Transmission clunking when hand spinning.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by armyguy08, Apr 19, 2020.
  1. armyguy08
    armyguy08 Junior Member
    Wisconsin
    I have a 2011 Prius with 145k. I started hearing little noises when the engine kicks on while already moving. I've had sounds that indicate a bad cv joint as well as clunking from the transmission under certain conditions. While inspecting the brakes a year ago, I noticed that spinning the front wheels by hand, there is about 5 inches of travel(at outside of wheel) before hearing a clunking of gears and the passenger wheel starts spinning. Spinning the passenger wheel produces that same thing with the noise coming from the driver side. My first thought was something wrong with the transmission but there is no signs of operational deficiency. Trans oil was changed every 30k after the first 60k change. CV joint seems intact with no noticeable looseness.
    Anyone notice something simlar?
  2. tankyuong
    tankyuong Senior Member
    1,555
    659
    Central MO
    I’d say your egr circuit needs cleaning
  3. armyguy08
    Wisconsin
    Inspecting the EGR valve is on my to-do list this summer.
    Raytheeagle likes this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,474
    Bay Area, California
    2019 Prius Prime
    Don't stop at the valve ;).
    It needs to be the whole circuit(y).
    ASRDogman likes this.
  5. Montgomery
    Montgomery Senior Member
    2,254
    2,233
    Orange County, CA
    Correct me if I am wrong, but the transmission on a Prius isn't built like regular transmissions and therefore should not be "clunking"?
  6. Vman455
    Vman455 Senior Member
    534
    551
    The Middle
    Was the car off when you did this? Anytime it isn't on (or is on and in P), there's a pawl that prevents the transmission from spinning, with a few inches of play.
