Traction Battery Preventative Maintenance - Hybrid Automotive Chargers
Discussion in 'Gen 2 Prius Technical Discussion' started by jeff652, Aug 1, 2014.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Cool. The Prius is a very powerful little car and most people don't even realize the potential it has. It can be a life saver in an emergency summer or winter if you plan well. It's a huge untapped power source. Very surprised Toyota has not jumped on this.
    Giving this thread a little more thought and I promise I'll stop after this but maybe you could make a little box that has a harness with 4 cables. 2 cables go on one side of the relay and the other 2 go on the other side. The car side of the relay for Inverter use would be bigger cables. The box would present a chassis mounted receptacle for your charger that accepts the same cord on your charger so no retooling there and the other end of the small box is 2 heavy gauge terminals for the Inverter hook up. These terminal have a protective cover. Both the charger port and terminals could be breaker protected. So you could throw the breaker to connect to the Inverter terminals. Or maybe just fuses and then a disconnect like they use on outdoor ac unit. Disconnect to wire up the Inverter. Safe and easy. Then with such a quick, safe, and easy install you don't need to mount the Inverter permanently in the car ala Bob Wilson. Just hook it up when needed.
    Make it an optional installation box. Handy too as you can check the terminals with your DVM if you were working on the battery.
    Nice test points.
    You could even hook up a semi permanent DVM to the Inverter terminals and drive around if you were doing a battery study.
    Lots of possibilities once you make that 200 volts easy and safe to grab.
    Patrick Wong, m.wynn and jdcollins5 like this.
  2. Danny
    Danny Admin/Founder
    7,093
    2,120
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    jeff652 likes this.
  3. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Danny,
    There are 168 (6*28) cells in the Prius HV Battery, not 169 as noted in the description of the "Hybrid Battery Preventative Maintenance Grid Charger". A minor edit, but accuracy is desirable.
    JeffD
  4. Mendel Leisk
    41,463
    I'm reading through the Gen II install instruction, and some way along there's this instruction:
    "On rare occasions, the battery might still have some voltage present due to a module electrolyte leak. (This is why Toyota's service procedure requires the use of insulating gloves when working on the traction battery.)
    We strongly recommend you check the battery voltage at the connection points before completing this step. Voltage should be less than 1V. Use only one hand to make the connections. Do one wire at a time. NEVER touch both battery terminals at the same time.
    Remove the white plastic terminal covers and connect the red charge positive and black charge negative wires to the 8mm high voltage battery posts as shown. .
    Reinstall the white plastic terminal covers (not shown)."
    I've highlighted in bold the part I'm wondering about. There's a photograph showing two bare copper bus bars, leading to orange wires. One's labelled "red", the other "black".
    Typically with a car, to check voltage, you put the positive lead on a 12 volt source, and the negative lead on any bare metal.
    Is the above NOT the case with checking the hybrid voltage? Do you instead just check put the meter's positive and negative leads on the bus bars labelled "red" and "black", respectively?
    I'd rather ask the "stupid" question, than not. ;)
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    To check for lack of voltage on the downstream side of the open main relays, for safety you would want to measure from the positive (red) lead to case ground and then negative (black) lead to case ground for the <1V.
    The HV battery floats with respect to ground. So you would want to check both leads to ground to verify no voltage present. You would also want to check between the positive and negative leads for total lack of voltage.
    On the other hand the 12V battery has the negative lead connected to car chassis ground. That is why you can check from any chassis ground point to a 12V source.
  6. jdcollins5
    5,131
    1,346
    Wilmington, NC
    jeff562,
    Another thread was discussing ways to short cut the multiple charge/discharge cycles needed when replacing failed module(s) in a battery pack and the need for multiple chargers for the individual module testing for similar charge/discharge rates.
    Question, could you remove the failed module(s) from a pack, perform charge/discharge testing of the remaining pack with your charger to determine pack characteristics, then perform charge/discharge testing of the new module(s)? If the new module(s) satisfies the pack charge/discharge characteristics then install new module(s) in pack and retest pack again? What are the chances of ending up with a well-balanced pack for additional years of service?
    Does this make sense? I am out of my comfort zone with battery pack testing but have read the other threads concerning short cutting the testing time with great interest, along with this thread on your new pack charger.
    Thanks,
    Dwight
  7. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    Fair question. To measure +12V from the Aux battery, you would measure from the AUX battery positive terminal to any chassis ground point. To measure the voltage from the HV battery (in case of cell leakage) you want to connect to the HV battery positive and HV battery negative terminals. I'll clarify that in the instructions next time I do an update.
    Yes, great advise. This would be the safest way to do it.
    No worries, happy to help. You could bridge a missing module and charge/balance the rest of the pack with our charger. If the voltage level drops below 200V, the charger will not be able to maintain a constant current and so it will fluctuate from 100-500mA but will still charge the pack just fine. Once the voltage hits 200V the unit will self correct and regulate to 350mA again. Our charger does not have data logging (it would increase the product cost significantly) so it's hard to test and match modules using only our charger. We have several customers who have had specific modules go bad that have bought a tested module or two online and installed them it into their pack, then charged/discharged the entire pack with our unit to rebalance and refresh all of the cells. All have gotten back on the road and are happy.
    While the charger works great for pack recovery due to cell discharge and/or imbalance, the best use of the product is as preventative maintenance. Start using this before the traction battery fails to significantly extend its life. Each time you change your oil, charge and balance the battery pack - deep discharge it as well a few times a year. The sooner the charger is installed and begins being used, the more benefit it will deliver its owner.
    Mendel Leisk and jdcollins5 like this.
  8. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Thanks Jeff
  9. jeff652
    607
    624
    Idaho
    Doh! That's my fault. I wrote the description for Danny. Fat fingered that one.
    Danny I got your email. I'll get back to you tonight :)
  10. pbui
    pbui Member
    190
    Los Gatos, northern CA
    Jeff652 - please confirm that during the "filling" stage, the charging current can be up 500mA but no more ?
  11. ericbecky
    ericbecky Hybrid Battery Hero
    4,440
    3,308
    Madison, Wisconsin
    Jeff's chargers are slow and gentle, plus provide cooling.
    I'm sure Jeff will respond, but I just wanted to jump in and reiterate that Charger/Balancers like this are much better than the ones where people are dumping in charge at ridiculously high rates.
    Whenever I read about people using hobby chargers that use high amps to "speed up the process" it makes me cringe.
    #31 ericbecky, Aug 13, 2014
  12. jeff652
    607
    624
    Idaho
    In no circumstances will the current ever be above 500mA. The current will only ever rise slightly above 350mA if the battery voltage is >50V below peak, and only for a split second or two. When the voltage is below the PSUs ability to regulate, the median current delivered is less, around 200-250mA (The current is fluctuating from 0mA to approx 400mA). This does not occur with a battery that is within its normal operating range, this only happens when a pack has sat and self-discharged to a point where the voltage has dropped below 200V (for an 04-09 Prius). In those instances, a slower overall charge rate is a good thing :).
    We are starting the development of our cooling fan control for the 2010+ Prius tonight. Should be fun! :-D
    jdcollins5 and Mendel Leisk like this.
  13. chtnwmw
    chtnwmw New Member
    Houston, Texas
    Jeff,
    I am a recent Gen II Prius owner and a first time poster here on PriusChat.com. I am seriously consider getting the charger but I have a few concern/improvement I would like to address. First off, the cable is directly connected the to 220V DC source, I have concern about this cable with high DC voltage dangling in the trunk which might accidentally gets crushed (hope not). This cable could really become a safety hazard if the cable gets wet from accidental fluid spill or rain water if the hatch is left open in the rain. I think you should consider a safety kill circuit if it detects large current draw. Having an unprotected electrical cable with high voltage is a serious safety hazard, not to mention a lawsuit magnet.
    Another recommendation is to modify the cooling fan circuit box to have a male receptacle so the original cable can be plug in directly. Cutting the cable may void the warranty of the vehicle. Also, does the cooling fan circuit box has any kind of bypassing circuit if it ever fails? If the cooling fan quit running due to the failed cooling circuit, it could potentially overheating the hybrid battery and become a fire hazard.
    Having all these changes might bump the cost/price significantly but you really don't want to put something out there that could potentially cause bodily harm. Having lived in this lawsuit happy country called US of A. You know someone will eventually do crazy things to get a lawsuit going.
    Just my 2 cents... I will shut-up now and listen...
    Tony
  14. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Welcome aboard!
    I would imagine if your savvy enough to buy this charger you would already own a mini vci ($25) and with that you can manually run the fan with the software. The mini comes with Toyota TIS software that gives you full hybrid battery diagnosis including delta and readout of all battery modules.
    With this software you can turn on the battery fan at will including speed.
    It would not make a whole lot of sense to just buy the charger and not also have Toyota Techstream software. I wouldn't chop up the fan wiring either. Cheaper to buy the mini.
    They should offer the mini with there charger. Ooops......sorry I said I would stop. lol
    Here's a popular model:
    Good luck. This charger looks pretty nifty.
  15. eblade
    eblade Junior Member
    70
    Plymouth, Michigan
    here's a q for you jeff, while you're answering.. for those of us with more money than time (or more money than sense perhaps ;) ) any idea how much it would run to get one of these installed by someone knowledgeable, somewhere in the western suburbs of Detroit or the Ann Arbor (MI) area? I'm definitely not the kinda guy that would rip the battery pack apart and replace a few cells just to save some cash, but I'd definitely put up a few hundred if it would prevent me from spending 3k in the next year or 3, and then I can put that 3k to better use replacing the broken grill piece, or the cracked bumper, or the missing wheel cover, or something. Or dump it into Toyota stock. :)
  16. pbui
    pbui Member
    190
    Jeff652 - slow charge at the top is in fact the only wait to balance the NiMh. Is the fan running at full flow or at partial % ? I am concerned about wearing out the fan bearing running for 24hrs plus.
  17. jeff652
    607
    624
    Idaho
    Wow lots of great feedback guys. Thanks!
    The design has been fully tested before release. Extensive testing has been done by our Electrical Engineer and NiMh battery expert. The system was tested to the point of thermal failure and extensive headroom is included in our ratings. You are quite safe to use our products. We have several years of experience selling the Honda variant of this product (selling over 650 chargers to date). We stand behind our products 110%, proudly offering a two year warranty on every charger we sell.
    The car harness is quite safe. If you were to dip it in a bucket of water the worst thing you would do is pop a fuse. If you have a Standard car harness, nothing would happen, as the circuit is diode protected. We planned for a short event in case collision happens that compromises the battery and/or harness. It was designed from the start to keep everyone safe. The charger has its own internal fuse. We have a car harness cap on our website for a couple bucks if anyone wants a little extra piece of mind.
    The vehicles OEM cooling fan circuit is always closed on the vehicle side while driving and when parked. Short of improper installation, it is near impossible for it to fail in manner that would disable the hybrid battery cooling fan.
    Thanks for the encouragement. Does the mini vci system work while the vehicle ignition is off? I have not researched it, but if it is OBD based I'd guess no. You cannot have the vehicle in Ready Mode while charging & rebalancing the cells or the vehicle will prevent the hybrid battery pack from ever reaching 100% SOC in the first place. That is why the vehicle must be powered off and our own Patent Pending integrated fan power/control system was developed and integrated into the system.
    We are targeting a much wider audience than the savvy tinkering owner crowd. People like easy, the masses want easy fixes. Our charger systems are an inexpensive & easy way to significantly extend the life of the hybrid battery systems. No savvy required ;-)
    We would be happy to help find a local past customer and/or hybrid specialist in your area who can install the system for you. PM or email me if you would like more details :)
    The fan runs at approx 50-60% PWM depending on version. Based on research done by our EE, the fan's rated life is such that it could run for 100% of the vehicles life and still not reach EOL. The consumption of a few extra hours once every couple month has no material impact on its service life, so no real issue here thankfully :).
  18. CBarr31
    CBarr31 Active Member
    436
    225
    Charlotte, NC
    Jeff,
    Isn't the HV battery being overcharged beyond the 80% software limit every time the battery shows a full charge and the engine RPM's ramp up to use the extra energy? I was under the impression that although the engine is high revving, which annoys me because it makes "The Burn" worse but that is a different thread, that not all the excess charge is lost and the HV battery is going above the 80% limit?
    If this is the case you are overcharging the HV battery whenever you come down a big hill and even though maybe only a few modules are getting above 90% or more the odds are that more of them are getting closer to the 80% software limit which is quasi-rebalancing. Granted your grid charger accomplishes this more completely then a big downhill overcharge but this along with extended highway miles is possibly why so few high mileage Prii have HV battery issues. Engine issues and "The Burn" are MUCH more common it seems.
    Happy Driving,
    Chris
  19. dolj
    dolj Senior Member
    8,448
    4,291
    Wellington, New Zealand
    No. Your impression is wrong. The HSD control system does not allow the battery to go above 80% capacity. Once it has reached its max threshold, what you perceive as the "the engine RPM's ramp[ing] up" is in fact the system reconfiguring the run one of the MG's to spin the engine (with no fuel flow) to burn off energy. So, in fact there is no "burn".
    It is not the case. As the HSD control system keeps the battery well short of 100% capacity, there is no way you will do any rebalancing. In the event of a long down-hill gradient, the HSD does protect its nominal 80% limit by inducing greater engine drag or using one of the MG's to spin the ICE (against piston compression resistance) with no fuel flow so that it can throw away the energy. BTW, by a long down-hill gradient, I mean well in excess of 10 mins continuous down-hill where you have to ride the brakes in addition to the normal re-gen induced drag in order to control the speed. I suspect most people never ever encounter such a gradient, because if they did there would not be so many comments on this subject. Trust me, if you do encounter such a gradient, and you fill your HV battery to 80% before reaching the bottom, then you will know all about it. The configuration at this point is absolutely disconcerting. If you have no idea what I'm talking about, you have never filled your HV battery to the full 8 bars (80%) capacity. Hence using "B" mode in any circumstance apart from this is just unnecessarily throwing away energy.
    Further, it needs to be understood the HV battery indicator is not a linear scale, it take far less energy to move from 2 to 6 bars than it takes to fill the 7th and 8th bar. When the 8th bar illuminates, you are not yet at 80% and have quite some ways to go to reach 80%. As I said before, when you reach that 80% mark, you will know about it.
    #39 dolj, Aug 15, 2014
    Robert Holt likes this.
  20. CBarr31
    436
    225
    Charlotte, NC
    dolj,
    Thanks for the response. "The Burn" has nothing to do with ICE combustion it is actually a made up term I have been using for oil consumption in Ema. This is typical of high mileage Prii and is exacerbated by engine RPM's at or over 4,000.
    In 385,000 miles yes I am very familiar with a "Full" SOC condition and KNOW all about it. There are numerous hills and mountains outside of New Zealand that can cause the condition. My question next would be you are positive that 100% of the energy created is being burned off by the MG's even when your engine RPM's are over 4,000 in such a downhill condition?
    I was looking for a reason why so many high mileage Prii don't experience HV battery issues but I guess it is more the lack of HV battery cycling due to highway miles over the possible quasi-rebalancing. Thanks for the info.
    Happy driving,
    Chris
