Transaxle Failure
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dailyphotofix, Feb 26, 2009.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Wow! Great job! This is the result of Prius owners stick and work together. If something happen to my Prius out of warranty, I am not afraid to fix it myself! Thanks for all the inspirations.
  2. patsparks
    10,664
    569
    Adelaide South Australia
    Peter, just a little advice.
    On a big job like this it's a good idea after a week or so to slide under the car and recheck all the fasteners you can get to, just in case.
    I'm assuming you repacked the CV joint with the right grease?
  3. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    Just a big THANK YOU for posting the play by play of this job. Great pictures and documentation! Generous sharing of your experience adds much to the value of Priuschat as a knowledge source for all of us!! :)
    ANDRAS RIMELY likes this.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Again, fantastic work and we're all thrilled you chose to share this project with us.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Pat, you don't need to pack the CV joints. Transmission fluid leaks through the seals and fills the boots, and then dirt packs in there automatically.
    :D
    Tom
  6. patsparks
    10,664
    569
    I am buggered if I know how that can happen Tom.
    Yes I saw your smilie
  7. bwilson4web
    16,513
    Before opening up the transaxle, you might take a peek at some of the earlier work in this area. Florian over in "Prius Technical Stuff" disassembled a NHW11 transaxle and Hobbit has also done some work in this area. Also, there is Arts Automotive, a bit late but interesting no less:
    For my part, a couple of thoughts for the disassembly ... as you are able:
    • Where does 'debris' collect? - An oil change takes out the suspended debris but stuff that settles out will ordinarily seek a lowest point. Insights about where any other areas might be located, especially the differential area, relative to the drain and fill plugs would help. NOTE: you might consider the current oil a 'flush' and change it out after say 2-5,000 miles to remove anything that might have been left over.
    • What is the normal oil level relative to the moving parts and stators? - I'm pretty sure the differential is partially in the oil pool but I don't have anything that shows where that level might be relative to the differential gears. In theory, a lower level might further reduce the internal drag but cooling is also important.
    • High resolution, close photography of the leaking and non-leaking seals. I would expect them to be difficult to remove and would suggest taking out the 'good seal' first before taking out the one that failed.
    • Carefully check all teeth for evidence of a chip. One hypothesis is a tooth or part of the chain lost a chip, which was ground up into debris that destroyed the rest of the parts.
    • Check the coolant races for any 'gelled' material. Hobbit reported finding a gelled material in an inverter coolant race. If you find anything, having a sample for analysis would be great (PM and we can work out the details.)
    • The lubricant flow from the transaxle oil pump remains a mystery. Other than trying to force a colored fluid through and looking for where it seeps out, I don't know how to easily map the pump to outlets.
    These are just random thoughts and if you're able to deal with any of them, good. Whatever you report will be well received.
  8. Patrick Wong
    18,210
    6,517
    Regarding the throttle body and throttle plate, this accumulation of black gunk is normal. It appears those parts have not been cleaned since your car was new.
    The reason for this accumulation is the engine's use of Atkinson cycle where the intake valves remain open past BDC, so some of the fuel/air charge can move back into the intake manifold. A portion of the fuel/air charge includes previously combusted exhaust gases that remain in the combustion chamber after the exhaust valves close. The carbon deposits stick to the throttle body and throttle plate.
    You can use throttle body cleaner for this purpose. I have successfully used rubbing alcohol and Q-tips to scrub off the dirt.
    I'm also interested in hearing about the process you used to rebuild the axleshafts.
    Its really nice to see how you completed the repair, to note that you did not need to suspend the engine from above, and to hear that you felt the job would be made simpler with access to a transmission jack.
    Again, congratulations on the successful repair and we are looking forward to seeing your transaxle dissection when you get to that project.
  9. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I swear I wasn't in any way involved with those half dozen pat sparks'
    But there is that hazy night of heavy drinking .....
    Uh oh
  10. qbee42
    18,058
    3,081
    Northern Michigan
    After seeing these pictures, I have decided to stop driving my Prius, just to make sure I never need to replace the transaxle. ;)
    Tom
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    Peter:
    Sorry to report this is a normal part of Prius operation. I finally got around to cleaning my TB last fall on my Prius, no difference in operation
    With both my FJ and my Prius, cleaning the MAF is a better choice. This is the MAF in my FJ after only a year
    After cleaning
    The MAF guts after cleaning
    Cleaning the MAF made a huge difference in how my FJ auto shifted and how it ran. Little difference in the Prius
    That's weird. On my FJ, the rear axle fill plug is very easy to reach
    The dribble of gear oil is because I had checked the fluid level before taking the photo
    The front axle is a lot harder to get to, unless you remove the front skid plate
    An entirely normal feeling. Imagine a large petrochemical plant after major upgrades, and you're the Project Manager who is responsible for the startup. My butt had never puckered so much in its sad little life
  12. jayman
    13,439
    641
    Winnipeg Manitoba
    To really play it safe I'm going to hide in my basement
  13. qbee42
    18,058
    3,081
    Northern Michigan
    Clean it up, dry it off, and dip it in Cosmoline. That should do the trick.
    Tom
  14. ggarb
    ggarb Member
    86
    Silicon Valley, CA
    Peter,
    Thank you for sharing your adventure with us.
    It's been educational, it's been inspirational.
    /Gordon
  15. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Hey, it looks like, in IMG_7177.jpg, that the little blockoff plate
    is on the right way without that tab sticking out toward where the
    resolver harness will pass. Did it come like that, or did you
    flip it?
    Yes, this is only peripherally related, but something I noticed..
    _H*
  16. magruder
    magruder Average Member
    145
    Colorado
    Ok, dumb question of the day...So what Peter replaced was the transaxle along with the mg1 and mg2 that are all together in the same housing? He removed the inverter from the top of this housing and removed the axle shafts from the housing. Then he disconnected the transaxle from the gas engine so it could come out the bottom of the vehicle. Am I understanding this correctly? The transaxle cooling system cools the transaxle, mg1 and mg2 right?
    Thanks,
    Dave
  17. Patrick Wong
    18,210
    6,517
    Yes. The inverter cooling system also cools the transaxle, and MG1 and MG2 live within the transaxle case along with the power split device and the differential gearing that drives the axleshafts.
  18. dailyphotofix
    dailyphotofix Junior Member
    Portland, Oregon
    Yes! Thank you for that advice. I was planning on doing that, which is also why I left the engine covers off this week so I could keep an eye on everything.
    Yes, I have had my eye on Art's since the beginning of this project. I will be sure to answer all of your questions as soon as I have the transaxle opened up.
    I will be cleaning the throttle body this week...so I will probably post some photos of it all clean along with the transaxle dissection when I get a chance.
    Haha! Seriously...I am afraid something else is going to brake now.
    Yeah, I had to clean the MAF quite a few times when I had my 99' tacoma.
    I am sure they changed the axles between the 99 tacomas and all the new ones, which is probably why my fill plug was in such a weird spot.
    Interesting...I actually did not pay attention to the way the plate came off and that's the way it made the most sense when replacing it. I guess its a good thing then huh!
    Yes, the "transaxle" is considered the mg1, mg2, and the sun gear all combined into one unit...and yes you are understanding it correctly. The cooling system, to my understanding is for the Inverter more than the transaxle, but I am still not exactly sure how it all works...I will be able to tell you in a week or so when i have it torn apart!
    I guess that answers the question of how the cooling system works! Thanks!
    By the way. The Prius is still running great. I topped off the fluid in the cooling system yesterday.
  19. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Would you be kind to do a write up to check and clean the throttle body? I don't believe we have a "How To" guide yet. I am sure many are itching to check how dirty theirs are.
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    What? Do you have any idea what Cosmoline would do to soft, sensitive skin .... oh, wait a minute.
    :rolleyes:
    You're talking about something else. Never mind ....
