Transaxle fluid
Discussion in 'Gen 2 Prius Technical Discussion' started by magruder, Jan 27, 2010.
  1. Patrick Wong
    18,210
    6,517
    Hi Dave,
    We're all "behind" you! ;)
    (I recently bought another case of Toyota ATF WS, 8 quarts remain in the box after changing the transaxle fluid in my 2004 a couple of months ago.)
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Good post. Redline D6 has slightly higher visc then WS (WS being very low visc) and I did take a slight mileage hit but I reasoned it with the car being subjected to very high ambient temps daily so I wanted a better GL-4 lubricant in there.
    Last summer here in Florida was brutal.
  3. triumph1
    triumph1 Member
    275
    After I changed to D6, I got the best single tank MPG I've ever had, over 62mpg. Since then, mileage is as good or better (as with the WS), don't notice any real difference in performance. I'm going to keep it in for 40k, the Oem fluid was definitely done after 31k. I'm shocked at the notion that WS is anything special, hell, its not even synthetic.
  4. edthefox5
    10,096
    4,837
    Clearwater, Florida
    I was trying to be forthright but not sure if I was approaching winter or the visc but went from 47.5 to 46.5 there for a while.
    Thought it was a tradeoff for the visc increase but lately I'm back to 47 so who knows. I do know the car runs perfect and I have a superior GL-4 lubricant in there.
  5. Sammydog
    Sammydog Junior Member
    Seattle
    It's now been 9 years since this post regarding using standard high-quality Synthetic ATF, so long I believe the new standard is GL-5. :)
    Any updates EDthefox5 or Magruder on the 'experiment'? How many miles do you have on those transaxles using a high-quality synthetic ATF? I use synthetic fluids is all of my cars/trucks and Yamaha 200hp 4 stroke boat motor and would like to use synthetic ATF in my 2007 182K Pruis.
    Thank You!
  6. Mendel Leisk
    42,272
    So, a scam where they caution against using alternate fluids, and say the factory fluid will be good for the life of the car? I don't see them getting rich with that.
    And up here at least, I can buy Toyota ATF WS, for $9.14 (CDN) per liter. Ah but it's an inferior product, always a catch.
  7. edthefox5
    10,096
    4,837
    Clearwater, Florida
    140,000 miles and 12 years going strong.
    m.wynn likes this.
  8. Mendel Leisk
    42,272
    Maybe some alternate fluids are ok. Maybe they all are. Who knows.
    Still, I don't see any upside to gambling on this.
    m.wynn likes this.
  9. will the engineer
    will the engineer Active Member
    238
    119
    LA
    2019 Prius Prime
    well all I can say is when you go against what chemist or engineers say/reccomend...you are decreasing your "factor of safety"
    like mentioned higher temps
    lower life expectancy
    we all can wag our fingers but at the end of the day you'll do w/e you want
  10. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Wow. I'm amazed there are still paranoid posts about transmission fluid that specs compatibility with Toyota WS and has excellent wear analysis posted online and good testimonials from those that use it.
    Mr "Engineer" Where is your data?
    #30 mjoo, Jun 28, 2019
  11. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Who mentioned higher temps or lower life expectancy?
  12. edthefox5
    10,096
    4,837
    Clearwater, Florida
    No experiment. Aftermarket high performance oil and fluids are a huge business and have been for decades
  13. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Yes who knows it’s all a big mystery. To you.
    mjoo and Mendel Leisk like this.
  14. Sammydog
    Seattle
    Thank you for the update.
    I have a 2000 Toyota Avalon since the warranty expired I've been using aftermarket Castro Synthetic fluids engine, trans, etc .. and the car has 289,000 miles and running as smooth as it was 19 years ago. Zero issues, just regular maintenance. Data via "Bob the Oil Guy" says Synthetic is a much better fluid in almost all aspects. :)
    edthefox5 likes this.
  15. bisco
    52,785
    hybrid avalon?
  16. Mendel Leisk
    42,272
  17. will the engineer
    238
    119
    LA
    2019 Prius Prime
    Yes! its a thing.
    viciousty, bulk modlous, working fluid, heat are a thing!
    But if the fluids are within the same class or spec, there's not a whole lot to worry about.
    unless you really want me to dig into SAE journals?
    ( I dont want to flip this back on you, i tried to reword this) If I do offer a link or two... will you even put the time to read it?
  18. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Not necessary we have Bitog for that and btw they are all about aftermarket fluids they love the Lubeguard over there. Many people run that in the G2 there.
    #38 edthefox5, Jun 29, 2019
  19. edthefox5
    10,096
    4,837
    Clearwater, Florida
    You mean modulus.
  20. edthefox5
    10,096
    4,837
    Clearwater, Florida
    modulus formula does not come into play on a G2 nor G3 as there basically manual gearboxes.
