Trans Fluid Change
Discussion in 'Gen 2 Prius Technical Discussion' started by PriusGuy32, Mar 22, 2014.
  1. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Today I changed my trans fluid on my 2007 Prius. The Toyota service history said "transaxle fluid service" or something to that effect around 50,000 miles at the dealer, 2-3 years ago. I now have 81,000 miles, bought it with 54,500 on it.
    Judging by the way the allen head drain plug looked, it had never been removed. And it was so tight it took myself and a helper to get it to break loose!! And Im no wimp - I have popeye arms and a breaker bar, lol. The fill plug looked the same way (never touched) but was much easier to break loose.
    The fluid that came out was not really dark at all, was probably very slightly darker than new stuff. So I almost wonder if it did get changed at 50k miles after all but maybe the dealer used another method to drain/refill it? My drain plug had just the slightest amount of build up on the magnet. It was so slight I almost thought there was nothing until I wiped it with a rag. :sneaky:
    Three questions:
    - Would a dealer use a suction device, or any other method to drain/refill the Prius transaxle? (that would explain the drain and fill plug that both look like a socket/bit never touched them)
    - Has anybody experienced an increase in mpg's after changing the cvt fluid? I drove it ~100 miles after, and my avg. mileage went up 1.5mpg's (y) I already had 120 miles on that tank, and today is colder than it has been. So I was really expecting a decrease.
    - I put it almost 4 quarts. I have maybe a 1-2 ounces left out of the 4th quart. Normal? I read on the site, people have recommended only putting 3.5qts back in.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Fill until some dribbles out.
  3. Mendel Leisk
    42,179
    with the car level.
    Maybe when the dealership did a change (and that would explain the not very dark colour), they used some sort of impact wrench to re-install the drain bolt?
    (3rd gen drain and fill bolts are both 29 ft/lb, they're identical, 10 mm hex socket head cap screw)
    PriusGuy32 likes this.
  4. PriusGuy32
    1,417
    514
    Heres what I did:
    I put the front end on ramps. The rear was still on the ground. I did this at first to prevent opening the fill plug and having fluid come out and making a mess.
    After I removed the fill plug, I then loosened the drain plug. THEN I went and jacked the rear end up. I jacked the rear end up higher than the front at that point. Then I went back and removed the transmission drain plug. I let the car drain like this, with the rear end slightly higher than the front for about an hour.
    I then lowered the rear end so the car was completely level. I added transmission fluid through a funnel and piece of clear tubing until I got to 3.75 quarts. I removed the hose - nothing dribbled out at that point. I did this 2 more times until I added most of the 4th quart. Finally, I was down to the bottom of the 4th quart, there might be 1/4 of an inch of fluid left at the bottom of the container. I figure I added almost all of the 4th quart until it started to dribble out.
    I then lowered the rear again, installed the fill plug, torqued everything to specs and went for a test drive :)
  5. Mendel Leisk
    42,179
    Too much raising and lowering, lol.
  6. JC91006
    16,923
    8,634
    The dealer would not use a suction device to make his work harder. Don't worry about what dealer might have done. You did what is necessary at a reasonable mileage. Your car should be perfect now.
    SM-N900P ?
  7. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    My worry was "Is a human ever under there when it is supported only by jacks?" I would insist on jack stands!
  8. PriusGuy32
    1,417
    514
    Well, the front was on ramps. I was under the front when I was loosening/tightening the plugs. Other than that, the rear was supported by a jack only. So if the rear fell, it doesnt really matter to me because Im not under the rear of the car :D
    And I dont mind raising and lowering the car a bunch of times - keeps the neighbors on their toes wondering if Im really crazy or not!! haha :confused: :LOL:
  9. Patrick Wong
    18,210
    6,517
    I am wondering how you expect a removed drain plug to look vs. one that was installed by the transaxle factory? I don't see why there would be any difference, if you are using the correct tools to remove the plug.
    Now that you've removed and reinstalled the drain and fill plugs, how has their appearance changed?
    Given your description of the drained ATF and the residue on the drain plug, it sounds like the ATF had been changed at 50K miles.
    The capacity is 3.9 US quarts so you put in the correct amount. 3.5 quarts would be insufficient.
    No reason for mpg to improve after the ATF is replaced unless the previous fill was overfilled. Since new ATF has higher viscosity as compared to used, if anything you would expect slightly worsened mpg.
  10. PriusGuy32
    1,417
    514
    Well, judging by the engine oil drain plug for example - you can tell a socket has been placed over the plug - you can see wear associated with two pieces of metal sliding over each other.
    After I removed the transmission drain plug, you can look at it and clearly tell it had been tampered with at some point now. However, before I touched it I carefully examined it by eye and it looked like it had never been touched. But hey, Im no metal forensic specialist or anything, and apparently I was wrong because it does appear the fluid was changed at one point, based on the condition of the fluid and the very little accumulation on the magnetic drain plug. I was just trying to hone up on my detective work and catch the dealership not doing something they billed the last owner for, thats all :D
    And as far as the mpg increase, I must be experiencing some kind of placebo effect - Im cool with that! (y)
  11. Patrick Wong
    18,210
    6,517
    What are the signs of tampering?
    Is the hex indentation within the plug's head slightly damaged? If yes, then that would imply that the 10 mm hex key tool is slightly too small.
    Or, are there some other signs? For example, a paint mark applied when the plug was tightened at the factory, which no longer lines up.
    I follow what you are saying with regards to the engine oil drain plug. That gets lots of use since it is removed every 5K-10K miles or so.
  12. uart
    uart Senior Member
    4,220
    1,212
    Australia
    I'm really not so sure you'd be able to tell whether or not it had previously been removed. Yes you might be able to see a small mark there on the hex indent after you've just removed it, but after it's been back in service for several years and there's a bit of oxidization, then probably not. To be honest, the condition of the fluid that you describe does strongly suggest that it was changed as per the service history.
    BTW. I changed mine for the second time a few weeks back, and I can tell you for sure that the drain plug is very tight to remove. The first time I removed mine several years ago I remember thinking "what idiot did this thing so tight". Embarrassingly however, I found myself muttering exactly the same thing just a few weeks ago when I did the second change. Now interestingly I used a torque wrench each time, so it definitely wasn't over tightened. I think it's just the type of thread that is a lot harder to remove than what it was to tighten. Mine also took all my "popeye" arm strength before suddenly "popping" free.
  13. PriusGuy32
    1,417
    514
    Thanks for all the feedback. I now know that the dealership did in fact service the transaxle and that just looking at the plugs arent a solid indicator of being previously tampered with.
    In the meantime, I am happy that changing the trans fluid is so easy. I dreaded the days when I would have to put my SUV up on ramps, chock the rear wheels, get under it and drop the transmission pan (but first removing 15 small bolts). I finally got it down to an art towards the end, I would siphon out the trans fluid through the dipstick tube with my mity-vac, and then drop the pan - little to no mess that way. In any event, my arms and hands would all be cramped and tired after from working laying on my back with my hands above my head trying to thread back in 15 small bolts. o_O
    The Prius was very straightforward (y) Ill change the fluid again in 30k miles or so, cheap insurance IMO.
  14. Patrick Wong
    18,210
    6,517
    Yes, it is very easy to do the Prius transaxle ATF change compared to most vehicles.
