Transmission Fluid change question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Berch1943, May 26, 2020.
  1. Berch1943
    Berch1943 Member
    146
    Arizona
    I could not find any videos how to clean the ac drip hose for the 2nd gen Prius. Mind pointing me to the right direction?
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Please read post #16.
  3. KeystoneKid
    KeystoneKid Junior Member
    24
    Utah
    Mendel,
    I know you guys say that Toyota recommends 29 ft.lbs. torque to close the fill and drain plugs. That said, why is it so darn hard to break them loose? They must be torqued from the factory at more than 29 ft.lbs., no? Would a little PB Blaster make a difference or is it just corrosion?
    Bob
  4. Mendel Leisk
    42,347
    I used a Jet wrench with a handle that's about 18" long, made it relatively easy. No extra lube. They still made a bit of a poing when they broke loose. You want to get a proper ratchet wrench socket with a (male) 10mm hex bit; don't try it with an Allen Key and pipe.
    KeystoneKid likes this.
  5. ChapmanF
    19,024
    Things can be torqued to j foot pounds at the factory, and then sit there for years, and then take kj foot pounds to break loose.
  6. KeystoneKid
    24
    Utah
    Berch1943 - I bet your mechanic was referring to an older American car with a lot of miles and no history of transmission service. Many transmission techs will tell you it's best to leave well enough alone. A trans filter and fluid change can sometimes make these transmissions fail. Not all but some will. He probably didn't understand that you were talking about a Prius. Just a thought?
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,014
    NJ-USA
    There's something about the plating used on fasteners by the Japanese.
    I see it all the time, where any bolt or other fasteners "feels" like it take 3-4 times the tightening torque in order to break it loose. "Crack it" a sixteenth of a turn, then spin it out with your fingers. Great corrosion resistance, but it has got it's own loctite.
