Traction Battery Temps
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by flyboy09, May 7, 2016.
  1. flyboy09
    flyboy09 Junior Member
    Seymour Tennessee
    loud battery fan noise and rising battery temps are leading me to believe that i now have a commuter only vehicle, unable to safely navigate long trips. a 26 mile early morning commute with the engine link app and LYL® Elm327 WIFI Wirless OBD2 Car Diagnostic Reader Scanner Scan Tool reveals the following temps. return 26 mile trip reveals higher temps. thumb_IMG_3849 copy.jpg thumb_IMG_3850 copy.jpg
    just hate to breakdown 400 miles from home. are my assumptions warranted? thank
    52,776
    how many miles on her? have you cleaned the fan?
  3. JC91006
    16,933
    8,643
    I think you should just change the battery and you can continue without problems
  4. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    Lemme guess? You have a new toy this year? You didn't do this just prior to summer last year?
    Assuming the output you have is true to what Techstream and Torque Pro report, nothing to worry about AT ALL.
    Max fan setting is 6. It's LOUD.
    Here in AZ , those temps are pretty normal, and my fan will hit 5. You report 4. Those temps are in the high 40s to low 50s °C. Nothing the car can't handle.
    Don't be stingy with your A/C. Keep the interior comfortable. That's where the fan gets its cooling air. If you're trying to improve mpg by not running A/C, stop. You're hurting the battery.
    Look at your own numbers:
    65°F inlet, 104-113°F outlet.
    vs
    87°F inlet, 114-125°F outlet
    The cooling air is 22°F hotter but the battery is only 10-12°F hotter.
    Lastly, if you really wanna know the health of your HV battery, run the discharge test in my signature. If you can log the data with your reader, capture, SoC, Battery current and Min/Max voltages. You can actually calculate the capacity extracted.
    Steve
  5. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
  6. flyboy09
    Seymour Tennessee
    Update showing delta v...can this info reveal anything extra about high fan speeds?
  7. S Keith
    799
    329
    AZ
    2003 Prius
    No.
    Your deltaV is about 0.2V, which is typically fine.
    Again, is this a new toy for you?
    Looking at that second set of data, your cooling system might be compromised. Clean the fan.
  8. goldfinger
    535
    403
    Buffalo
    flyboy09, what year and how many miles?
    Can you read the block impedances?
    Is your battery's vent blocked by dog hair?
  9. uart
    uart Senior Member
    4,220
    1,212
    Australia
  10. S Keith
    799
    329
    AZ
    2003 Prius
