Transaxle hum but no warning lights.....help???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sfv41901, Feb 23, 2012.
  1. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I looking to see if anyone has a scangauge I can borrow. I seem to have gotten a hum coming from the front end when I reach 40mph & higher. Todate, I have not gotten any warning lights, red trinagle etc, but wanted to see if maybe there were some codes thrown.
    Lastnight, I put the front on jack stands & had my wife put the car in D & step on the gas while I was laying under the car. The noise is coming from the transmission where the axles plugin. My fear is I need a new tranny.....but if its a code related to the hybird system, I might be covered under warranty.
    By the way, my Prius is a 06 w/ 108xxx miles. I changed the CVT fluid around 70xxx miles.
    Thx in advance.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Re: Scangauge Loaner in Los Angeles
    Hum is not good. That usually reflects a bad mg. Also you would see much higher cvt temp caused by the bad mg. You could check that with a new Xgauge. It might be worth it to buy an xgauge as there very handy to have. If I lived in LA I would stop by but I'm in Fla.
    But a failed mg would also throw a slew of codes too. Odd.
    Because its not throwing any codes are you sure the sound is coming out of the trans and not a wheel bearing. Wheel bearing failure is pretty common on this car. I lost my LF wheel bearing at 30K and it made a humming wup wup noise at 40 and above.
    And do you see any cvt fluid leaking out where the axles come out of the trans as those seals leak right there sometimes.
    Check fluid level asap to get that out of the way.
    Btw, have you owned this car since new and or never been in a wreck?
  3. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I was just under there checking the fluid as u replied. It's fine & still looks new. No leaks around the axles. I was suspecting a WB as well until I got under it while the wheels where spinning. The noise is right around the tranny......not near the wheels. Today as I was driving & it started a slight vibration. I'm the 2nd owner. Got it with 55k miles. Clean title. I'll look into the Xgauge.....hope its not too much $$$.
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    what would be better:
    SGII w/Xgauge
    PLX Kiwi Bluetooth w/Torque app
    Sorry, this is all new to me.
  5. edthefox5
    10,096
    4,834
    Clearwater, Florida
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I remember reading that thread & a few others. They all seem to have gotten some sort of warning light on the dash.......which I haven't. I went into the maintenance screen & this is all I saw.
    What are the chances there were some codes thrown but dash lights didnt light?
  7. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Seen that mentioned before here and its basicly gibberish.
    I own a Scangauge so am partial to that. Here's a list of codes available with the new Scangauge II:
    http://www.scangauge.com/support/toyota-specific/
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Ok, so I bought the kiwi Bluetooth adaptor so I can run the torque app. Cheaper than the SC2. $89 + $4.95 for the app. I'm hoping I won't see anything wrong.
    Has anybody heard of the axles failing? I don't have CV joint noise, but don't know if the axle has a joint near the tyranny. Anybody woes have a clue?
  9. UKCLASSICPRIUS
    127
    UK LONDON
    Mate seriously with these cars, until It aint broken, DONT fix it...!
    wait for the issue to get worser, & lights to pop up, that will show the problem...
    the best you could have done you done already by changing the transaxal fluid...
  10. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Good. Monitor cvt temps like that thread I linked. Trans on these cars run pretty cool. The bad mg will spike hot like 180F.
    CV joints especially inners don't hum when they fail but
    hum is subjective but not sure what your asking is there a joint inside the trans that may be servicable? Doesn't matter you can't get any parts for it and you would have to pull the cvt anyway. At that point there's used cvt's available.
    But are the inner & outer rubber cvt boots intact and not ripped or leaking?
    And with no codes thrown its a head scratcher at this point.
  11. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Both inner & outer boots are intact.
    What I was referring to was the inside of the axle side closest to the tranny. Dose it have a joint & can that fail?
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Thx but I would rather not way for a sever failure. Would like to catch it before I end up stranded on the side of the road.
  13. shaneb
    shaneb New Member
    Cairns Australia
    The joint that goes into the transaxle is a very basic tri joint that doesnt usually give problems. I have had gen 2 prius do over 500,000km and give no trouble with the inner joint. The outer joints closest to the wheel have failed but they give a very distinct clicking sound when turning.
    If the mg temps are ok the bearing under the silent chain is failing. Early on it wont set any codes but as it gets worse they will light up.
    This is very common here in Cairns in the taxis.
  14. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Once again, are you sure it's not a wheel bearing? That's a very common cause of humming in that area.
    Tom
  15. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Is there an easy way to test the WB?
    So far I have tried the following:
    I've yanked the wheel from side to side.....no change
    I've lefted the front to see if there was any play in the wheel....none
    If it was a wheel bearing, would the noise almost disappear when the wheels are off the ground?
    If its the bearing under the silent chain, would this be covered under the 150k CARB warranty? Is there a way to test this bearing?
  16. qbee42
    18,058
    3,081
    Northern Michigan
    Drive somewhere that you can make turns at speed. Get up to the speed where the hum is audible, then turn to one side and then the other. The turns should be sharp enough to generate noticeable side loading. A bad wheel bearing will be louder turning one direction, and quieter the other.
    Tom
  17. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Ok. So ill look for a parking lot big enough for 40+ mph turns & report back tomorrow. Thx.
  18. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Qbee is on it as thats how the Toy tech road tested it. Parking lot not neccessary. Drive down a quiet road and whip the wheel a little back and forth one direction then the other slowly. Like your avoiding a road hazard. If the noise gets louder as you whip it, it's the wheel your whipping into.
    The WB would make the most sense 'cause if its a shorted MG it would throw codes.
    I lost my LF WB at 30K on my 07. Fixed under 3/30.
  19. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Interesting. Is anyone rebuilding the transmissions up there Shane, or are just fitting new ones?
  20. northwichita
    481
    102
    29
    Wichita KS
    Laying under a car while its running... yikes. Someone had to say it.
    If all tests for the wheel bearing seem negative, I would try draining the the transaxle fluid into a clean container , you can reinstall the fluid, after checking for the amount of metal on the magnetic drain plug, and also whatever shavings settles into your catch container. It may give a clue in the inside of the transaxle.
    I've considered doing this to my car halfway between fluid 'changes', filtering the transaxle fluid through a fresh coffee filter, and reinstalling it , as the car itself doesn't have a fluid filter.
