Transferring favorites from Garmin to Entune Map App
Discussion in 'Prius v Audio and Electronics' started by jejennings, Oct 31, 2012.
  1. jejennings
    jejennings New Member
    Just took delivery of a Prius V with the Entune system installed. I have been using a Garmin in which I have entered hundreds of "favorite" addresses. How can I transfer these from my Garmin to the Entune Map app????
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,678
    Texas Hill Country
    One by one, unfortunately. If you want to try, you could attempt voice entry and then save. For example, press the voice button and state "Destination 1002 Maple St Austin Texas". The system will pause then repeat back and sometimes ask if #1 Maple Tree or #2 Maple Syrup or #3 Mariposa St or #4 Marty McFly is correct....
  3. GerryL
    GerryL Master Model Railroader
    170
    23
    Minneapolis, MN
    That's what I had to do with my Garmin: one by one. Pain in the bucket seat.
  4. mandasol
    mandasol Member
    33
    27
    Atlanta, GA
    If you have a smartphone you can save a little extra time by downloading the entune app, then searching for each location using the bing search within the app and saving that location, later you can sync the addresses to the entune system in your car. I can enter and find locations way faster on my phone than I can using the touch screen or voice recognition with the car.
  5. mdchachi
    mdchachi New Member
    Can I ask a silly question? Why do you save so many addresses? Navigation is generally used for places you don't know well. If you know how to get there, you probably don't need to save the address. Anyway I'm just curious as to why so many, thanks. BTW, I think the Entune system only saves up to 100 so if you really have hundreds, you may be out of luck.
  6. tim1964
    tim1964 Junior Member
    2012 Prius+ MPV
    I would like to know also but using TomTom POIs instead.
    On my TT I have thousands of electricity distribution sites covering 1000+ sq miles that I need to be able to find and to save using both the TT and the NAV in the V would be ideal.
  7. Zephyr7
    Zephyr7 Member
    301
    28
    Are you Display Audio with Nav? there is a import/export function somewhere under Setup->General.
    In theory, U could do the below
    google "export garmin fav address".
    Once you get it into a file format attempt to format it to the format the entune likes on your PC.
    bring it back to Entune system and import it. Done!
