Traction Control
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rgevans871, Jan 1, 2016.
  1. rgevans871
    rgevans871 Junior Member
    16
    Michigan
    Is there a way to turn off Traction Control on a 2012 Prius? It's not a help when trying to break a path thru heavy wet snow. I've looked in the Owners Manual, but so far haven't found a description of deactivating Traction Control.
    Ron.
  2. frodoz737
    frodoz737 Top Wrench
    4,807
    2,561
    33
    Should work on your 2012.
  3. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    These steps must be completed within 60 seconds.
    Step 1: Set the ignition switch to ON, not READY.
    To do this press the power button two times, without pressing the brake pedal.
    Step 2: While the transmission is still in park (P), fully press the gas pedal two times.
    Step 3: Apply the parking brake to ensure that the vehicle will not move during this step.
    Put the transmission in neutral (N) and fully press the gas pedal two times.
    Step 4: Put the transmission back in park (P) and fully press the gas pedal two times.
    The car will display “!Car!” in the upper left corner of the LCD screen.
    Step 5: Press the brake pedal and turn the ignition switch to the start position, without going back to the ready position, to start the engine.
    If these steps are followed correctly, the vehicle will start with the traction control system defeated.
  4. rgevans871
    16
    Michigan
    Thanks for the instructions. Do you have to reverse the process to reengage the traction control? A simple switch would be nice.
    Ron.
  5. qdllc
    qdllc Senior Member
    1,377
    400
    That says it all. You wonder why Toyota doesn't have an Ice/Snow button to let you temporarily turn off or desensitize the traction control.
    My guess is that it's effective until you cycle power off...which makes sense.
    #5 qdllc, Jan 6, 2016
  6. Cloude1
    Cloude1 Junior Member
    23
    Sydney NSW
    If these steps are followed correctly, the vehicle will start with the traction control system defeated.[/QUOTE]
    Don't quite understand Step 5. How does one turn the ignition key to start?
  7. fjpod
    fjpod Member
    419
    72
    New York
    Don't spin your wheels too much. You can burn out the electric motors. This is why Toyota made it difficult.
    ...But I thought the procedure was:
    1. Roll the right front passenger window up and down three times
    2. While the window is halfway down on the second cycle, turn the radio on and off twice.
    3. Then get out of the car and hop all the way around the car on your left foot
    4. Get back in and put on a rap station as loud as you can while holding the lock button on the armrest.
    5. Look around to see if anybody is staring at you.
    frodoz737 likes this.
  8. Former Member 68813
    3,524
    983
    US
    even in a conventional car you can ruin a tranny by doing this or even put the car on fire (as reported on news recently).
