Transmission fluid change
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by fgoodyear, Jul 16, 2008.
  1. Mendel Leisk
    42,355
    The correct level is achieved by filling till it comes back out, with the car level. You probably are close, but it is SO much easier, with car raised and level.
    ozmatt likes this.
  2. ozmatt
    ozmatt Active Member
    637
    263
    Australia
    I done my partners gen2 a couple weeks back :)
    It took 3.6L
    I was happy to use valvoline maxlife as edthefox made me aware the motor generators are not submerged in fluid in gen2
    edthefox5 likes this.
  3. Classic Car Guy
    Classic Car Guy Active Member
    505
    136
    Northwest, USA
    Hi Patrick,
    How many miles do you change the transmission oil? The last oil that I use and I want to replace is the one you told me to buy at the Toyota dealer. Thanks,
    CCG
  4. Patrick Wong
    18,210
    6,526
    I would change the oil after the first 30K miles; then every 60K miles beyond the initial change.
    Classic Car Guy likes this.
  5. Classic Car Guy
    505
    136
    Northwest, USA
    Thanks Patrick. I always take your advise!
  6. Pete44
    Pete44 Junior Member
    48
    AWSOME work Jeff. Thank you so much for sharing. I've been digging through this forum for an hour trying to find USEFUL information. Yours is great. I had researched this at some point a long time ago....after changing my original WS ATF fluid with Redline D6 at about 60,000 miles. Factory oil looked kinda ugly, and I was glad I changed it. Somehow, I had a note to just change it every 60k miles, but then I wrote another note to myself (I think more recently) "Did research on Prius Chat. No need to change ever again." I don't write something like this lightly. I research the F%$& out of things, and I have a chemistry degree and manage many types of piston aircraft engines. So I'm no slouch. Just trying to find out if I'm going to change the ATF fluid again now (I last changed it at 96k and I'm at 160k) and your data will help me decide. I might, possibly, skip it completely, and forever. Not certain, but pretty sure I'm only going to put another 30-60k on this car (moving away from US hopefully), and thus not sure it's worth bothering to change it since I've done two D6 changes, and the Redline should easily last 100k. Meh, we'll see. Just wanted to thank you for putting up actual data. Appreciate that very much.
