Transmission Fluid change question??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PRwanting, Oct 19, 2012.
  1. PRwanting
    PRwanting Junior Member
    48
    Boston, MA
    So took my 05 Prius to the dealer to get a transmission fluid drain and fill and a regular oil change since I'm about at 60000 miles. This is what the dealer technician told me-- "The Transmission fluid shouldn't be changed. Transmission is a sealed unit and the transmission fluid shouldn't be changed." It's kind of puzzling. I thought Prius is supposed to get a transmission fluid change at 60000 miles. Anyone have any idea why the technician said that? I have 2005 Toyota Prius, package 6 if that helps.
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Because Toyota says that the fluid is good for 100,000 miles.
    U can either TELL them (dont ask them) u want it done or DIY
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    When I took my Gen 2 Prius in and asked for a Transaxle drain and fill, both the service manager and the mechanic stated that it was not required at that time. I told both that I wanted it anyway. $109
    Once the mechanic saw the black color, he quit arguing.
  4. usnavystgc
    3,159
    990
    Tucson, AZ
    Just so you know, all transmissions are sealed. That's why they don't leak. So that's a play on words but, changing fluid in anything that has metal to metal contact is never a bad thing.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    What is interesting to me is that the dealer says that the transaxle fluid change is not on the Toyota maintenance recommendation and people go OK. Yet the same dealer will upsale you fuel flushes, brake fluid flushes, engine top cleaning services, etc. that are not on the maintenance recommendations and most never question this.
    Berch1943, sfv41901 and usnavystgc like this.
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Cause most don't know any better
  7. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Sad but true.
  8. bisco
    52,554
    what dealer is it? being in the boston area, i like to know who to avoid.:cool:
  9. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    The sales pitches for unnecessary scam services are so common, widespread and uniform that there has to be some organized effort behind it. Might be part of the sales pitches that the sellers of the trans flush and injector cleaning machines, etc provide the dealer with.
    Since there is no way to use an automatic transmission flush machine on a Prius, there is no incentive for the flush machine vendors to program the stealerships to sell that service to Prius owners. OTOH, I did have a service adviser for another make of car try to sell me an expensive transmission flush for my manual transmission equipped car.
  10. Berch1943
    Berch1943 Member
    146
    Arizona
    I'm at 160,000 and dealer told me the same thing.
  11. HyperVent
    HyperVent Junior Member
    MA
    "Same thing" meaning, don't change it??
  12. Mendel Leisk
    42,059
    Just change it. DIY if possible. It's about $40 for 4 quarts of TOYOTA ATF WS and fill/drain bolt washers (through dealership parts dept).
    Raise and level car, drain, reinstall drain bolt (with new washer), then fill till it starts coming back out. Install fill bolt.
    Easy way to fill: funnel with tube extension from above, preferably with an assistant pouring, while you keep watch below.
    Takes about 1/2 hour, plus maybe an hour for all the dicking around raising/lowering.
    The best time to first do this was about 150k back.
    Through dealership $80 would be fair price. Anything over $100 is robbery.
