Transmission fluid life-age oriented?
Discussion in 'Gen 2 Prius Main Forum' started by bogeybob513, Jun 5, 2013.
  1. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    My 2006 (actually purchased in Aug. 2005) only has 26K on it. Does the transmission fluid deteriorate based on time or miles?
  2. Patrick Wong
    18,210
    6,517
    Miles driven.
  3. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    After 60k miles it is used up (earlier in the "Break-in" period).
    JeffD
  4. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    Thanks Patrick-thought so but just wanted to be sure.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    7 years is a very long time for dirty trans fluid to sit in the trans. Acid will build up. Its very cheap insurance to replace it.
    That includes the Engine and the Inverter coolant also.
    JMD likes this.
  6. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    Thanks-I believe the Inverter coolant was replaced a few years ago during a recall.
  7. jdenenberg
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    All,
    Here is some real data on Toyota Type WS ATF performance in my 2004 Prius over the first 240k miles of it's use. Testing of ATF samples was done by R&G Labs of Tampa FL on Virgin ATF and at each 60k miles of use when the ATF was drained and refilled. Several things should be noted:
    • The wear metals build up quickly in the first few miles to unreasonably high levels and then the rate of metallic wear decreases to a low level.
    • There is a high silicon content in the original factory ATF which seems to be due to factory sealants.
    Both of these factors suggest that an early ATF drain and refill is advisable - I suggest doing one at 30k miles.
    • The Viscosity tests indicate that the Type WS ATF lubrication properties are weakening by 60k miles.
    So I suggest a drain and refill each 60k miles thereafter if you want to take good care of your Prius transmission. It can be done DIY or, if you want, should only cost about $100 at a Toyota dealer
    JeffD
    dorunron and JMD like this.
  8. edthefox5
    10,096
    4,837
    Clearwater, Florida
    The fluid is usually not replaced during that pump replacement done under that TSB. They just clamp each hose off and swap the pump in. Then top off the small amount they lose.
  9. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Acid?
    From what?
  10. edthefox5
    10,096
    4,837
    Clearwater, Florida
  11. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
