Trailer hitch?
Discussion in 'Prime Accessories and Modifications' started by MikeDee, Nov 16, 2016.
  1. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    Is there a trailer hitch for the Prime? I need it for my platform bike rack.
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    In some regions you can't even get one for that.
  3. Mister MMT
    Mister MMT Active Member
    285
    142
    Germany
    One of these regions is Europe. I have it officially from two sources within Toyota.
    Jan
  4. MikeDee
    1,581
    597
    It's a deal killer for me if I can't install a trailer hitch.
  5. Andrew May
    Andrew May New Member
    Orange County, CA
    The dealer seemed to think the Prius liftback hitch would fit, but I called Draw-Tite and they said it might not. Yeah, it's a problem. I don't want to buy their $320 cross bars due to the wind noise. I either do that or wait for someone to release a version for Prime. My local installer was going to call Curt and ask them. I'll see what they say.
    Oh, I emailed Toyota and their response was "We don't recommend you modify the vehicle". So why do they publish towing capacity for the Prius?
  6. DavidA
    2,349
    1,825
    Chicago western burbs
    The rear of the Prime is at least 3 inches longer than the GenIV hatchback. I would think that alone might mean the hitch for the GenIV wouldn't be a fit on the Prime.
  7. Trollbait
    12,825
    The gen4 Prius has a tow rating in markets outside of North America only. I started a thread about tow ratings here awhile back. The tl;dr is that regions have different tongue weight regulations for trailers. If limited to the tongue weight in the UK, a Prius tow rating there would be cut in half for the US.
    I haven't heard of the Prime having a tow rating at all, which would make sense. It is heavier than the Prius, and much of that extra weight is in the rear where the tongue weight of a trailer would be applied. FWD isn't has effective in towing as RWD, because the tongue weight is on the rear. That can shift the car's center of gravity back, decreasing the weight on the front axle, and could lead to lower traction for the drive wheels.
    In the case of hitch mounted bike racks, Toyota's no is CYA in North America. In Europe, such racks have additional legal requirements to meet, such as not blocking the license plate, and having lights if those are blocked, and they have to okayed by the insurance company. If the manufacturer says no to such hitch accessories, it is very unlikely an insurance company will okay anything.
    The undercarriage where the hitch mounts to is the more important factor. If unchanged, without anything in the way, then a gen4 Prius should mount to a Prime. If that test is passed, then it is a question of whether the different bumper blocks the receiver tube. Likely not since that part of the receiver hitch is the lowest point.
    Tube extenders are available, so the extra 3 inches of rear length isn't an issue if those other conditions are passed. In the case of bike mounts and such, an extender might not be needed.
  8. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    6) If your vehicle will be towing a trailer, load from your trailer will be transferred to your vehicle. Consult this manual to determine how this reduces the available cargo and luggage load capacity of your vehicle. (P. 321)
    Toyota does not recommend towing a trailer with your vehicle. Your vehicle is not designed for trailer towing. -Page 318
    Towing capacity
    Toyota does not recommend towing a trailer with your vehicle. - page 321
    Trailer towing
    Toyota does not recommend towing a trailer with your vehicle. Toyota also does not recommend the installation of a tow hitch
    or the use of a tow hitch carrier for a wheelchair, scooter, bicycle, etc. Your vehicle is not designed for trailer towing or for the
    use of tow hitch mounted carriers. - page 322
    Do you have a page of your owners manual that DOES list a towing capacity?
    Optimus PRIME and Mendel Leisk like this.
  9. Andrew May
    Orange County, CA
    The tow capacity I saw was for the Prius lift back. I haven't found one for the Prime yet. Thanks for all the responses. I might have to get the cross bars after all.
  10. MikeDee
    1,581
    597
    I'm thinking that after a period of time, Curt and Draw-Tite will come out with a hitch.
  11. IAPrius
    IAPrius Active Member
    120
    140
    West Des Moines, IA
    I have a trailer hitch for my Gen 4 liftback - a 1 inch hitch installed by Uhaul with no wiring was only like $200. I use it to haul bikes and it works great. I assume something will come out for the Prime soon.
  12. MikeDee
    1,581
    597
    I'm assuming that with the raised floor, I can still get my bike in there while waiting for a trailer hitch to come out, correct?
  13. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    I don't see why not. Height has never been an issue. My wife and I stacked our bikes inside once in the PHV. It worked fine.
    For me, I'll also be waiting for roof mount clips. In the meantime, I could see transport of the 2 kayaks to the lake 1 mile down the road as a toss-in-back effort.
  14. Rmay635703
    Rmay635703 Senior Member
    2,701
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    Make your own hitch
  15. Andrew May
    Orange County, CA
    I have a 58 CM road bike and it fits in the back with the wheels on. I just have to put it in handlebars first.
  16. MikeDee
    1,581
    597
    When I've put my bike in my gen 3, I always put it in back wheel first. Never tried it the other way. Seems like it's more difficult that way, though I have to try it.
    I sent emails to Draw-Tite, Curt, and etrailer. Curt said middle of next year. etrailer said they contacted both companies and they are looking for a Prime to fit check so they can design a hitch.
    john1701a likes this.
  17. john1701a
    12,840
    5,312
    58
    I have a Curt now. Love it. Will buy one for the Prime as soon as it's available.
    What's the email address for them? Each of us could send a request to make them aware of the upcoming demand.
  18. MikeDee
    1,581
    597
    I filled out a Web form on their Contact page on their website. [email protected] replied (Scott Bentley).
    iPhone ? Pro
    #18 MikeDee, Nov 23, 2016
  19. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Torklift Central | PriusChat is a user here on PriusChat. I have one of their hitches and am impressed.
    If you are near Seattle, I bet they would use your car as the template for the Prime.
  20. galenagal
    galenagal Junior Member
    24
    CA
    Any more news on putting a hitch on the Prime for attaching a platform bike rack?
