Traction Control Dangers and Engine Braking Savior
Discussion in 'Gen 2 Prius Technical Discussion' started by slvr_phoenix, Feb 9, 2007.
  1. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Silver Phoenix,
    Can you tell us what speed this drop out of regen braking occurs at? Maybe the slip causes the wheel to drop down to 7 mph rotation speed. Which of course would cause the Prius to do the normal switch to friction braking.
    In my previous standard car, I instincively would reduce brake coming to a stop, to feather the onset of static friction. Now I find I instinctively increase brake pedal pressure coming to a stop in aticipation of the change over to the much weaker friction brakes.
