Trans oil questions ( I know it's been talked to death)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by xerox6135, Sep 7, 2016.
  1. xerox6135
    xerox6135 Member
    170
    93
    michigan
    I have seen oil out of these gear boxes with 1,000 miles on it and the fluild is as dark as mine at 35,000 miles. So I guess my question is does Toyota use a different darker oil than what we are buying front the dealership.
  2. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    Perhaps there is an additive that darkens the fluid that results in Toyota's "lifetime" claim.
  3. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    same
  4. jdenenberg
    jdenenberg EE Professor
    3,852
    1,847
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My lab tests on Toyota WS ATF showed that there is an initial leaching of silicates into the ATF from the gaskets/sealants. Perhaps this is what darkens the ATF that we see in low mileage OE ATF samples.
    JeffD
    Rebound likes this.
  5. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
  6. xerox6135
    xerox6135 Member
    170
    93
    michigan
    Thanks for all the reply s I knew you would have the answers
  7. grnd0
    grnd0 Member
    42
    26
    I just did mine 2 weeks ago and old fluid looked really bad, at 52,000 miles. Got my WS on ebay.
  8. grnd0
    grnd0 Member
    42
    26
    Forgot, price for 4 quarts was $30 shipped.
    tankyuong likes this.
  9. xerox6135
    xerox6135 Member
    170
    93
    michigan
    Did mine at 36,000 looked very dark. Pulled a 2016 Prius out of the ditch with the wrecker and the oil leaking out was the same dark oil that was in mine just the 2016 only had 1,000 miles on it. Now I know color doesn't matter it's what the oil analyzation says. Different from a regular automatic trans because of no clutch material being in the oil
  10. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Actually there IS a single plate "clutch" in there. It just stays "engaged" (or should that be "released"?). Over-torque prevention device.
  11. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    link?
  12. Mendel Leisk
    38,726
    I changed mine around 15,000 kms and first year, found it quite dark. I did a second change around 40,000 km and third year: it looked still very clean, not that different than the new fluid.
    jdcollins5 likes this.
