Traction Battery indicator and triangle of death
Discussion in 'Generation 1 Prius Discussion' started by jimbfla1300, Aug 30, 2012.
  1. jimbfla1300
    jimbfla1300 Junior Member
    16
    2002 Prius
    Great Forum, and lots of good advice... I have a 2002 with 110,000 miles. Over the past 8 years it has had the check engine, triangle and ! symbols come up a few times. When I was new to the car, I raced to the Toyota dealer, but they never really found anything wrong, so I have become detuned to the issue. It has been years since the last episode, but yesterday the check engine, triangle and exclamation point all came on. The difference is now the battery indicator will drop from 75% to 25% while idling and I can hear the inverter cooler running. (usually it only runs after driving a long distance). I can see coolant bubbling in the reservoir. After a short while, the battery goes back to 75% and will stay there for awhile during normal driving, but will randomly drop back to 25%. Is this a warning of battery failure and is there anything I can check, or should I take it to the dealer? Thanks for any help.
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    It just depends. I've had these symptoms b4 but, they have not been consistent. What I think is the biggest indicator is, 1) fuel economy (has it changed) and 2) Do the warning indicators reset and come right back? If there is a problem, the warning lights/dtc's will come back consistently after being cleared. 4-5 cycles of the key will typically clear the lights. Or you can disconnect the neg terminal of the 12V battery to clear the codes. I experienced this last summer on a really hot day (virtually the same symptoms), I turned the car off, then back on and it ran normally. I reset the warning lights by cycling the key off/on 5x and haven't had a problem since. I or someone in my family drives the car nearly every day. My experience w/ the Gen I is that it can be finicky.
    I've also experienced opposite symptoms (once) where the ICE ran all the time and the battery charged to 100%, no warning lights (I have no idea why this happened). A cycling of the key fixed this as well.
    That is not to say you don't have a problem but to me (maybe to my deficit), you need to see the warnings consistently (or at least semi-consistently). Coolant bubbling in the reservoir is a good sign. I would recommend checking/replacing the 12V battery though.
  3. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    The coolant pump is always running, do you mean you can hear the fan behind the back seat that you normally never hear? If it is the fan (stick your ear at the weird air outlet on the back pillar) and it is very loud, that points to the traction battery getting very hot (ie. dead modules).
    The battery SoC jumping around also points to a bad module or pack. It could throw a red sign if the battery voltage w
    It also isn't good to have air in the inverter coolant, so it can throw codes for that reason, if the inverter gets too hot.
    I would run to an auto parts store and read the codes with an OBD-II reader to see if that gives any insight if it just happened, they will clear after you start and stop the car a few times.
  4. jimbfla1300
    16
    2002 Prius
    Thanks for the info. The 12 v battery was replaced 3 years ago and reads 12.85 with no load and 14.05 with engine running. I tried disconnecting the negative terminal, waited 5 minutes and restarted. All warning indicators went off, but returned within 10 seconds. My next step is to see if my local auto parts store can read the codes for me.
  5. jimbfla1300
    16
    2002 Prius
    Yes it is the fan at the rear that I am hearing. It comes on after driving about 8 miles/15 minutes. I don't recall hearing that before. I will go to the auto parts store and get the codes. Thanks.
    bwilson4web likes this.
  6. bwilson4web
    16,547
    The battery fan running indicates one or more failed modules that are overheating. It is a strong indicator of a failed (failing) traction battery. Sad to say, the standard OBD scanners seldom handle reading the detailed codes from the traction battery ECU . . . the ones that show the module-pair voltages and temperatures.
    Joedirte gave you excellent advice and I concur.
  7. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    Oh... well... that's different. Yeah, only go to auto parts place if they are really close, but it might give something, probably worth paying Toyota for a prognosis. Sounds like one or more battery modules are now bad and heating very quickly and heating other modules. The fan doesn't go to screaming loud unless you are really putting a lot of current into/out of the battery, or one module is bad and constantly heating itself.
    One question. Say you drive for 5 mins, put it into P, how long does the ICE run for before it shuts off?
    It may only be a few modules, but likely you are going to have to start reading about getting a new battery pack from somewhere or looking into doing it yourself.
  8. jimbfla1300
    16
    2002 Prius
    Advanced Auto Parts read codes P3006 and P3191, but no other info was displayed. The car was parked in the shade (93f degrees). When I started the battery level was at 25%. Sitting at a 4 minute light in Park the battery went to 75%. during the 10 minute ride to the auto part store it dropped to 25%. During the 10 minute ride back it charged back to 75%. The cooling fan was running when I parked it. It doesn't look good for the battery does it??
  9. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    As you've seen by the heat, one or more modules are in self-discharge range and just generating heat. From this graph: http://batteryuniversity.com/_img/content/cycle3.jpg which is NiMH 950mAh pack. [1]
    I might try force charging the battery just to see if you can coax some extra capacity out of it. I wouldn't recommend it and you probably shouldn't do it, and it could hasten the demise or overheat the module, but my view is the module is toast anyways. But if you started the car and waited 2 mins, then put into D with brake FIRMLY on the brake pedal then apply moderate pressure on the gas pedal and you will hear the engine revving. I would only do this for a minute and stop if you hear the loud battery fan kick in. I guess if the module is complete dead, you will see it jump to green/100% on the battery bar quickly.
  10. usnavystgc
    3,159
    990
    Tucson, AZ
    Well, P3006 is a good sign (for me anyway) because that means you should be able to determine which module(s) is/are bad. If you're mechanically and electrically inclined, this is not hard to do and requires few tools. You just need to access the battery and measure each module with a DMM. Does this sound like something you can do?
    Beware: High DC voltage present.
  11. jimbfla1300
    16
    2002 Prius
    I just watched a removal video on you tube and it looks pretty straightforward. I have an electrical and mechanical background and tools, so I think I'll go for it. Questions: Would you advise going to a Toyota dealer first for a more detailed diagnosis? Are the individual modules readily available? What does P3191 indicate? Thanks for your help.
  12. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    If you have time, pull the battery cover and be reasonable careful (ie don't touch or measure from one end to the other) and just measure all 38 module voltages, (or just the 19) and see if the end connectors have corrosion on them which might explain/need cleaning up.
    You could also pay Toyota $50 or $100 to print out voltages and module resistances and any codes.
    P3191 means the ICE didn't start for some reason. Subcodes might tell you more.
    This might be an interesting read (but may not apply to your situation)
    Prius 1st gen - P3101 & P3191 part 2
    Another case study which probably does not apply to you:
    2001 doesn't like being parked on slopes overnight? | PriusChat
  13. usnavystgc
    3,159
    990
    Tucson, AZ
    AFAIC, the reason you got P3191 is insignificant to the 3006 and your particular problem. That was probably a stored code from who knows when. I wouldn't put much time into trying to figure out why you got 3191 unless it consistently comes back (which it shouldn't).
    And yes, fixing the battery is pretty straightforward as long as you have some electrical/mech knowledge. Just b careful, go slow, check and doublecheck everything you do. YOU CAN DO IT!!!!
    scotman27 likes this.
  14. jimbfla1300
    16
    2002 Prius
    It has been awhile, but I finally got back to working on the Prius. I found one module reading less than 6 volts, the rest all 7.8 to 8.0. I bought a module, replaced the defective one, cleaned all the buss bar connections and reinstalled the battery. The car starts and runs well, but the Triangle and codes came back within 20 seconds. I ran the car around the block a few times and the battery indicator appears to be acting normal. I let it run in the driveway until it shut down, then disconnected the 12v battery to clear the codes, but they came back after re starting. Will the battery ever rebalance itself? Would it help to take a long highway run, or a slow ride to run the battery down and make it recharge?
    Thanks for any advice.
  15. bwilson4web
    16,547
    What are the codes?
    Are these from a Prius aware, scanner? The reason is many over the counter scanners do not know how to report the 19 module pair voltages, a key metric.
  16. usnavystgc
    3,159
    990
    Tucson, AZ
    Without knowing the codes, the triangle is probably from module imbalance. What was the voltage of the module you replaced? Did you do a balance on the pack at all or did you just replace one module?
    I don't believe a long drive would ever "rebalance" the pack. If I were in your shoes, here's what I would try (following info assumes car is warmed up and in S4 mode):
    1) Drive the car on a flat stretch between 30-35mph in all electric as long as possible (until the battery is as depleted as the HSD will let it get. You will know this when the battery indicator is at 25% and the ICE fires up).
    2) Drive normally until the battery indicator = 75%
    3) Find a long slow downgrade and coast in D until the indicator goes to 100%
    4) Drive normally to home and reset the codes
    If after all of this the codes still come back (which I'm betting they will) and the codes indicate HV battery imbalance, the only way to clear the codes will be to pull the battery back out and balance the whole pack.
    It should be noted that this is what I would try. I'm not a mechanic, I'm not smart and I'm not an expert. Taking advice from someone from KY could be dangerous to your health and your cars health. Although I don't see how this could hurt your car, I also place a low probability in it fixing your problem.
  17. jimbfla1300
    16
    2002 Prius
  18. jimbfla1300
    16
    2002 Prius
    Thanks to everybody that replied to me on this problem. I rechecked all the individual module voltages and they were all within .3 volts. The car was 90 miles from home, so I took the risk of hitting the interstate at 70 mph and then some surface streets at 35 mph to get it home. I turned it off, waited 5 minutes and restarted and the codes were still there. Not feeling great, I proceeded to drown my sorrows with a couple brews and went to bed. The next morning I started it and all codes were gone.... This was in November 2012 and it has been running great ever since (now March 2013). Gas mileage has stabilized at 44.1 mpg. Thanks to PriusChat members my 2002 will stick around awhile longer. Total cost to repair $38.00 (not counting my labor which my wife says is pretty cheap anyway)...
    usnavystgc likes this.
  19. usnavystgc
    3,159
    990
    Tucson, AZ
    That's so awesome. I love to hear stories of a $38.00 HV battery repair (that's about 25% of the cost of a new aux battery!!!!!!!). If/when my HV battery fails in my 01, I will implement nearly the same procedure.
    PS: Where did you get the module from?
  20. jimbfla1300
    16
    2002 Prius
    Purchased from ebay, seller tedb8, "Battery Boy". Search for 7.2 v prius battery on ebay. Ted shows battery charging set up. Also happy to help via phone.
