Transaxle issue; would appreciate your thoughts
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lauren Everett, Jan 3, 2025.
  1. Lauren Everett
    Lauren Everett Junior Member
    Portland, OR
    Hello all,
    This is kind of a long story so bear with me!
    I've had my 2007 Prius for 4 years with no significant issues. It was just about to hit 140k when the triangle came on. I took it to a mechanic to read the codes and got P0A08. It started up one more time and then wouldn't start the third time, but started with a jump. Had it towed to Greentech EV and Hybrid Battery and they tested the inverter and pump before finally deciding it must be the 12v battery, which they then replaced. Apparently it had been draining quickly while the car was off.
    I did some short drives around town and all was fine, so a week later I departed on a 1,000 mile road trip from Portland, OR to Yucca Valley, CA. Unfortunately, that was not the end of the story...
    Day one of driving (around 350 miles) was totally fine). Day two, we get maybe 100-150 miles down the road and the triangle comes on along with the tire pressure sensor and VSC. Pull off the highway to collect ourselves and then head to an Auto Zone for a code read. They get C1241 and C1310. I explain to the dude at the store that the battery was just replaced and his theory is a bad connection. We decide to keep going since I think at this point it was just the triangle and it seemed like whatever triggered the other warning lights had subsided.
    At some point around now I also noticed a pretty audible whirring noise on the left side of the car. My co-pilot thought it was just the wheels hitting the road, but it def didn't sound normal to me.
    Well, an hour or so later those lights come back on and the car powers down on the highway. We pull off and I call a tow truck. After an hour or so of being off, we turn on the car just to see what happens and (I think??) the triangle is on warning lights are off so we drive to the local Toyota service center, which is closed. Absent any great options we decide to take back road for the last 100 or so miles to our destination. The next day we go to the local service center but of course NOW the triangle is off, so all I can do is give them the history. They run a $300 diagnostic (fun!) and find P0A2B-250 and P0A37-260.
    The tech explained that this points to a malfunction with the temperature sensor and showed me how he was monitoring all the heating components - which are all behaving normally - which in his view points to the sensor itself being bad. Explains entire transaxle would need to be replaced. Shows us how to disconnect and reset the battery in future, so we can get where we're going. He also checked the fluid (fine) and replaced, and the coolant and wiring and found no issues.
    Since the lights are off we decide to proceed cautiously to our destination, trying to go no faster than 70 (CA highways are very fast). Triangle comes on again (to my recollection it was just the triangle this time) so we pull off the road and luckily there's a service center a few miles away. They do a free health check (thank you Selma Toyota!) and find P0A2B-250 only.
    We get back on the road and maintain a speed of under 60, and stay at a midpoint between there and our final destination so as not to stress the car. From that point forward - staying under 60 - no more warning lights have come on. I would estimate 200-300 miles since then.
    I am now in a driving environment where I have to get on a 60mph highway every day to go anywhere, which is like the worst possible time for this problem to happen, so I need to figure out a solution (fix? buy new car?) asap. Your sage advice would be most appreciated!
  2. Tombukt2
    Tombukt2 Senior Member
    13,668
    2,476
    Durham NC
    These thermister type temperature sensors I guess they can go bad and this particular one is inside your transmission transaxle and doesn't look like it's something that gets changed or serviced a wiring diagram would help greatly. Tracing down the sensor wiring to make sure that nothing's been crimped pinched or something out there in Oregon and whatnot The weather's pretty reasonable not excessively hot or excessively cold and all of that so California these days similar although it's getting hotter. I have friends in Corvallis. I would think personally slapping another transaxle into your Prius if you like the car wouldn't be a problem if it's not smoking burning oil and otherwise doing old car things if that's not in the list of possibilities then you'll probably wind up replacing the car if you have to spend a lot of time going over 60 miles an hour in the heat just makes sense The codes all point to the thermistor in the transaxle that reads the motor electric motor and gets too hot what have you I mean a transaxle for an '07 Prius even a low mileage one from somebody like me or a private owner today would be almost no cost there's no market for this stuff You should be able to get it for near nothing I would almost give it to you your friend would come over here and help me lift it out and he could take it with him give me 50 bucks something just so somebody can use it I know all people aren't like this but anyway rather than just send it off to be burnt or crushed or I don't even know what so you have to weigh that out but changing the transmission in the front wheel drive car generally is about a two or $300 labor affair it's not a big job to drive axles get pulled out lay in the car seven bolts undone inverter moves out of the way transmission is hoisted right out another one drops right in place seven bolts or replaced inverters mounted back on top of the tranny drive axles are pushed back in etc It's not that bad so if you can get the transaxle from somebody for say $200 you know got like five or six hundred dollars doing this repair so if your car isn't reasonable shape it may be well worth it a generation two in my eyes is well worth it generally now if it's rusting away and all of this and that then you may have to reconsider that depends where you live and the weather but generation twos are built like tanks compared to everything forward of that model You're in the one that's got the possibility to go 666 The rest of them not going to happen so you have to go with your gut and what the mechanics are telling you and what you have a picture of your car goes a long way doesn't matter if it's old and faded got a few dents that's not what we're talking about that may be what you're interested in. I'm interested in the car going to 666 and being usable I don't really care what the neighbors say they're the ones paying $700 a month for a Chevy Aveo.
  3. Lauren Everett
    Portland, OR
    Thanks for your response! I'm unfortunately already in CA so I can't take you up on your Corvallis offer. Is there any chance this could NOT be the temperature sensor? I found this old thread where the car owner changed the transaxle twice and that code ended up being I think the ECU (I thought I bookmarked the thread but can't find it.) A little worried I'll spend a bunch of money to replace it and that won't end up being the problem.
    Also, what's the deal with the sort of howling noise on the driver's side? How does that fit into this scenario?
    Brian1954 likes this.
  4. Tombukt2
    13,668
    2,476
    Durham NC
    With the proper Toyota software a reasonable technician should be able to gauge and figure out whether your ECU ECM is going south or has gone south or weather you have a problem in the transmission generally the squib business and all that Is internal to the transmission and the transmissions coming out whether they play with yours or they replace it with another one that didn't have the problem that would be up to you I don't think I would be paying anybody to rip open a 20-year-old transaxle at this point in the game when I can find a $100,000 mile one in many parts of the US they're all over the place pretty much.
  5. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    Never had this issue, but if the trans is making a new noise and a temp sensor is sensing maybe the two are related. Noise indicates friction somewhere. If you can drive it at 60 with no issue, continue that until you find a decent independent prius shop. Getting AAA with free towing might make you more comfortable with the situation. Another question is how much do you want to spend to keep it running? With that sort of mileage it might be worth fixing. You should have another 100K left easy but if there is a trust/anxiety issue with it that matters as much as the money.
    FWIW both my 30 something kids have these cars and when they go more than 300 miles they rent. When I have a trip over 100 miles I take another car, the prius just isn't fun over 70 especially in hilly areas. The wife's baja turbo is!
  6. Brian1954
    Brian1954 Senior Member
    2,513
    1,005
    South Central PA, USA
    Yes, there is a good chance that the problem is not the temperature sensor. The temperature sensor is a thermistor, which is very reliable and rarely goes bad.
    My guess is that the inverter coolant pump is bad. Normally, when the pump goes bad, code P0A93 is triggered. I would take a chance on replacing the pump before I replaced the transaxle. Find an independent garage to do the work and only use the Toyota OEM inverter coolant pump.
    The inverter coolant pump is located underneath the inverter on the driver's side. The noise you hear maybe is the pump.
  7. Lauren Everett
    Portland, OR
    Thanks Brian! Two shops have tested the pump (I've also observed it working) and don't think it's that, but is it possible it's intermittent? I did find a mechanic out here to replace the transaxle for the amazing price of $1,500 plus the part, so I'm ready to move forward on that as long as I feel confident that's the issue.
  8. Lauren Everett
    Portland, OR
    The Toyota service center did in-depth testing and didn't find anything beyond the temp sensor issue. Obviously I can't speak to the depth of their knowledge, but the dude did spend some time with it...
  9. Lauren Everett
    Portland, OR
    I found a shop in my area with good review who can do it as soon as I have the part for $1,500 labor! What should I be looking for online when shopping for a used one? Some say 0 miles, which I don't understand...
  10. mr_guy_mann
    mr_guy_mann Senior Member
    4,107
    2,008
    NJ-USA
    You can get strange transmission temperature sensor codes if the transmission fluid is overfilled. Have seen it act up but only after driving at highway speeds for several hours.
    If the transmission was filled while the front was raised on jack stands, someone can put way too much fluid in. I have drained 3-4 quarts out of the FILL plug on a couple Gen2's while the car was raised (level) on a lift. This corrected the problem.
  11. Lauren Everett
    Portland, OR
    Would it shut down on the highway though? Cause that happened once. The guy at the Toyota dealership drained and measured the fluid and said the correct amount was in there…
  12. rjparker
    rjparker Tu Humilde Sirviente
    10,723
    6,733
    Texas Hill Country
    Some good advice and maybe some shotgunning. When you went to the "local service center" and they changed the transaxle fluid, do you mean at a Toyota dealer or somewhere else.
    Did a dealer look at the howling issue? It could be the transaxle (rare) or a wheel bearing (common). Certainly something causing excessive drag could warm up the transaxle. At freeway speeds you would not expect the transaxle's electric motors to be used excessively.
    This is my philosophy as well. An old Prius is not reliable enough for road trips.
    A bad temperature sensor usually is easy for the ecu to specifically diagnose and code for including issues like a sensor or wiring short, open or totally out of range. A sensor that starts at ambient temperature when the car is cold and builds up in a linear manner is usually telling you the device being monitored is too hot. Being able to watch the sensor with a scanner while driving tells the tale.
    This is an interesting possibility but is one I would discount if the fluid was changed by a Toyota dealer. Regardless it is a quick and easy check for anyone with a lift.
  13. Lauren Everett
    Portland, OR
    So is it possible the wheel bearing could be causing the sensor malfunction code? It sounds like the wind howling through an empty house and gets louder the faster I go and is way more audible when I take my foot off the gas. Almost can't hear it at all when I'm pressing the gas. This is the exact code from the health check at the dealer:
    P0A2B-250, TEMPERATURE SENSOR CIRCUIT MALFUNCTION.
    Or is there a scenario in which both things are just happening at once??
    Yes, the Toyota service center mechanic emptied and measured the transmission fluid (said it looked fine) and refilled. I've now been driving it for over 300 miles with no red triangle (yet!) but the sound is very stressful.
  14. Lauren Everett
    Portland, OR
    Update: I made an appointment at an independent mechanic for Wednesday to try and figure out the noise, and from there determine if I need a new transaxle in addition to whatever is causing the noise. Hopefully I will make it the 25 miles there!
  15. Lauren Everett
    Portland, OR
    Does anyone have a Carfax or similar account and wouldn't mind running a VIN for me? There's a used transaxle an hour away but they don't know the mileage. Just want to make sure it isn't something crazy.
  16. Lauren Everett
    Portland, OR
    In case anyone dealing with the same issue sees this thread, it was a failed bearing in the transaxle. No idea why that would have happened at 141k miles and with the proper amount of fluid, but here we are. Bought a JDM used transaxle and am hoping for the best. Not super confidence inspiring with this car.
