Transmission Failure!
Discussion in 'Gen 2 Prius Technical Discussion' started by ptesta454, Apr 8, 2018.
  1. ptesta454
    ptesta454 Junior Member
    Alaska
    So my transmission totally failed yesterday. Gave it some gas, tires slipped on wet road, and boom, warning lights, no power, and a NASTY grinding sound with lots of vibration from the engine bay.
    The smell was really bad too. Obviously something is seriously wrong. Does anyone have experience with this?
    The car will not move at all in gear. Took it to the dealer. Worried about the bill.
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Curious about the total mileage, and if the transmission fluid was ever changed?
    Raytheeagle likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Once the codes are read, post them up here ;).
    Were there any other issues with your Prius prior to this incident?
    Good luck and keep us posted (y).
    SFO likes this.
    52,855
    i hope you're going to get an estimate before they repairo, could be more than the value of the car.
  5. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Being an 07, that shouldn’t be too high of a bar:(.
    edthefox5 likes this.
  6. bisco
    52,855
    whoops, i thought it was an '04, never mind.:oops:
    SFO and Raytheeagle like this.
  7. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    No worries;).
    The same bar is still verrrrrrrrry low and the salvage title will be applied:(.
  8. bisco
    52,855
    yeah, there comes a time in every car's life, unless you can diy.
  9. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Even if you can DIY, insurance will estimate the the repair cost and if it is within 80% of the estimated value, it’s scrapped:(.
    I’m waiting with popcorn to see why this particular 07 is worth saving:cool:.
  10. bisco
    52,855
    i don't think insurance will cover a break down. not my insurance anyway.
    edthefox5 and Raytheeagle like this.
  11. audiodave
    audiodave Active Member
    800
    272
    US
  12. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Coming full circle now, so you can get back up to speed quickly.
    Dealer will be asking for north of 4k.
    A used transmission is around $500, and the R+R could be as little as $500+ (depending how hungry someone is).
    Now might be a good time to look for another vehicle, and or find a local mechanic who can do a swap with a used transmission.
    strawbrad, edthefox5 and Raytheeagle like this.
  13. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    If you worried about the price don't go to the dealer. Used transmissions for this car are going to be Dirt Cheap since nobody ever needs them. How many miles on yours? Fluid never changed right?
  14. ptesta454
    Alaska
    My car is an ‘09 Touring package 6 with 159K on it. Worth probably $5K. Bought at 120K and have never changed the fluid, per Toyota.
    It is in Wichita, KS. Anyone know any independent Toyota mechanics in the area?
    I get the news tomorrow. I am not expecting it to be good.
    Raytheeagle, audiodave and SFO like this.
  15. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Wouldn't surprise me if @Raytheeagle knew of a decent mechanic in Kansas :whistle:
  16. ptesta454
    Alaska
    Is it defintely just the tranny? What else could it be? I’m seeing some used ones for between $250-$500. If I can get a good mechanic to do the job, I may survive this.
  17. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Never really used one while in Wichita :whistle:.
    But L&M auto repairs off of 43rd street is one a couple of people I knew out there used:).
    Might be worth a call if nothing else(y).
    bisco, ptesta454 and SFO like this.
  18. ptesta454
    Alaska
    Thanks! I gotta say...I’m glad I posted here. My stress level is down about 70% thanks to you guys.
    douglasjre, audiodave and Raytheeagle like this.
  19. ptesta454
    Alaska
    The only issue I noticed was a jerkiness at around 30 MPH when the ICM engaged. It was quite a hefty jerk.
  20. ptesta454
    Alaska
    Dealer just called. Transaxle failure. $6,800 parts and labor!
    I’m gonna buy a used tranny for much less, but they are asking for the damper assembly and if it comes with it. Does anyone know what they mean? I can’t get an answer from the part supplier if it will be included. Thanks.
    Prius2007xyz and edthefox5 like this.
