Transmission drain/flush, how often.
Discussion in 'Gen 2 Prius Technical Discussion' started by bigjon42, May 21, 2014.
  1. dolj
    dolj Senior Member
    8,657
    4,408
    Wellington, New Zealand
    You make some good points and makes sense to me.
    Yes, oil is the easy one, thankfully. Here I don't think even the Toyota dealerships use Toyota oil - Mobil or Castrol, I think.
    Thanks for your input.
  2. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    When I asked the Toyota dealership about the service, they told me that the fluid was good for the life of the vehicle and didn't need to be changed (even at my high milage). I came across this video during my internet research. I just had my transmission fluid changed at 166,000 for the first time by Dynamic Garage in Libertytown, MD. Total cost $115.00 and my Prius drives much smoother.
    Silver bullit likes this.
  3. bigjon42
    bigjon42 Junior Member
    Well, I changed the transaxel fluid today myself, thanks to lots of help from this forum. At 76,500 miles the old fliud was surprisingly clean.
    While darker than the new fluid, it was still semi-translucient and still red. Drain plug had dark stuff on it, but not a lot. Overall, job took about an hour, including getting the car up on jackstands. Biggest problem was getting the new fluid in with long, snakey funnel. I used Toyota WS fliud, about $11.50 a quart from the dealer. Would recommend do-it yourself if you are at all mechanicaly handy.
    Daves09prius and usnavystgc like this.
  4. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    And if this has been mentioned earlier I would like to reinforce........that a "flush" is NOT necessary and often causes more problems than it solves. Extra Dealer Profit is about the only reason for doing it.
    AzWxGuy and Daves09prius like this.
  5. car78412
    car78412 Member
    284
    32
    Hudson Valley, NY
    After watching the above video on how to change the tranny fluid, I am perplexed by the mechanics statement that the clutch material in the old fluid was making the fluid dark. I didn't Know there were clutches in a cvt tranny. I thought the Prius had planetary gears.
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    There is a clutch of sorts, but it is always clamped down and should never slip unless there is catastrophic failure.
    (about 5:20)
    Justin Walter likes this.
  7. Easy Rider
    982
    210
    N. Central Florida
    I saw it on the Internet; it MUST be true !!! ;)
  8. Mendel Leisk
    42,389
    There is one reason for a flush: if the wrong stuff has been put in.
    And all a flush need entail is: drain and refill, multiple times, with a short drive after each refill.
  9. GregP507
    GregP507 Senior Member
    3,002
    481
    I believe it's called a "torque-limiter." I've seen them on larger machines when they're ripped apart. They're designed to relieve stress on the drive-train which may be due to abrupt shifting or other sudden changes in drive-line velocity. In a practical sense, the Prius engine remains directly connected to the wheels at all times. Motor-generator 1 (MG1) compensates for the gas engine when it's stopped or running at a speed not proportional to the drive-train, and by running in reverse when the gas engine is stopped, while the car is moving.
    Those YouTube videos by John Kelly from Weber State explaining the Prius drive-line are really excellent. BTW, he drives a Chevy Volt himself.
  10. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    As you mentioned it wouldn't be clutch material making the fluid dark, it would be actual degradation of the fluid itself (and perhaps a very, very small amount of particulate from planetary wear). There are no active clutches either as noted above, it's a torque limiter (like a manual clutch that remains engaged at all times) and absorbs any torque spikes seen in the drivetrain.
  11. GregP507
    3,002
    481
    In the case of the Prius, it could be caused by a short in the windings of the electric motor-generators. In a different video, the transmission had failed because the insulation had burned off the stator.
  12. MTL_hihy
    536
    261
    Maritimes, Canada
    I've seen that before and it's not entirely clear what caused the MG2 shorting issue in the transmission, but I think that's part of the reason why sticking with the OEM fluid and changing it often could prove helpful.
  13. GregP507
    3,002
    481
    That makes good sense. There's no telling how the varnish on the stator windings might react to detergents in the oil.
  14. ETC(SS)
    7,587
    Whenever somebody says that you "have to use this oil" or "any non-OEM product will harm the vehicle" I'm always very skeptical.
    After all.....ATF, gear and engine lube are hardly what you would call emerging technology.
    However (comma!!!)
    I believe I would go with the herd on this one!
    I'm mechanically competent enough to change the transaxle fluid.
    I don't want to HAVE to find out whether or not I'm mechanically competent enough to do a transaxlectomy on a Prius.
    I believe that I would go with a change at 60K and see what happens after that.
    You're looking at perhaps $50 in fluid (or less!) and an hour's labor.
    If I ever buy a new G3.....maybe I'll do it sooner than 60K but the stator windings have me convinced enough not to try to use a substitution for the OEM fluid.
    Good discussion!
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
  16. GregP507
    3,002
    481
    I'm acquainted with inferior lubricants. The salesmen will give you any guarantee you want, but when your seals all turn to sludge, you're on your own. Happened to a farmer I know.
    Just like that.
  17. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Did my third trans fluid change last weekend. 30,000 miles on this fluid with vehicle total at 70,000 miles. Fluid still red and no metal whatsoever on the magnetic plug. Just a tiny film. So Redline D6 showing no wear at all so won't bother with a UOA at this time. Next change will be in 50,000 miles at 120K vehicle total.
    Changed out the fluid at 5,000 on it from new and that showed the most wear I have seen. Moved over to Redline D6 at that time. The first 5-10,000 miles are where all the wear happens in this cvt. I would say change the fluid out on a new Prius at that time and your good to go for at least 125K. Lot of initial break in wear.
    7 years on Redline D6.
    Also changed out the Inverter fluid at that time. Your already under there so pull that bolt. So easy to change the Inverter coolant its so simple.
    Also dumped just the rad engine coolant. I do that once a year. It helps. A full engine coolant change is very hard to get the air out and a total pia.
  18. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Fairly annoying, I agree
    From now on I plan on replacing a gallon every 10 - 15k miles using the Lisle funnel so that no air enters the system. That will hopefully be a 5 minute painless exercise rather than the couple of hours the complete drain dance requires.
    edthefox5 likes this.
  19. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Me to. This car is very easy on the Engine coolant but I figure the cleaner it is the longer the water pump will last.
