Transmission fluid change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by zander, Sep 25, 2012.
  1. zander
    zander Junior Member
    46
    connecticut
    I tryed to change my transmission fluid thinking that the filler, drain was on the drivers side according to the picture of the transmission. I found the correct way on the web site and did remove the under cover.
    The fluid was dark, nothing comparded to the new fluid( 51,500 miles), what a big difference smoother operation and coasts better.I would not wait this long again to change the fluid.
    Batmobile 2010 likes this.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    After the first change, it stays pinker longer. I try to recommend 30,000 miles and then every 60,000 after that.
    Batmobile 2010 and Andyprius # 1 like this.
