Traction Battery Preventative Maintenance - Hybrid Automotive Chargers
Discussion in 'Gen 2 Prius Technical Discussion' started by jeff652, Aug 1, 2014.
  1. ericbecky
    ericbecky Hybrid Battery Hero
    4,426
    3,300
    Madison, Wisconsin
    I'll answer a bit and let Jeff chime in with the rest.
    2) You could charge daily as long as you stayed within the cars normal operating state of charge.
    You would not want to charge it up to 100% SOC every single day. That'd be too hard on the pack.
    3)The balancing happens mainly at the top end of the SOC range. If you don't bring the pack up to the high SOC range it won't balance. Most of the time you would just be balancing if you stay away from the top SOC range.
    jeff652 likes this.
  2. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    Awesome! Thanks for the kind words. Yes, the chargers are all dual voltage. We have shipped many to Australia and all over the world. We can configure it to charge only to ~80-90% to be used daily as a PHEV charger but then it would not rebalance the battery cells. We are working on a fancy 3A version that can do both but that is far away still. Right now it is hard set from the factory and not adjustable without disassembling the unit (which you could do if you want, takes ~15 min to reconfigure each time). The 'as shipped' configuration is charge & balance, as that is where the real value of the product is. You know that unit has transitioned from charging to balancing when the displayed voltage stabilizes. After that is a simple time calculation. The HV fan comes on immediately when the charging process begines to get the battery cool and keep it cool. Shipping to Australia is $60USD for a charger system, or $80USD for a charger and discharger combination system :)
    Agent J likes this.
  3. Agent J
    Agent J Hypoliterian
    294
    111
    Sydney, Australia
    Thanks for that. I think I'll get the current one on offer first and if ever you need a test mule for the charger-only (or dual) module, i'd be more than happy to report on it. :)
  4. pbui
    pbui Member
    190
    Los Gatos, northern CA
    What is the purpose of discharging, and cycling ? Is it just to "exercise" the pack ? can someone confirm the benefits of cycling ?
    since the balancing is done at the top, when the full cells simple convert added energy to heat while waiting for the lower cells to catch up.
    thanks
  5. ericbecky
    4,426
    3,300
    Madison, Wisconsin
    Simplest way to explain it is that the discharging helps regain capacity. The Honda Insight community has used similar chargers/discharger for years.
  6. krmcg
    2,592
    2,392
    Whittier, CA
    Is there a go-to place in Southern California that could/would install this for me? Installation cost?
  7. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    I have also read that NIMH batteries can form crystals inside and cycling will break these up.
  8. ericbecky
    4,426
    3,300
    Madison, Wisconsin
    Another way to think about it is that when nimh crystals are new they have well-defined facets. Over time the facets become muddled. Discharging can bring back some of the facet's definition. Never as good as new, but better than if it was never cycled at all.
  9. jeff652
    607
    624
    Idaho
    Yes and deep cycling (charging and discharging) produces much better results than charging alone.
    Scott at Jue Motors in Covina is our Socal Authorized Installer. He will take good care of you :) - 909-605-3810
  10. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Jeff652,
    Firstly, I don't doubt your sincerity and the basic rationale behind your product, but I do find claims of "significant" improvement in battery life to be not informative at best. I say this as a person schooled in basic statistics where 'significant' means the improvement is highly unlikely due to chance, but it says nothing about the amount of improvement.
    Can you provide quantitative data that can gives a firmer notion of how much longer a battery will last ? I am thinking of data that compares in the lab groups of batteries aged with and without your balancing protocol. This kind of study could start from new batteries, or begin with batteries that had been aged down to say 75% of rated capacity.
    I entirely agree that people who buy your product after the battery gives off an alarm have missed a window of opportunity to prolong battery life that will not return. I'm interested in knowing the value of smart battery maintenance over 5 - 10 years.
    #70 SageBrush, Sep 6, 2014
    kiwi and Patrick Wong like this.
  11. pbui
    pbui Member
    190
  12. jeff652
    607
    624
    Idaho
    Our chargers are guaranteed to improve the life of your hybrid traction battery anywhere from one day to three years (or more). It is not possible to quantify how much the charger will help your specific battery, as the amount of improvement depends entirely on the condition of the underlying battery pack itself. The sooner one starts using a charger, the longer they can expect it to extend the life of their battery pack.
    A significant percentage (over 97%) of our customers report battery improvement at the time of purchase. They report improved fuel economy, longer assist before the battery empties, and increased EV mode performance. Customers who opt for the discharge option report increased battery capacity. Many of our Honda customers have already experienced a 'failure' and are able to add several months and even 1-2 years to the life of their battery with a charger. Just under 2% of our customers report that they are no better off with the charger than they were before they used it. The amount of time that the improved performance created by the charger will last is entirely dependent on user habits and underlying battery condition. We have sold just under 700 chargers and the above statistics are drawn directly from our customer base.
    I could add hundreds of dollars to the price to cover the cost of the lab data you are referring to, but it would not be a wise investment for me or for my customers. We know this works, which is why we have sold so many of them and are investing in patents before the large automotive companies enter this space, which will happen eventually. The technology works for the same reason that removing the pack from the car and cycling/rebalancing the individual modules works. NiMh cell self-discharge, crystalline formation, and multi-cell imbalance are well known phenomenon and easily verifiable via a Google search. It may appear novel and unproven to you, but this is very established technology.
    #72 jeff652, Sep 8, 2014
    usnavystgc likes this.
  13. jeff652
    607
    624
    Idaho
    Sulfation is a well known effect that impacts NiMh battery cells. They experience a memory effect, just like their NiCD brethren. Performing a deep discharge in a slow controlled manner can break down these crystals and restore lost battery pack capacity.
    How low? That is still up for debate. Some people go all the way to zero volts. Some go only to 0.92V/cell. Both methods appear to work well if done properly. I personally have done both and seen prolonged cell capacity improvement with each approach.
  14. kiwi
    kiwi Member
    246
    87
    New Zealand
    To Jeff652: who wrote, quote, "Sulfation is a well known effect that impacts NiMh battery cells" end of quote.
    • Are you serious? Are you selling chargers to cure "sulfation" in NiMH batteries?
    Could we suggest that was a typo...
    FYI: Sulfation is a chemical reaction found in Lead Acid batteries, not in NiMH. :)
    jeff652 and SageBrush like this.
  15. jeff652
    607
    624
    Idaho
    Yeah, I did state that incorrectly. I should have said crystalline formation. I'll edited the post to be more precise :)
    Edit: Here is a nice article that talks more about the crystalline formation phenomenon. It's Primarily focused on NiCd, but also touches on NiMh:
    How to Restore Nickel-based Batteries - Battery University
  16. ericbecky
    4,426
    3,300
    Madison, Wisconsin
    Jeff,
    You linked one of my favorite articles.
    The three photos at the beginning are the ones I think of when describing battery condition.
  17. kiwi
    kiwi Member
    246
    87
    New Zealand
    I like the way you think... FYI -We have already started here in New Zealand...
    • There are numerous patents and tons of claims of all sorts of "cure" against aging of everything from face wrinkles :-( to traction batteries in this case.
    • There are numerous rejuvenation/reconditioning "proprietary" technologies claimed especially in USA which is famous from the Golden Rush to modern times to be full of inventive people selling “Elixir of Life”.
    • For example you can easily find on the net:
      - Numerous schematics for devices to recondition and conduct “de-sulfation” of Lead-Acid batteries
      - Numerous articles, patents for asymmetric or sometimes called “burp” or "pulse" chargers to destroy “crystals” formed in NIMH batteries and hence regain capacity
    • What is lacking in all those claims, articles and patents is absolute absence of the documented results of the tests conducted in controlled environment.
      We at www.hybrids.co.nz have been asked numerous times of whether we think those technologies work or not.
      We are open-minded and inquisitive at the same time and extremely curious of the end results ourselves.
      Without conducting tests – how do we know? But, wait, we though recently:
    • Our High Voltage Battery Analyser is perfectly fit for purpose to prove or otherwise any claim of reconditioning improvements.
    • We can put few batteries together, charge few with conventional “off the shelf” charger and few with the “magic” charger and discharge simultaneously one and another with the same load applied in controlled manner, graph it, table it and analyse what is going on.
      Being curious we have purchased recently two quite expensive Asymmetric Pulse (“Burp”) Chargers for NiMH batteries. Those are claimed to have something similar to NASA technology and reference to previously openly published ideas incorporated into them. It is now up and running in our lab.
      We have also invested in some extra testing tools and planning to build our own Lead Acid De-Sulfator following open source design, which was claimed by folks in US and Japan to rejuvenate Storage (Solar) / UPS / Starter and Traction (Golf Carts) Lead Acid batteries.
      We have plenty of Lead Acid batteries from our industrial UPSs, plenty of Prius NiMH batteries and NiMH batteries used in RC models to play with in our Lab
    Surely we will have a lot of fun in conducting numerous tests.
    We are not biased at this stage to object or support those reconditioning ideas. Please continue inventing stuff.
    • P.S. Providers of "magic" chargers of all sorts are welcome to send their devices to New Zealand for us to test.
    • Even if it is a prototype and requires assembly and soldering - we can add tender loving care to it and put it to the test.
    #77 kiwi, Sep 8, 2014
  18. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    X2
    Great article and the pictures are worth a thousand words as to why the deep cycling works (ie cycling breaks up crystal growth in NiMH cells).
  19. kiwi
    kiwi Member
    246
    87
    New Zealand
    Putting my audit and analyst hat on can't resist to mention folks that that article IS NOT applicable to NiMH Prius batteries. The whole article and deep discharge methodology is applicable to nickel-cadmium batteries. Modules used in Toyota are NOT NICd, they are NiMH.
    By the way, applicable to both type of chemistry, the methodology suggested by then was aimed at increasing battery life span and was mostly focused on the way you charge (pulse charging) to Prevent formation of the crystals at the first place by reducing overheating of the plates and formation of crystals during charge, rather then to try and apply reconditioning after-fact when it could be too late.
    What we have already found with the our newly build asymmetric pulse charger - versus conventional one is that batteries were experiencing little temperature rise and accepting more charge. But that IS NOT yet an indication of increasing module's capacity. Conventional chargers (aka RC chargers) a lot of forum members have in their possession - they cut off charge based on change in voltage curve (aka delta-v). Pulse charger we use for experiments control the temperature rise - hence not cutting of prematurely. That may give wrong perception of the capacity being increased, whereabouts it is a matter of being able to fully charge vs partially charge by conventional charger.
    Cheers,
    FireFighterHill and SageBrush like this.
  20. jeff652
    607
    624
    Idaho
    Did you actually read the article :p? If so you would see that it applies to all nickel based batteries:
    "When nickel-metal-hydride was introduced in the early 1990s, this chemistry was promoted as being memory-free but this claim is only partially true. NiMH is also subject to memory but to a lesser degree than NiCd. While NiMH has only the nickel plate to worry about, NiCd also includes the memory-prone cadmium negative electrode. This is a non-scientific explanation of why nickel-cadmium is more susceptible to memory than nickel-metal-hydride."
    The memory effect is present in Toyota and Honda NiMh batteries, and deep discharge in a slow controlled manner that minimizes cell reversals while maximizing the conversion inactive NiOOH back into active material is the preferred method for capacity recovery. Our simple discharger add on item does this now for less than $50USD. Our advanced computer controlled discharger will do it in a fully automated manner that requires minimal user intervention for around $300USD.
    Sure there are other fancier options on the market that are much more expensive and/or require the battery to be removed from the car and possibly dissassembled to the module level, but that is fine with us. We are not trying to be the only product in existence. We are the only sub-$400 in car hybrid battery charger/balancer/discharger on the market today.
    #80 jeff652, Sep 9, 2014
