Traction Control On When Switching from Reverse to Drive?
Discussion in 'Gen 3 Prius Main Forum' started by kevelev, Jan 29, 2018.
  1. kevelev
    kevelev Junior Member
    65
    ny
    2011 Toyota Prius II (non plug in). Car has about 90,000 miles on it. I noticed the last few weeks that occasionally when I switch between reverse and drive, the traction control light comes on with a beep, and travel is halted for a brief period, even when I let off the brake. Then it goes away. This is even on dry, level pavement (although it is winter in NY). Any idea what could be the cause? The only thing I can think of is that maybe I switch between R and D too quickly. I've heard of people having trouble with T/C on the Prius but is this one of those issues? Thanks!
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    First thing to come to my mind is a faulty wheel speed (Hall) sensor. Perhaps it could also be corrosion in the wire harness connectors. To start off, I would check all of those connectors and make sure that the wheel reluctors are not covered in rust and dirt. Clean everything up and go from there.
  3. ChapmanF
    19,025
    Nitpicky point, maybe, but Hall effect sensors are only one, rather specialized, kind of magnetic field sensor, that can be used for certain magical things like making current clamps than can measure DC. I think there are some in a Prius (in the accelerator pedal and the shift selector, at least), but I don't think the wheel speed sensors (or the crank, cam, or MG1/2 resolver sensors) actually use the Hall effect.
    -Chap
  4. BZzap!
    1,607
    878
  5. padroo
    padroo Senior Member
    2,763
    2,253
    Do you have any ABS Codes?
  6. orenji
    orenji Senior Member
    5,887
    3,489
    Could be a bad steering angle sensor. You will need to have Toyota check for codes that may have been picked up by the computer.
  7. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Are you sure that you have come to a full stop before shifting from reverse to drive?
  8. kevelev
    65
    ny
    Doing some more digging, it seems like hill start assist might be kicking in. I do hear a beep, and when I let off the brake, it takes about 1 second for the idling engine to start rolling the car on its own, rather than the instant I let off the brake. What do you guys make of this?
  9. Bill the Engineer
    1,048
    2,278
    467
    Pressing on the brake pedal too hard while at a stop can trigger this. Sounds like the answer. Try not mashing so hard on the brake after the car has come to a stop.
    scona likes this.
  10. kevelev
    65
    ny
    Yeah I started trying to lightly press the brake and the issue seems to be gone. The reason I was pressing hard was because at first I thought I switched between R and D too fast, so to make sure that I came to a complete stop I gave it a firm, but slow pedal press. But that's what actually caused the problem to begin with. Thanks!
  11. BZzap!
    1,607
    878
    Here’s what you do to prevent your light from coming on.
  12. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    I haven't dealt with the ABS/wheel speed sensors on either of my Prii, but unless they're different than other cars, they are indeed Hall Effect Sensors.
    HES's are also commonly used as Crank Position Sensors for timing purposes in internal combustion engines.
  13. padroo
    2,763
    2,253
    This video may be a good place to look.
    A visual inspection is always a good place to start.
  14. ChapmanF
    19,025
    The Toyota manuals are pretty explicit about identifying which sensing technology is used for each application in the car. For example, the 2004 (Gen 2) New Car Features manual covers the use of Hall sensors in the shift position sensor (page CH-13), the shift control actuator (CH-16), and the accelerator position sensor (TH-38). The MG1/2 resolver sensors use a simpler technology (ordinary coils, one fed by an AC signal, the other two picking it up off the oval rotor; page TH-29). The cam and crank sensors are plain pick-up coil type (page EG-19). The steering torque sensor with its coils is described on CH-78.
    The wheel speed sensors don't seem to be detailed in the New Car Features manual (maybe they weren't a new enough feature?) ... but for Gen 1 anyway, they can be seen in a clear diagram on page DI-366 of the 2001 repair manual. Plain pickup coils again, showing the sinusoidal waveform you'd expect, and a simple resistance test between the two coil terminals.
    It's clear why they would use Hall sensors for the accelerator pedal and shift selector; after all, those sensors have to accurately read the position of a magnet, even when the position isn't changing, and for that you need the Hall effect. The other applications like wheel speed and crank position all have a toothed disc happily spinning away in a magnetic field, and nothing would stop you using Hall sensors for that if you just had them lying around, but you certainly don't have to, as a plain coil and permanent magnet can do that job.
    -Chap
    kc410 likes this.
  15. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    Doggone it Chap, I'm not even done with my first cup of coffee this morning and you've made me go and learn something! :)
    My knowledge of Hall Effect Sensors is limited exclusively to automotive/motorcycle applications -- used to sense position of the engine for timing and fueling purposes, and to sense the position and speed of wheels for ABS.
    Your post made me Google "Hall Effect" which led me to Wikipedia and a fascinating read on Hall Effect Theory.
    It seems the use of Hall Effect in the automotive world is about the simplest use of the theory -- a bianary, "yes or no" to determine the position and/or speed of a rotating object. I had no idea about the more sophisticated applications.
    I'm going to take the rest of the day off. This thinking business is hard work!!:X3:
    kc410 likes this.
  16. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    My 2011 (prius II) 128K had the traction control come on during driving on steady roads no bumps, a few times a week, every now and then. I had the original factory 2011 battery back then.
    After I changed the 12v battery the issue seemed to go away but it did happen one or two times in a year now.
    I wounder if my old 12v battery would go down in voltage and trigger my traction control for some unknown reason.
    I never continued to troubleshoot this since it's almost all gone with the new battery.
    I just assumed since it was electrical, the new battery helped put all the sensors and electronic devices back to where they should run at.
    If you still have that old OEM 12v battery a new one could help.
    my2cents.
    #16 rrg, Feb 3, 2018
  17. ChapmanF
    19,025
    I think I needed to learn something too. Gen 1 and Gen 2 manuals show speed sensor waveforms that are sinusoidal and get closer together and taller with increasing wheel speed, as you'd expect for simple passive magnetic sensors.
    In the Gen 3 manual, the waveform illustrations have changed, to square pulses that get closer with speed but have constant height, because starting in Gen 3 they really are using some kind of active sensor like Hall effect. And this thread's in the Gen 3 forum, so that was right all along, and it was my bad for taking the thread on a detour. Live and learn. :)
