Transmission fluid leaking after fluid was replaced
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 4HisGlory, Dec 30, 2017.
  1. 4HisGlory
    4HisGlory Junior Member
    San Diego, California
    Here is the culprit:
    I got the new water pump put in. I had a difficult time tightening the water pump pulley bolts. I tried inserting a bar in the pulley holes to stop the pulley from turning, but that didn't work very well. I don't know if I was able to adequately tighten the bolts.
    52,861
    congrats, that's a tough job!(y)
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    When I did this on a Gen2, we used a pair of channel locks and that seemed to had it well enough to snug it down;).
    But it is a tight area to work:(.
    Glad you found the leak culprit(y).
    uart likes this.
  4. Mendel Leisk
    42,352
    A little late, but this might help. There's an SST (Special Service Tool) which looks to be something you could cobble, basically a pair of pins to restrain it from rotating. Or maybe there something like that commercially available. Or channel locks.
    uart likes this.
  5. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Once you have installed the belt just tighten the belt a bit too tight and then you can use a wrench to tighten the bolts. If you put the wrench so that it goes over the center of pulley it will reduce the force that’s turning the pulley. In reality that’s very fast and easy.
    johnjohnchu, uart and Mendel Leisk like this.
  6. Mendel Leisk
    42,352
    ^ That's actually brilliant. (y)
    As you say, doesn't completely prevent the tendency to rotate, but would really reduce it.
  7. Patrick Wong
    18,210
    6,522
    1. I hope you installed a new serpentine drive belt. A new belt, properly tensioned, should exert sufficient friction to hold the coolant pump pulley stationary, as the pulley bolts only need to be tightened to 11 ft.-lb.
    2. Are you aware of the need to run the coolant heat recovery system pump, while working on getting air out of the engine coolant loop?
    3. If you hear air bubbling in the cabin heater core when you have the cabin heater turned on, that is evidence that you have air in the system and you need to take action to resolve that issue.
  8. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    On the topic of tightening the bolts, be sure to properly tighten the idler pulley (tensioner) and adjusting bolts.
    My adjusting bolt had been finger tightened, which held for 500 miles before loosening enough to toss the belt onto the splash shield.
    Raytheeagle likes this.
  9. Mendel Leisk
    42,352
    Drive Belt info:
    SFO and Raytheeagle like this.
