Transaxle Fluid Change DIY?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by eric1234, Jul 12, 2016.
  1. eric1234
    eric1234 Active Member
    392
    201
    Hamden, CT
    Also, this car is loooowwww to the ground. I have a set of ramps that I've used in the past for oil changes, and they always provided plenty of room for oil changes.
    For the 2016, that underbody covers are lower, providing very little room to maneuver on my mechanics creeper. (Either that, or, I've gotten a bit wider in girth...)
    RCO and krmcg like this.
  2. krmcg
    2,592
    2,393
    Whittier, CA
    I bought these low profile ramps from Amazon (my car has been lowered by about an inch)
    #22 krmcg, Sep 8, 2016
    thatoneraccoon and RCO like this.
  3. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Ramps alone aren't good for the tranny fluid change because you need to also raise the rear by the same amount.
    One way to keep the car level is to begin by putting a piece of painter's tape on the car door and taping a bubble level to it. Of course you don't need precision accuracy but you want to get in the ballpark.
    RCO likes this.
  4. krmcg
    2,592
    2,393
    Whittier, CA
    That's why I bought two sets...
    RCO likes this.
  5. Rebound
    3,996
    2,645
    Portland, OR
    Have you used them yet? Did they all fit? Was 3" of lift enough?
  6. krmcg
    2,592
    2,393
    Whittier, CA
    No. not yet.
  7. Rebound
    3,996
    2,645
    Portland, OR
    For me, 3" wouldn't be enough. I had a Sears floor jack for a decade, and I finally replaced it with a real floor jack from Harbor Freight which has two feet of lift. I can practically walk around under my car now. It's huge -- weighs 100 pounds -- and cost about $200. Jack stands extra. But it makes car work a lot easier.
    Raytheeagle likes this.
  8. krmcg
    2,592
    2,393
    Whittier, CA
    Because my car is lowered 1" I have to drive it onto the ramps to get my Harbor Freight Floor Jack underneath. I am not interested in performing my own fluid maintenance.
    RCO likes this.
  9. Rebound
    3,996
    2,645
    Portland, OR
    Oh!!! I was trying to figure out the point of 3" ramps
  10. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Any pics of your Prius in the air?
    Sounds like a great setup:)!
  11. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    I hope you're putting the car on stands?
    Our other car is an '05 outback....no need to jack it up unless I'm doing brake or suspension work.
    My Prius - need to put it on stands to change the oil
  12. Mendel Leisk
    42,379
    I like safety stands, plus a squat tree trunk section pushed under, near the centre, as a backup.
    RCO likes this.
  13. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Rebound did mention jack stands as a complement to the floor jack. Yes, a safety must!
  14. Jimi1976
    242
    124
    Denver, CO
    Correct. Also mentioned lifting it 2 ft.....which most jack stands will not extend to. Climbing under a car that is jacked up to 2 ft with no jack stands is no joke dangerous- just pointing it out.
  15. Mendel Leisk
    42,379
    Max height of the jack is 24", that doesn't mean the car is raised that much, more like 18"~19", due to the lift point being about 6" clear. 6 ton jackstands will just be up one or two notches.
    I would heartily recommend NOT using the scissor jack locations; there's more substantial and stable bearing points, at the leading edge of underbody structural rails.
    RCO likes this.
  16. Mendel Leisk
    42,379
    Some pics, my jack has an advertised lift of 21", measured no-load lift recently, it was about 20": The pictured safety stands are 6 ton, fully retracted, have height to top of cradle is around 15".
    RCO and Raytheeagle like this.
  17. Rebound
    3,996
    2,645
    Portland, OR
    I won't get under my car without jack stands. I haven't tried my stands with my new jack yet, so I don't know if they'll need upgrading. But the jack stands go closer to the center of the car than the jacking point, so they don't need to be quite as high as the jack's 23 inches. We'll see how it goes, but I'll definitely lift it higher than before.
    I've been traveling on business so no car playtime.
    Mendel Leisk, RCO and Raytheeagle like this.
  18. RAM v
    RAM v Junior Member
    72
    St. Paul, MN
    2014 Prius v wagon
    I did my ATF change yesterday at 30K miles. Went OK except for tight quarters as my 4 ramps were only 3" high. Did the funnel and hose fill method. I put the first 3 quarts in and then added the 4th slowly until it started to dribble out into the drain pan.
    Fluid was a bit dark (reddish-brown instead of pink) so I'm glad I did this 'early' change.
    JimboPalmer and Mendel Leisk like this.
  19. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    RAM v I really do recommend 30,000, then 90,000, then every 90,000. 30,000 will still be the darkest.
  20. RAM v
    RAM v Junior Member
    72
    St. Paul, MN
    2014 Prius v wagon
    Yeah, that's why I decided to do mine at 30,000. Glad I did.
