Traction control light is stagnant. Fault code C 1290
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Uberfast, Jun 5, 2021.
  1. Uberfast
    Uberfast Junior Member
    76
    Oakland , ca
    2014 Prius v wagon
    Replaced tie rods. Drove car to alignment shop. Traction control light is now stagnant. Alignment was performed. Traction control light is still stagnant. Fault code C 1290.
    How do I reset traction control light.
  2. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    Check connections to wheel sensors.
  3. ChapmanF
    19,034
    The code is about the steering angle zero point. First make sure the alignment is reasonable: is the steering wheel well centered when driving straight ahead, 22 mph or more?
    If that's ok, do a clear and relearn of the yaw rate and acceleration sensor. The steering angle zero point ought to be captured correctly after that. If it still can't be, there could be a contributing problem with the wheel speed sensors (the ECU won't believe you're driving straight, if it thinks the wheels are turning different speeds).
    Tim Jones likes this.
  4. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    How can I reset the acceleration sensor and yaw sensor
  5. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    I know that the aliment shop can set the steering wheel straight.
  6. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    Thank you for your help
  7. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    I just connected the obd reader and reset the code.
    Hope this works.
    Let me know what you guys or gals think
