Traction battery rebuild at only 106k mi!
Discussion in 'Gen 2 Prius Technical Discussion' started by YY4U, Jun 16, 2015.
  1. YY4U
    YY4U Junior Member
    85
    23
    Hello all,
    My daughter's '05 with only 106k mi just got the red triangle. I guess the heat in the deep south takes its toll.
    Block 11 is the obvious culprit. It's the highest when charging and the lowest when not. I'll pull the pack tonight and get it on the bench. I'm sure a voltage test will pinpoint the bad module, but can anyone give me a head's up on exactly which 2 modules make up block 11?
    Thanks,
    YY
    MTL_hihy and strawbrad like this.
  2. JC91006
    16,937
    8,647
    It should be, counting from the battery ecu end, first 2 will be block 1, 2nd 2 will be block 2, and so forth
  3. strawbrad
    953
    1,007
    I am nearing a hundred rebuilt batteries, In my personal experience the module count starts opposite the ecu. This is for the Gen II Prius years 2004 to 2009. Good use of Techstream to do a charge and discharge test. Please share your personal observations .
  4. JC91006
    16,937
    8,647
    yes I've heard that before........since you're nearing a hundred and I'm at 1, you win :)
  5. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    That's depressing! Sorry for your loss :(
    I'm telling you, not enough miles for its age. It really seems with prii that they like being driven
    Merkey likes this.
  6. YY4U
    YY4U Junior Member
    85
    23
    Yes, let's go with the guy with 100 rebuilds. And it turns out strawbrad is right. Using his numbering method, block 11 would be modules 21 and 22. Guess what? Mod #22 is reading over 1.25v less than all the others, so it's a no brainer; it's sticking out like a sore thumb.
    Here's my parts battery:
    This is my 3rd rebuild. If you need a good laugh, check out my 1st try a couple of years ago:
    Traction battery rebuild question | PriusChat
    Everything that could go wrong did go wrong. It ended ok though, I just sold that car this week after putting 24,000 miles on the rebuild and it was still running strong.
    On this job I'm going to replace the bad module and do this:
    3 discharge/charge cycles on each module.
    .7 amp discharge to 6v.
    5 amp charge to 7500 mah.
    5 minute rest.
    720 minute timer.
    This is what I did before. If there is a new, better way, please let me know. I read somewhere to only charge at 2 amps, but that would take forever. I only have 4 DC-6 chargers and would like to complete this in 2 weeks or less.
    Since this car has such low mileage, I'm tempted to just replace the one module and button it up.
    Any thoughts?
    YY
    #6 YY4U, Jun 17, 2015
    strawbrad likes this.
  7. strawbrad
    953
    1,007
    If this were my kids car and she needed something to drive NOW I would do just that. Then I would go to work on the parts battery. You are sitting on a pile of gold there. I feel that one of the best module test that is too often overlooked is self discharge, How long as your spare battery been sitting untouched? I will not use any module that can not hold at over 7 volts in storage, Once you finish cycling through the parts battery then pull the pack from the car and replace it with the parts battery and as many modules as needed from the cars original battery, Then go to work cycling the cars original modules, When you have cycled all the modules from both batteries select the best matched set of 28 to build a good pack. Low mileage is not as important as years and heat. Since you have at least two Prius in the family you could repeat this process every couple of years as your batteries die. The extra pack could keep you cars running for a long time.
    Brad
  8. YY4U
    YY4U Junior Member
    85
    23
    My parts battery has been sitting in the garage for over a year. The guy I bought it from on Craigslist probably had it sitting for a year or two. Last year, on my 2nd rebuild, I ran all the mods through several cycles and recorded the final voltages, capacities etc. Tomorrow I will look at my list, and see if I can find one that is still reading 7v+.
    If I remember correctly, I suspected the CL seller was less than honest (what? Say it ain't so). He said his battery went bad, he was going to rebuild it, but decided to buy a rebuilt one instead, he somehow managed to keep his core (huh?), and just needed to get rid of it. I expected to find many good mods, but most were shot, kinda like he had already pulled all the good ones and filled it with known bad ones. He prob owned a fleet of taxis and these were his million mile rejects. And I drove 2 states away to get it. But if I get another mod or three out of it, it was well worth the $150.
    Hopefully I can find just 1 more.......
    YY
    #8 YY4U, Jun 17, 2015
  9. strawbrad
    953
    1,007
    Sitting for a year is perfect! Just the measure their voltages now before doing any charging or discharging. Any module that is still over 7 volts is worth putting through another round of cycle charges. The modules that have fallen below 7 volts should be put in the discard pile.
    Too bad your spare battery is in such poor shape. A spare pack can be all you need to keep your fleet of Prius running for years. If you decide to invest in another spare pack use Car-Part.com--Used Auto Parts Market . It is a data base of almost all junk yards in the US. You can search and sort by price and location. Batteries in the deep south tend to be expensive and few to pick from. In the cold frozen north batteries are becoming plentiful and prices are dropping.
    Brad
  10. YY4U
    YY4U Junior Member
    85
    23
    Good news, the spare pack is better than I expected. The first 7 or 8 were bad, very bad, 1-4 volts, like the Craigslist seller had pulled the first few on the end out and replaced with bad modules, just to make a full pack he could sell. That's what I was remembering. But the other 15-20 or so all measured between 7.4 and 7.8 volts, after sitting 13 months. So life is good again!
    I'll start cycling today. If the mods in the battery I'm repairing all have good capacity, I'll just cycle them once or twice.
    Thanks,
    YY
    Strawbrad, is it ok to charge at 5 amps?
    And away we go!!
    My parts battery notes from last year.
    YY
    #10 YY4U, Jun 18, 2015
    Aaron Vitolins likes this.
  11. strawbrad
    953
    1,007
    Good for you! Not only do you have a good selection of replacements but you also have a wealth of data. It would be great to compare new cycles and the results from a year ago. Did the modules hold at the same capacity as a year ago? Did they loose any gains from the last rounds of cycles? It takes a year to do this kind of testing. This could show some real insights in to the long term effects of cycle charging and discharging.
    I think that is a matter of opinion. Hopefully other members will add their thoughts. I usually charge a whole pack at 400 mA.
    Brad
  12. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Great project! Thanks for sharing all those details!
  13. YY4U
    YY4U Junior Member
    85
    23
    Ok, I may have some problems. I'm going through the modules in the battery I'm rebuilding and I may have something in my chargers set wrong. The discharge went good, but something is happening during the charge and they are charging very quickly. The discharge took 6-7 hrs, but the charging took a fraction of that. Or can these batteries really be this bad?
    Mod #1 4663mah discharge 2679mah charge
    Mod #3 4463mah discharge 986mah charge
    Mod #25 1878 disch 2741 ch
    Mod #27 3865 disch 828 ch
    NiMH Charge: auto
    720 min timer
    10.00v low input cutoff
    Delta Peak: default
    Either I'm doing something wrong or these mods are not as good as I thought. I'm running another cycle. Perhaps I need to be charging at 2 amps?
    YY
  14. strawbrad
    953
    1,007
    Hows the project going? I see two possible reasons for the low recharge figures. One would be that your chargers are seeing false delta V drops. That's no big deal. It just happens sometime. I am not familiar with the chargers you are using. What is the default Delta Peak setting? Can you change it? The other thing I noticed in your pictures is that the chargers are sharing their 12 volt supply. My chargers do not perform well this way. When one charger starts up it can pull down the 12 volt supply which will cause the other charges to shut down. Make sure the 12 volt lead acid batteries are well charged and that the 12 volt charger is big enough to handle the load. The good news is the problem is most likely not your modules.
    Brad
  15. YY4U
    YY4U Junior Member
    85
    23
    Brad,
    I'm not sure what the default Delta Peak setting is, but it can be adjusted from 5-20 mv/cell. I don't know which way to adjust it. I've always left it on default, but this very well could be the problem.
    The chargers are set on a 10v low input setting, this has not been an issue since I went to two 12v batteries. With just one I used to get low voltage errors all the time. They read 12-13v every time I check them. This is not the problem as the chargers are finishing their cycles, just with poor results.
    In fact the results are so bad, it's actually encouraging. If these modules were really this bad this car wouldn't even run:
    Mod #1 4663mah discharge 2679mah charge(1st charge), 2588-7500(2nd charge), 5511-7500(3rd charge) (decent)
    Mod #3 4463mah discharge 986mah charge(1), 1019-842(2), 865-1669(3), 1640-902(4)
    Mod #25 1878 disch 2741 ch(1), 2302-2397(2), 2213-793(3), 789-3215(4)
    Mod #27 3865 disch 828 ch(1), 924-1860(2), 1891-615(3), 672-1734(4)
    Mod #7 1919-1648(1), 1756-5363(2), 3224-5305(3)
    Mod #21 3845-555(1), 604-509(2), 600-635(3)
    Mod #23 3134-209(1), 223-994(2), 1046-117(3), 110-1257(4)
    The charger that did mod 1 is now charging mod 5 and it's taking much longer than the others. Perhaps 3 of my 4 chargers went bad just sitting? Unlikely, but possible. When mod 5 finishes I'll post the results and see if I can find any difference in settings between the 4 chargers.
    Can anyone recommend Delta Peak settings?
    YY
  16. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    Britprius (John) always recommends setting the delta peak cutoff to the highest setting possible. In your case to 20 mV/cell.
    hope this helps.
  17. strawbrad
    953
    1,007
    The intention there is to turn the delta V off. The chargers are not likely to ever see a delta V that great. This is fine and dandy if you are trying to put a reasonable fixed over charge into the module. At the end of the charge all that energy (5A X 9V =45W). is going to heat and forcing oxygen out of the cells. Setting the termination at 7500 mAh for a module with 6000 mAh capacity leaves only 1500 mAh for heat. Putting 7500 mAh into module #25 with a capacity of less than 2500 mAh leaves 5000 mAh with nothing to do but heat the cells. This leads in to the argument for low power (300 mA) grid chargers. At that rate there is only about 3.5 W to charge and heat the modules.
    Modules #25 and #7 look bad. The rest look like good modules with charger problems. Looking at #25 more closely.
    Discharge 1 is only 42% of the stronger modules. Charge 3 looks like a false delta peak. The rest of the charge and discharges look like a module with 2500 mAh of capacity.
    Module 7 follows the same pattern of low initial capacity and small gains.
    I saw 15 modules with much better capacity in your notes from last years tests of your parts battery.
    #'s 2,3,4,7,8,10,11,12,14,15,16,17,18,19,20.
    Keep up the good work.
    Brad
    #17 strawbrad, Jun 21, 2015
  18. Texas Hybrid Batteries
    Texas Hybrid Batteries Senior Member
    271
    563
    Dallas -Fort Worth
    Reduce your charge rate to 2A and set the Delta Peak to 20 mV. That will eliminate the false peaks and early charge terminations. You will also be able to manage the heat better at 2A vs 5A. That's a very important part of the process if your going to charge above 6500 mAh. Strawbrad is right about the supply voltage to the chargers, they don't perform as well in the 13V range. 17-17.5V is what I find works the best.
  19. YY4U
    YY4U Junior Member
    85
    23
    Thanks, guys. I'll do a round with the Delta Peak set to 20 mV at 2A and post the results.
    #19 YY4U, Jun 21, 2015
  20. YY4U
    YY4U Junior Member
    85
    23
    Earlier; Delta Peak settings at "default":
    After changing DP settings to 20 mV, charging at 2A:
    Mod #1 Looked good the first time around so I didn't balance it again
    Mod #3 850-7500, 5776-7500, 5680-7500
    Mod #25 2895-6175, 3902-6169
    Mod #27 2024-7500, 5651-7500
    Mod #5: (lost data on first 2 charges, but looks good), 5198-7500
    Mod #7 3523-6131, 3994-5134, 4125-4197
    Mod #21 5012-7429, 5173-7148
    Mod #23 4626-7187, 4971-7329
    As you can see, the numbers look much better. The odd thing is, during my previous 2 rebuilds, the DP was set on default and worked fine.
    Brad, mod 7 still looks squirrely, but what about mod 25? Good enough or replace it? I'm going to go through all 28 of these modules before I decide which ones to swap out and break open the pack.
    At 2 amps, this is going to take weeks. Fortunately, I have a spare high-mileage-but-great-running 2005 Prius that my daughter can use, so downtime is not a major issue. I should probably upgrade my chargers. Maybe buy just one extra unit that can charge multiple modules at once and has it's own power supply. The Thunder T6 seems to be sold out everywhere. Any recommendations?
    YY
    #20 YY4U, Jun 23, 2015
    MTL_hihy likes this.
