Transaxle fluid
Discussion in 'Gen 2 Prius Technical Discussion' started by magruder, Jan 27, 2010.
  1. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Yes I'll read it
    Pixel XL ?
    will the engineer likes this.
  2. RacerX
    RacerX Junior Member
    Des Moines
    Hello, I have a simple question and I have searched Priuschat an did not find the answer and this thread seems like a perfect place to ask it. I am passing my 07 Prius down to my kid and it has 220+K on it. I have never changed the transaxle fluid and I just drive it every day with no problems. Should I get it changed or is this something like you should not fix it, unless it's broke?
    #42 RacerX, Jun 30, 2019
  3. Mendel Leisk
    42,347
    Change it.
    I'm gonna get flamed, but use Toyota ATF WS. There's pretty much ONE instance in the Owner's Manual where Toyota get's insistent, and the the transaxle fluid spec is it. 4 quarts or liters should do. If you're getting an independent mechanic to do it, maybe supply him the fluid.
    It's a simple drain and fill. Refill with the car level, and when it starts coming back out, that's the correct level.
    A fair price would be around $80. Anything over $100 is a rip off.
    #43 Mendel Leisk, Jun 30, 2019
    Fred_H likes this.
  4. ChrisFaehrtPrius
    ChrisFaehrtPrius Junior Member
    29
    Hamburg, Germany
    I paid 43 EUR for four quarts of Toyota ATF WS, I don't see why you would need to buy something else. It isn't very expensive, and the oil change service shouldn't be either. Its very straightforward and doesn't take much time.
  5. Sandman53
    Sandman53 New Member
    San Francisco
    2014 Prius Plug-in
    So.. Ive been doing transmission ( Transaxle) fluid exchanges on my own Prius as well as all generations excluding Gen 1
    Ok... Good stuff! In my experience the prius has been SUCH a solid and reliable example of a workhorse daily driver vehicle. And as far as the transmission "transaxle" is concerned, i have been using Valvoline Maxlife synthetic ATF on mine as well as my customers gen 2 and above standard, plugin, and C models for 60,000 miles and over with no problems or complaints! Deffinately not saying Valvoline makes the BEST fluids for all vehicles... But did want to say that the prius platform is extremely versatile and well engineered to last a very long time with regular maintenence, with basic caution towards fluid reccomend ations.
    #45 Sandman53, Feb 28, 2020
    edthefox5 likes this.
