Traffic jam assist
Discussion in 'Gen 5 Prius Main Forum' started by GREEN BAE, Jan 9, 2024.
  1. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Same thing, different name.
    That's the DRCC's normal resume time. The extended resume time lifts that time from a few seconds to around 3 minutes, same as TJA. But it doesn't have the hands-off ability of TJA.
    Maxwell61 and purplePriii like this.
  2. GREEN BAE
    GREEN BAE Member
    61
    49
    Winter Garden, Florida
    2024 Prius Prime
    XSE
    DRCC and LKA are enabled as is TJA. Maybe I've just not encounter the ideal situation of under 25 mph and stop and go. I use DRCC and my cruise control all the time and it's great.
  3. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    Try any road with your speed under 25 mph and both the DRCC and LTA (not LKA) turned on (not just enabled), and see if you get a hold-the-steering-wheel warning. If not, the TJA is working.
    In my 2021 Prius Prime Limited, it works, except that you need to hold the steering wheel. Therefore, it cannot be considered to be TJA.
  4. Will B
    Will B Active Member
    454
    419
    Denver
    2023 Prius Prime
    XSE Premium
    Thanks @KMO ! While annoying TJA is tied to a working nav subscription, your explanation about why makes sense.
    will
  5. purplePriii
    purplePriii Active Member
    275
    123
    Try calling it through the Toyota Assistant at low speed. It will have a different animation screen on the dash if it's on.
  6. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    In other regions with only the "DRCC extended resume time", that's tied to working navigation. So you need either the built-in navigation or a subscription. All European cars have built-in navigation (possibly for the benefit of the speed limit alerts), and it's optional in Japan.
    I believe TJA is only available in the US, and no US cars have built-in navigation, so we don't know if that could work without a subscription if you didn't need a subscription for navigation.
  7. Maxwell61
    Maxwell61 Active Member
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    Does it means that a destination must be inserted in the navi, or simply that DRCC ext uses the navigation in shadow mode?
  8. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    In "shadow mode". The only function I'm aware of that needs a destination set is the Predictive EV Drive.
    Maxwell61 likes this.
  9. Maxwell61
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    double
    #29 Maxwell61, Jan 22, 2024
  10. Maxwell61
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
