery and ECU up front. And I do wonder if they did the requested work.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    I can't help with additional arguments, but $1430 sounds like a pretty good deal.
    Tom
  4. Bob64
    1,540
    92
    Virginia
    Is toyota giving you free labor with the quote?
  5. Patrick Wong
    18,200
    6,479
    I think that $1,430 is a great price considering that your car is out of warranty. In my experience when the traction battery is dead various warning lights will appear suddenly and there's not much advance warning (I've had two traction battery failures so far, covered under warranty, after owning three Toyota hybrids.)
    If no warning lights came on back at 95K miles, then no DTC will be logged. If no DTC was logged then there's no basis for the dealer Prius tech to replace the traction battery under warranty.
    Which ECU needs to be replaced? Is it the traction battery ECU? I would question routine replacement of that unless it is proven the part is bad (specific DTC will be logged in that case.) With my two failures the ECU was not replaced in either case.
    Your mpg decline could be due to a number of factors, such as rear brake drag, wheel alignment, tire pressure, new tires, etc.
    Although it is true that Toyota's suggested MSRP for the battery is $2,200 there's no requirement for individual Toyota dealers to honor Toyota's suggested parts pricing. So if your dealer initially priced the battery at $3,895 that is just one blatant example of greed showing.
    Good luck.
  6. tochatihu
    tochatihu Senior Member
    9,068
    3,538
    Kunming Yunnan China
    2001 Prius
    I also suggest you call Toyota at 1-800-331-4331 and fill them in on all the details. Get a case number. It might help motivate the Toyota shop in question, or direct you to another alternative. Also mention that your situation a topic of active disccussion among current and prospective Toyota owners at PriusChat. Good luck.
  7. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi wade...,
    Take the $1430 deal. It sounds like they prorated the battery at the 150K miles expected life, even though your not in a CARB state.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,812
    Clearwater, Florida
    That sucks.
    We see poster after poster come here and ask for help and everyone would love to help but we need one thing and that's the codes the car threw. The dealer may be really drilling you and it might not need half those parts but without those codes you and I have no idea and are at there mercy. That's a bad place to be.
    I do not trust dealers at all. I have worked for car dealers before and man oh man the stuff I saw they did to people.
    If your going to fix this car and keep it please buy a ScanGauge here at Priuschat because it will read any future codes with a push of a button so you'll know what the car is complaining about before it hits the dealer. If the dealer thinks you know what your doing and talking about and are able to recite codes to them they will be a little more hesitant to rump you. I think.
    The Scangauge does alot of things and reads codes on any OBD II car which is just about any car out there. Very valuable tool when you need it. Please purchase it here and support Priuschat!
    But $1430 does not sound too too bad. Make sure you get a trans fluid change while your there too as you are way overdue if oem fluid resides. Good luck.
  9. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    I wonder whether the dealer will put in a brand new battery or some sort of refurbished one or one from the junk yard?
  10. wadecaldwell
    Daytona Beach, FL
    The two pieces of hardware they were replacing totaled $4,790, so labor shop fees and tax made up the remaining $800.
  11. wadecaldwell
    Daytona Beach, FL
    I have been told that when the battery dies, it pretty much always takes the ECU with it. I have seen copies of battery reports in postings here and that is on my list to see when I head back to the dealer.
  12. efusco
    19,891
    1,193
    Nixa, MO
    Add that one to the long list of lies told to customers by dealers. That said, sometimes the DTC codes do not clearly tell the repair folks what is wrong, and one thing must be fixed before they can tell if something else is also broken. But there's no reason the ECU would need to be replaced just b/c the battery went bad.
  13. wadecaldwell
    Daytona Beach, FL
    They agree that the codes don't always tell the story. What they are saying now is that if they replace the battery and not the computer, there are three options: the computer is dead and they have to charge labor to take everything apart again to replace the computer, the computer could kill the new battery, or everything will be fine. And of course, they recommend the safer, more costly option 1.
  14. Patrick Wong
    18,200
    6,479
    1. Have you asked what DTC had been logged? If not I suggest you do so and post for group discussion. Then we can tell you the likelihood that the traction battery ECU has a problem.
    2. The traction battery ECU is not going to kill the new battery. What it does is to monitor the voltage of module pairs and report to the hybrid vehicle ECU when the battery needs to be charged. If the battery ECU is not working, certain DTC will be logged.
    3. Regarding a potential labor double-charge, the only labor that would be wasted is having to open up the traction battery case a second time, to remove and replace the ECU. That should be around one hour at most.
  15. richard schumacher
    7,663
    1,040
    United States
    Is this the first instance of a Gen 2 battery dying?
  16. Patrick Wong
    18,200
    6,479
  17. mona_tony
    mona_tony New Member
    16
    Houston
    The same happened with us this week.
    At 113k miles our '05 traction battery had cell #4 go out. In fact today if blew up. It sounded like a back fire.
    Not being able to afford the dealer prices I have since found on my own a used battery pack and a local mechanic is going to try and replace it on Tuesday. Wish up luck because it is our only car.
    What other problems might occur with the failure of the battery pack that we should be warned about?
    [/quote]
  18. Patrick Wong
    18,200
    6,479
    You can find repair manual info at techinfo.toyota.com and I strongly suggest that your mechanic should download and study the info about how to replace the traction battery prior to performing the job, if s/he is not already a Prius specialist. Otherwise it will be easy to screw up the job or cause a safety hazard.
  19. richard schumacher
    7,663
    1,040
    United States
    It's impossible to know how a second-hand battery might have been damaged or abused. Good luck.
  20. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i have to agree that $1400 is not a bad price if that includes labor. think about other cars and possible repair costs with that much mileage. transmissions would be more than double that and most of them would be out of warantee in less than half the mileage.
    and ya, batteries fail so rarely that there are plenty of salvage out there. i talked to a guy that specializes in salvaging wrecks and reselling them and he says that traction batteries fare pretty good in wrecks he's had. he has only had one battery that "might" have been damaged. it did have extensive damage to case, so he decided not to use it although the modules appear to be ok.
