Traction battery rebuild question
Discussion in 'Gen 2 Prius Technical Discussion' started by YY4U, Apr 6, 2013.
  1. YY4U
    YY4U Junior Member
    85
    23
    I tried, but it pops right back on, almost immediately. With only .04 difference in voltages I really expected the lights to go off. Now I wonder if I knocked something loose or caused a short. Hopefully the new scanner will shed some light.
    yy
  2. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    I agree with the battery voltages that close you should not be seeing a problem.
    Did you see any problems with the small wires from the battery terminals, these go back to the ECU to report module pair voltages, and are prone to braking off at the terminations causing no voltage to be reported.
    I do think, and hope for you this is something minor.
    John (Britprius)
  3. YY4U
    YY4U Junior Member
    85
    23
    John,
    I'm not sure which wire you are referring to. Can you elaborate?
    yy
  4. Britprius
    5,194
    1,924
    The wires I refer to "colored, orange, green, and blue on this section of the battery" are clearly visible in the picture below and have been known to cause problem. From memory I think there are 14.
    John (Britprius)
  5. YY4U
    YY4U Junior Member
    85
    23
    I'll check the wires and connectors today, as soon as I can pull the cover off. Thanks.
    yy
  6. YY4U
    YY4U Junior Member
    85
    23
    I didn't see any broken wires or anything disconnected. Since the bus bars were off I checked all the voltages. The lowest was 7.58v and the highest 7.71v, a difference of .13v. This is after balancing them all and then driving the car 20-25 miles.
    Thoughts? Ideas? I should have my scanner in a week or so.
    yy
  7. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    YY,
    Measure the series resistance of each module by drawing one amp and measuring the voltage drop at the module terminals (don't rely on the DT6 to measure the voltage as the wires have some voltage drop as well). If any modules exhibit a noticeably higher series resistance, that can account for your alarms.
    JeffD
  8. YY4U
    YY4U Junior Member
    85
    23
    Jeff,
    Can I use the DC6 to discharge? I think max discharge is .7 amps.
    yy
  9. jdenenberg
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If you discharge at 0.5amps, just multiply the voltage drop by two to get the series resistance. At 100 amps discharge (high acceleration), a difference of 1 miliohm between modules can account for a 0.1 volt lower module voltage and about a 0.2 volt difference can trigger an alarm.
    JeffD
  10. YY4U
    YY4U Junior Member
    85
    23
    Jeff,
    I'm still waiting for my bluetooth dongle, but I load tested the modules at a .5 amp discharge and here are the results. Note that these module numbers are the original numbers, they've since been moved around.
    Which brings up something you talked about earlier; pairing similiar modules together. Perhaps you could elaborate.
    These voltages were after the pack had set for a few days with the bus bars disconnected. #1 still was the lowest voltage at 7.59. All modules under load discharged .01-.02 volts, so at a 1.0 amp discharge that would be .02-.04. I'm not sure what module resistance is, exactly, but they are all similiar.
    While I'm waiting for my scanner I'm going to balance the modules again, then immediately connect everything and start the car. If I still get the lights I'll be able to retrieve the codes soon.
    Anyone who has a comment or opinion is welcome to jump in here!
    MOD # VOLTAGE UNDER LOAD (.5 AMP)
    1 7.59 7.58
    2 7.67 7.66
    3 7.64 7.62
    4 7.63 7.62
    5 7.66 7.65
    6 7.65 7.63
    7 7.67 7.65
    8 7.67 7.66
    9 7.66 7.65
    10 7.64 7.63
    11 7.63 7.62
    12 7.64 7.62
    13 7.64 7.63
    14 7.63 7.62
    15 7.62 7.61
    16 7.64 7.63
    17 7.66 7.64
    18 7.64 7.63
    19 7.68 7.66
    20 7.65 7.64
    21 7.63 7.62
    22 7.73 7.72
    23 7.68 7.66
    24 7.63 7.62
    25 7.64 7.62
    26 7.64 7.63
    27 7.63 7.61
    28 7.62 7.61
    Too Wise
  11. jdenenberg
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The battery ecu monitors module pairs (2 in series) so if you group module pairs so that the sum of their voltages track with the other pairs, the ECU will stay happy. Just put the weakest modules with the strongest and put those that dropped 0.01v with one that dropped 0.02v in your resistance test and you will have a better chance of avoiding alarms (I would pair module 1 with module 22). The downside is that this requires disassembling the battery again.
    The resistance is the voltage drop divided by the current so your series resistances measure 20 and 40 milliohms. A higher load current would give a more accurate reading, but your new scanner should also be able to report module pair resistances (the sum of the two in series),
    Good luck,
    JeffD
  12. YY4U
    YY4U Junior Member
    85
    23
    I balanced the modules again, removed the harness and started the car. The lights came on instantly. I don't see any modules that should be immediately setting codes and lights. I may have a short or a bad wire somewhere.
    I'll have my dongle soon and we'll see what Torque has to say.
    yy
  13. YY4U
    YY4U Junior Member
    85
    23
    Got the dongle, Torque gave me code POa9e. "Hybrid battery temperature sensor "A" circuit high". Hmmm, as noted early on, I taped the temp. sensor to module #28. Hmmmm.
    yy
  14. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    It sounds like the wires to the sensor got nicked, and are now open circuit. should be simple to find. See the circuit diagram attached. You should see some medium resistance in the circuit.
    For fun, here is what Toyota says about a bad temperature sensor circuit:
    "Since the battery temperature sensor is not available by
    itself, if replacement is required, replace the entire HV
    battery assembly."
    :ROFLMAO: (n) :eek:
  15. YY4U
    YY4U Junior Member
    85
    23
    I don't see a circuit diagram.
  16. nh7o
    1,686
    340
    Hawaii
    Sorry, now added to my post.
  17. jdenenberg
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If you need it I also have spare wiring/sensor cables as well as miscellaneous parts from my original 2004 Prius battery.
    JeffD
  18. YY4U
    YY4U Junior Member
    85
    23
    Does anyone know which of the 3 wires underneath the modules is temperature sensor circuit "A" ?
    yy
  19. Britprius
    5,194
    1,924
    If you put an ohm meter across the ends of the wires at the ECU the good ones will have resistance of around 1k ohm the non working one will be open circuit. Best I can help sorry.
    John (Britprius)
    SFO likes this.
  20. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    Techstream / MiniVCI will give you relative internal resistance for each pair of modules, but not a high resolution/ accurate measurement. We built our own circuit to measure IR, with higher accuracy than Techstream. (We install 1-2 rebuilt batteries each week so we needed something extremely accurate that we could depend on)
