Trailer hitch?
Discussion in 'Prime Accessories and Modifications' started by MikeDee, Nov 16, 2016.
  1. Captmiddy
    Captmiddy Active Member
    225
    204
    Massachusetts
    I wonder if this item may work for the car. Not sure if it pushes out far enough but a rise adapter (flip it over) would be nice to give a little more clearance for bikes on the back of the car.
  2. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    I have a 1upUSA bike rack. It barely clears the back bumper. If I had installed the Curt hitch instead of the Draw-Tite, I would have needed a hitch extender. I am not familiar with other brands and styles of bike racks to offer an opinion on which ones work without an extender.
    twinprime likes this.
  3. galenagal
    galenagal Junior Member
    24
    CA
    Curt says
    It looks like you have the Curt 1.25" hitch and a 2"
  4. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    It's all 1.25"
  5. galenagal
    24
    CA
    I contacted eTrailer about a setup for two carbonfiber frame mtn bikes. They suggested the Curt 1.25" hitch (the only Prime specific) and Kuat Transfer 1.25" bike rack which has a 7-7/8" tenon which is 7/8" longer than the hitch hole-to-end-of-bumper which is too tight considering all the rattling that will occur. Yakima Holdup rack adds 2-1/2" but the tenon curves up soon and might hit the bumper. Others have mentioned that the 1.25" hitch and/or extender seems loose/rattly. Total weight I need to carry is about 95-100 lbs (rack plus bikes). Thoughts? Rspecially on an extender? How to make it more stable? Thanks.
  6. galenagal
    24
    CA
    oops, Not the Kuat Transfer but the Kuat NV 2.0 Base.
    Jon Senum likes this.
  7. Trollbait
    12,825
    @bwilson4web uses some simple wedges on his i3 hitch to tighten up the connections, and there products like this too.
    itsmejame5 likes this.
  8. bwilson4web
    16,533
    The installer called and it is taking longer than expected. They are keeping the car tonight so I rented a Jeep Cherokee, $22/day, from Enterprise, their next door neighbor. Now for my Jeep Cherokee review:
    "THE FUEL NEEDLE GOES DOWN WHEN YOU DRIVE IT!!!"​
    #128 bwilson4web, Apr 13, 2017
  9. galenagal
    24
    CA
    Thank you! Both are great ideas.
  10. bear15
    bear15 Member
    168
    36
    Suburban Chicago
    Yes, and quickly.
    HPrimeAdvanced likes this.
  11. bwilson4web
    16,533
    I turned it back in after refueling, 1.67 gal for 19.7 miles: 11.8 MPG. OWCH!
    I can't imagine thinking this is normal mileage for anyone. What got me is my first drive home, watching the fuel needle move. The good news, I'm back in the Prius Prime Plus and drove the rest of the day on EV ... with the receiver hitch and extension.
    Sad to say, the air conditioning at work broke down and the top, 5th floor got pretty grim. Huntsville tied the heat record set in 1925. I'm just now getting back to 'normal.'
  12. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    That is awesome MPG against my M 760 9 MPG in city normal drive AC on
  13. bear15
    bear15 Member
    168
    36
    Suburban Chicago
    Glad to hear you got your hitch and extension installed and you are back in your Prime Plus. Do you have a few pics?
  14. bwilson4web
    16,533
    #134 bwilson4web, Apr 14, 2017
  15. bear15
    bear15 Member
    168
    36
    Suburban Chicago
  16. galenagal
    24
    CA
    And you backed up to a curb! Very nice.
  17. MikeDee
    1,581
    597
    Nice. Did you use an anti-rattle device to prevent sway? Lock? Etrailer.com sells a combination lock and anti-rattle device.
  18. bwilson4web
    16,533
    I wasn't aware of them. I took a quick look and can see the merit. Certainly for the 1.25" receiver extension. So taking out the slack, instead of working like an impact hammer, the load become a solid piece. But I am still concerned about torque loads.
  19. itsmejame5
    itsmejame5 New Member
    Brea, California
    Finally!!! finished installing the hitch, bike rack, and the best part is that I ended up NOT needing an hitch extender.
    Everything went so smooth... until I found out that my bike rack is rattling like jingle bells after mounting. Any idea on how to fix the issue?
    Equipments used:
    (Purchased from etrailer.com)
    Curt Trailer Hitch Receiver Custom Fit - Class I - 1-1/4
    Thule Vertex 2 Bike Rack - 1-1/4 & 2 Hitch
  20. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    You'd have to identify where it's rattling first.
