Transferring iPhone contacts over bluetooth
Discussion in 'Gen 2 Prius Audio and Electronics' started by Teddy76, Mar 28, 2012.
  1. Teddy76
    Teddy76 Junior Member
    38
    Denmark
    I have an iPhone 4 that is already paired with my European 2008 Prius.
    When going through the MFD menu to transfer contacts, it tells me to initiate transfer from the phone. I do not see an option to do this on the phone. But I see that the bluetooth has been disconnected although I read somewhere that this is normal and not to worry about.
    So how do I make the transfer?
  2. ranvin
    ranvin New Member
    Teddy
    Did u ever figure this out? I'm having the same problem.
    QUOTE=Teddy76;1509091]I have an iPhone 4 that is already paired with my European 2008 Prius.
    So how do I make the transfer?[/QUOTE]
  3. ranvin
    ranvin New Member
    Teddy
  4. Teddy76
    38
    Denmark
    As far as I can tell, it's not possible (thanks to Apple).
    Still looking for a way to get them transferred.
  5. Teddy76
    38
    Denmark
    I have read that thread before and the one that your linked post links to. It still does not tell me how exactly, one can transfer the iPhone contacts to the Gen. II Prius.
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I'm saying you may be out of luck thanks to what's implemented on both the iPhone side on the Gen 2 Prius' nav system side, at least w/the rev of nav DVD I have.
    If someone succeeds, I'd love to hear about it.
    It's CLEARLY possible (w/the "right stuff" on both ends) since I did succeed transferring my entire iPhone 3G's phone book in one fell swoop over to a Lexus HS 250h, but that was a much newer nav system.
  7. Murray Bell
    Murray Bell New Member
    Did you find out i have the same problem
  8. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Do you have a Gen 2 (04-09) Prius or a Gen 3 (2010+) Prius? Your user info indicates 2012...
  9. Logical
    Logical Junior Member
    82
    26
    St. Louis, Missouri
    I used a program for my Mac. Book called Prius phonebook it did a great job.
    Tapash likes this.
  10. jasdaller
    jasdaller New Member
    Hong Kong
    2013 Chevy Volt
    IPhone doesn't support bluetooth.
