Trailer hitch
Discussion in 'Gen 3 Prius Main Forum' started by attyjeff, Apr 10, 2013.
  1. attyjeff
    attyjeff Member
    153
    40
    Ok I have searched through a few threads on here and not really sure I have an answer ( or one that I like ) I have a 2012 prius hatchback, I would like to add a class 2 hitch because most of my accessories have class 2 receivers, I do NOT plan on towing a lot or heavy items, just bikes or a kayak. I have also seen the conversion you can connect into a class 1 to a class 2 but usually they are a pain. It also looks like my options may only be class 1. any thoughts?
  2. retired4999
    2,652
    625
    Eau Claire, Wi.
    Check Curt Mfg. I think they have a 2" Resize of 007.jpg Resize of 008.jpg Resize of 010.jpg This is on my 2012 plug .
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    U-Haul: Towing glossary
    I am not sure you mean Class 1 or Class 2, I suspect you mean 1.25 inch or 2 inch.
    Torklift Central - Toyota Prius Trailer Hitch|EcoHitch|Seattle|Kent|Auburn|Puyallup|Tacoma|Renton|Covington|Sumner|Bellevue|Burien|Enumclaw|WA
  4. attyjeff
    attyjeff Member
    153
    40
    oh sorry I assumed class 1 was the 1.25 and class 2 was the 2, but thanks
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Torklift sells both 1.25 and 2 inch, but they are all class 1 hitches. Since Toyota advises you not to tow at all, there is no point in pretending you can tow over a ton.
  6. attyjeff
    attyjeff Member
    153
    40
    ooooh ok I got ya, thanks.
  7. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    Since you're not towing, the load on the tongue is the only factor. Keep in mind it gross weight so include the rack and load. Though my road bikes are only 15lbs, the rack itself is like 60!
  8. mnsweeps
    mnsweeps Member
    108
    16
    Los Angeles CA
    I have a 2012 Prius and I got a class 1 Reese (ordered from amazon) and installed at UHAUL for $30. Like you I only tow bikes. So class 1 was more than enough. I have ordered the SWAGMAN xtc 2 RACK which works for both 1.25 and 2 in receivers.
    Amazon.com: Swagman XTC Cross-Country 2-Bike Hitch Mount Rack (1.25 and 2-Inch Receiver): Sports & Outdoors
    I have a 2007 HiHy which has a Curt class 2 hitch which has a 2 inch receiver.
    So the Swagman comes with 1.25 and 2 in adjustment on the rack itself and will fit both my Prius and Highlander receivers. I had a 1.25 to 2 in receiver adaptor which I returned back to amazon as it was wobbly and rattles a lot. Plus like someone mentioned having a adaptor reduces the tongue weight limit by 50%..
  9. Sfcyclist
    1,621
    375
    SF, CA
    I think the main concern is the leverage of the load since it's now extended out further due to the adapter.
  10. 916Prius
    916Prius Junior Member
    30
    I have the same swagman and it kicks butt for my bikes. I used it with my G35(soon to be gone) ...so I need a new tow hitch...most likely a Curt with a 1.25.
  11. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    I have the 4-bike version I use on my van and it is pretty nice. I like it much better than the hanging styles. It can be a little tricky to get all of the bikes lined up so they fit nice, but it's not too bad. I would love to put it on my Prius, but the rack + bikes would be getting close to the max tongue weight of the receiver (2" ecohitch if I go that route). I'm concerned about the leverage of the load on the cars frame as it sticks out a good 4' or so.
  12. Sfcyclist
    1,621
    375
    SF, CA
    You're concerns are valid with 4 bikes! That's a lot of leverage! The 2" ECO-Hitch has the same capacity as 1.25 model, both are class 1 with max tongue weight of 200lbs.
  13. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    Any 4 bike racks that I wouldn't have this issue with?
  14. Sfcyclist
    1,621
    375
    SF, CA
    Basically it's the total weight or load. The other factor that comes into play is the leverage if the rack extends out. So the only ways to control this is minimize the load which can be with lighter bikes and shortest rack as possible.
    My rack is 55lbs and bikes are under 18 each so I'm no where near the capacity. I'm not even half way. Even with my heaviest bike, 28 pounds, I am still barely at 50% of rating. BTW, all ways load heaviest bike closest to car.
    In the end, you may be ok with your 4 bikes. I am sure they calculated it with a safety factor...
  15. GeekAtLarge
    GeekAtLarge Junior Member
    Alexandria, VA
    I think you are referring to a class 1 hitch with a 2" receiver, not a class 2 hitch. The difference is that a Class I hitch has a lower tongue weight rating, usually 200 pounds and a lower towing rating, usually 2,000 pounds. A Class II hitch usually has a tongue weight rating of 350 pounds and a towing rating of 3,500 pounds.
    If you plan on carrying light-weight platforms on a 2-inch hitch, it can still fall under a class 1 designation.
    I plan on carrying 2, 80-pound ebikes and an ebike platform bike-carrier on my 2012 Prius, and that means I want a class 2 hitch with a 2-inch receiver, but no one makes a class 2 hitch for a Prius. Apparently, the Prius cannot handle the tongue weight. I could probably transport a single 80-pound load with a bike-carrier, but not 2 ebikes on the same carrier on a Prius. This makes me sad. . .:cry:
