Traction Battery Troubleshooting and Revival
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by EV_Mark, Feb 6, 2020.
  1. EV_Mark
    EV_Mark New Member
    CT
    I bought a 2008 Prius two years ago, but it's been sitting, and now it starts, but the "triangle of death" is lit, as are the other indicators, and I can't shift it out of park, so I believe the traction battery might be toast. I let it run for a couple of hours in the hope that the battery might recharge, and I noticed that the internal combustion engine shut down periodically, so it almost seems like the batteries are charging, but I still see the indicators. Any suggestions on how to easily determine the state of the battery and how to recondition it if necessary?
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Welcome to PriusChat!!
    At a minimum you'll need a OBD2 scanner to retrieve the stored codes (DTCs), a hybrid compatible OBD2 scanner would be best.
    Many here use a "mini-vci" cable, and techstream (toyota diagnostic software).
    There are plenty of threads that can guide you thru reconditioning, try our advanced search feature while it still works.
  3. EV_Mark
    EV_Mark New Member
    CT
    I ordered an OBD2 scanner, so we'll see how it goes, thanks.
    SFO likes this.
