Traction control warning light & beep suddenly more senstive, goes off more often
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Equalizr, Jul 30, 2025.
  1. ChapmanF
    18,186
    The magic smoke went out of my Techstream laptop a while ago and I haven't rebuilt it yet, so I've been using an Autel AP200 lately. But I haven't checked whether the Autel can access the ABS History ... I definitely haven't stumbled on that option while using it.
  2. Equalizr
    Equalizr Junior Member
    I ordered a cable from Amazon that I can obviously always return I'll play with the software on the weekend and see what happens but thanks for all your help
  3. Equalizr
    So you had it running on the laptop at some point ?
    was it hard to do im a computer guy for the last 40 something years
  4. h1ph0panonymous
    258
    36
    You will have to take the rear wheels off to check connector to the rear wheel hub ABS speed sensor connection and wires, might as well spray the connector terminal with some electrical cleaner while you’re at it, for the fro wheels you can probably get by turning the wheels to open up the wheel well area. I haven’t messed with tech stream ever so Chapman can lead you from there.
  5. Equalizr
    Great I'll see what happens tomorrow I have a 26 Mile Drive 13 miles each way not the smoothest of Roads so I'll keep an eye on it maybe check it this weekend I've got some deox cleaner.
  6. ChapmanF
    18,186
    Some people get Techstream from Toyota and obtain an activation code from TIS (good for 2 days or a month or a year)—the official way. That shouldn't have many surprises (though I heard they are phasing out, or have phased out, the old Windows Techstream in favor of new Global Techstream+, which may be a whole different ball game I haven't used). When you go the official way, the surprises should be few, and Toyota support should be available if you get stuck.
    Others get Techstream from an unofficial channel, and there will usually be some instructions and oddball steps for getting it to work. From what I've read over the years, the details differ by version and by the source of the unofficial package. The one on my defunct laptop was set up so long ago that the versions available now may have rather different setup procedures. If you're a computer guy you can probably get through the instructions with the package. Of course Toyota support won't be an option, but some help might be available from whoever supplied the package you got.
  7. Equalizr
    Thanks I know completely what you mean about other sources I'm toyota charges a lot of money would be my guess even for a month or whatever they provide
  8. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Another one for the quotes archive.
  9. Equalizr
    Not exactly sure what you mean?
  10. ChapmanF
    18,186
    Grit keeps an archive of favorite PriusChat quotes.
    I can't tell what part of that whole quote made it a favorite for Grit.
    I liked the "32 bit version of Windows 10 that I will insult tomorrow" part. If you need any help insulting Windows, I'll be happy to pitch in, too.
    BiomedO1 likes this.
  11. BiomedO1
    BiomedO1 Senior Member
    3,600
    1,861
    SacTown, Ca
    tisk,tisk, tisk; you guys don't have an OEM version of Win95 laying around????:love::D:p A must have for running legacy software and diagnostic routines.
    @Equalizr you got the same size tires on your car or are any of them different?
  12. Equalizr
    I did but I got rid of them all but I have a side I can get to to find it tires are all the same have correct air pressure was checked drove my 13 miles this morning no beeps or flashes
