Transmission B Mode -- Do my brake lights come on?
Discussion in 'Gen 3 Prius Main Forum' started by BlizzP10, Nov 13, 2010.
  1. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Observations
    Artnc you were correct, this version of the Prius does not default to D after it has been in B for a certain time or distance. I drove about 20 miles in B yesterday at 60 to 70 MPH and it never came out of B. Driving at a steady speed or accelerating the only difference I could detect between D and B is that the CC can't be set in B.
    But when you take your foot off the gas pedal the difference is obvious. In D or B on a particular stretch of fairly level road the tach read about 2200 at a steady 70 MPH. When I let off the gas in D the RPM dropped to a little below 1000 and there was no detectable engine noise. At the same speed in B when I let off the gas the RPM increased to about 3800 and I could hear the engine acting as an air compressor as described above.
    I remember last summer coming down a long steep hill in the Rocky Mountains I had a full battery so I put it in B and didn't apply any additional braking. At 85 MPH or so I noticed the tach and it was up to about 4800 RPM, the engine noise was quite noticeable.
    As far as I can tell driving in B mode doesn't really hurt anything but it is wasteful except in special circumstances.
  2. Tideland Prius
    16,683
    Good to know, thanks!
