Transaxle fluid... to change or not
Discussion in 'Gen 2 Prius Technical Discussion' started by Loanshark, Jul 7, 2016.
  1. Loanshark
    Loanshark New Member
    Indianapolis
    I have a 2008 Prius with 170,000 miles on it , I don't believe the transaxle fluid has ever been changed. What's the consensus should I change it or not?
    thetuningspoon likes this.
    52,773
    sure, why not.(y)
    Loanshark and Mendel Leisk like this.
  3. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    Probably a case of better late than never, but who knows how much longer it will go on a fresh batch.
    Loanshark likes this.
    52,773
    agreed. it's worth a shot. at least it will remove all the crud that's built up over the last 8 years.
  5. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Easy peasy DIY, go for it.
  6. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    My understanding is that you don't have to worry about changing trans fluid in the Prius at high mileage. Unlike traditional automatic transmissions, our trans does not have clutches to worry about. You should be fine.
  7. jadziasman
    1,355
    488
    District 6
    ATF lubricates the gears in a "traditional" automatic transmission - not the clutch(es). The Gen 2 Prius e-CVT has gears in its single planetary gear set. The transmission fluid performs two functions - reducing friction and transporting worn metal from the gears to the magnet attached to case. There is no transmission fluid filter inside the Gen 2 Prius transaxle.
    Eventually the trans fluid degrades due to thermal decomposition (it does get hot - there is no ATF oil cooler in a Gen 2 Prius) and due to debris particles that cannot be entirely drawn out by the magnet. Will this cause transaxle failure after 300K, 400K, 500K miles? I don't want to be a guinea pig. I change the ATF-WS in mine at least every 100K miles.
  8. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Some part of the old wives tale about not changing the ATF in high mileage transmissions is the hydraulic logic array called the valve body.
    Disrupting the old fluid can cause blockages in the tiny valve body passages and the transmission works differently, almost never better. (think Stroke in the brain)
    The Prius logic is electronic, it has no valve body so there are no tiny passages to clog. It is always safe to change ATF in a Prius.
    NORMAL POPS, Loanshark and johnnyb588 like this.
  9. Loanshark
    Indianapolis
  10. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    do not use anything other than 4 quarts of genuine Toyota WS fluid.
    Sonic_TH and Loanshark like this.
  11. Tboy160
    Tboy160 Junior Member
    27
    Flint, MI
    I have
    2008 Prius 316,000. 220,000 when acquired
    2009 Prius 341,000. 190,000 when acquired
    I'm just reading about changing the trans fluid.
    Guess I have some work to do.
  12. ETC(SS)
    7,496
    Loanshark was last seen:
    Sep 11, 2016
