Traction Battery SOC "Meta-States"
Discussion in 'Gen 2 Prius Technical Discussion' started by uart, May 31, 2013.
  1. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Thanks miscrms. Yes your assessment of what's happening here is pretty much inline with my own. It's due to a reduced capacity battery (for whatever reason), where it's hitting upper or lower voltage limits which makes it need to recalibrate the coulomb counting assessed SOC. My solution for the past 2.5 years (since I first noticed it) is simply to avoid too many large SOC swings where possible. Essentially I try drive in such a way to prevent it hitting those voltage limits too often if I can, though obviously it's not always possible.
    Before you spend too much money on it, note that I've had the issue for at least 2.5 years and nearly 50k miles now and mine hasn't got much worse. So it's quite possible that a battery can be in this condition but remain operational for some time. I agree with Jeff652 that a grid charge would be worthwhile trying on this particular problem. It may or may not improve it, but I think it's worth a shot. About 18 months ago I designed myself a simple grid charger and was planning on doing this myself, but for some reason I just never got around to it. (The usual, got complacent, battery didn't seem to be getting any worse, just kind of got used to living with it and couldn't be bothered.) Anyway, I'm definitely thinking about reinstating that plan, and I'll certainly update this thread with the results if I do so.
    #21 uart, Oct 14, 2014
    SageBrush likes this.
  2. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    It's to my understanding though that grid charging only charges the battery to 100%, but doesn't drain it. Correct me if I'm wrong. But from what I've read, I though to restore capacity, that the pack would be drained, then charged full once or twice. Again, I could be totally wrong.
    I live in WV, so a full (76-80.5%) charge is seen daily unfortunetly. But when it does that SOC drop from 6 bars, then a few seconds later down to 5, then 4, then 3, it gets kind of annoying. The engine starts to race, MPG goes down cause it's trying to charge it back up to it's normal state. But once it gets there, it's all fine and dandy.
    I did use Torque to monitor the 14 block voltages, and they all stayed the same under load and charging. Played very well together. So I know it's not an imbalance issue. I guess it's just age. Even with only 50,000 miles. I thought it may be the 12v battery going bad, because it's the original battery, but I did all the 12v testing and it acts healthy. I plan to change it anyway.
  3. That_Prius_Car
    1,282
    344
    Pittsburgh, PA
    I also wonder if corroded buss bars could cause this?
    52,789
    i don't see why not.
  5. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    You are correct. For best results on a Toyota battery, we recommend the charger and discharger as a set. This allows for unlimited in car battery refurbishments to be performed. The "Discharge Ready" is required but by itself does not by itself allow the hybrid battery to be discharged. It replaces the standard diode on the car harness with a ceramic fuse assembly. This allows current to be drawn by the battery by a discharger. We are developing an advanced discharger that is not released yet, and we offer a simple discharger on our website now:
    This is called a negative recalibration, and is the first sign of poor battery health (and impending failure). By performing an in-car battery refurbishment with our products, you can eliminate the recalibrations typically for several months. By performing a refurbishment a few times a year and charging every 6-18 weeks in between, you can extend the life of the battery for years. If you wait until one of the cells experiences a hard failure, even a refurbishment treatment with our products will not help and you will need to replace the module or the entire pack.
    gdanner and Danny Gonzales like this.
  6. Garvin
    Garvin Junior Member
    I have a generation 3 prius at 78000 km and i am also experiencing this behaviour. Charging would be initiated when the SOC falls to around 39.6% from full, but it would sometime fall all the way down to 30% SOC before the SOC starts increasing again.
  7. daniel boro
    daniel boro Junior Member
    israel afula
    i didn`t read inaf
    but as far as i know battery SOC is usually measured by Volt
    V and SOC is effected by Temp
    the battery Temp goes up wen in use/charged
    this can explain the drop in SOC at the beginning of recharge
    recharging heats (makes it hot) the battery more then using it did, and the increase in T drops the V
    making it look as a drop in SOC
    edit: fixed spelling
    wen ill be on a computer whit a spell checker ill try to fix this post
    #27 daniel boro, Mar 25, 2015
  8. daniel boro
    israel afula
    some data from torque
    Block Highest Volt(Volt), Block Lowest Volt(Volt),SOC(%), # with Max V(Num), # with Min V(Num),Battery power (kW)
    15.04 14.91 52.0 0 5 -3.03876
    15.08 14.91 51.5 0 11 -2.34951
    14.94 14.79 51.0 0 11 -3.28355
    15.08 14.92 51.0 0 11 -3.28355
    15.21 15.09 50.5 13 11 -3.25591
    15.24 15.11 50.5 0 5 -3.51087
    15.37 15.26 50.0 0 5 -4.28722
    15.59 15.36 49.5 0 11 -5.5827
    15.50 15.42 49.5 10 1 -4.51083
    15.60 15.41 49.5 0 8 -4.51083
    15.59 15.49 49.5 0 5 -4.9631
    15.67 15.57 49.5 0 11 -4.06144
    15.70 15.56 49.5 0 11 -4.06144
    15.75 15.57 49.5 13 7 -2.80207
    15.71 15.56 50.0 0 7 -3.45246
    15.65 15.53 50.0 0 5 -2.77983
    15.67 15.57 50.0 0 5 -2.59904
    in this data you can see that even wily KW is going in to the Battery all the time
    and the min and max V are going up
    SOC is going down
  9. JC91006
    16,933
    8,643
    Recently I've experienced a big swing in my SOC readings. Many of it actually seems like it's not even a correct reading from what I see on my MFD. When it's really hot out 90+ degrees, the car would show 5 or 6 blue bars but when the AC is running, the engine would kick in when the car is down to 4 or 5 blue bars. It doesn't even reach the bottom of the SOC meter before the engine kicks on. I'm not sure if this is showing weakness in the battery, where the readings that you can see are actually not the correct readings of the ECU that controls when the engine has to kick in to charge the battery.
    My car is reaching it's 150k miles warranty limit, it's at 145k miles now. I'm hoping if this is a sign of imminent failure to come, it would come before I drive my next 5000 miles.
  10. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    I have also experienced this in Gen 3 Prius with 90k km, it's not that obvious but enough that I noticed it even before I read this thread.
  11. Garvin
    That_prius_car how is your battery doing since your last post concerning the rapid drop in SOC? Any signs of trouble with your hv battery or did you get the hybrid battery charger?
  12. Garvin
    I cleaned the corrosion on the bus bar today but coming from a full SOC I still see a rapid fall off in SOC from about 5 or 6 bars down to 2 bars.
  13. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    Yep. I see this on a daily basis. 6 bars would last in EV mode at 35mph for a mile or more before dropping to 5 bars. Then from 5 to 4 within 15s and the engine kicks in to recharge. Sometimes it drops to 3 bars even while charging.
