Transmission Fluid Replacement - DIY or Dealer?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PixelRogue, Jun 16, 2019.
  1. Mendel Leisk
    42,322
    Yeah it's a spindly leafed variety. Happened to land on the car lol.
  2. CR94
    CR94 Senior Member
    2,825
    1,241
    Northwestern S.C.
    My take:
    You do need to get it approximately level. I did so by working on a moderate hill, with front on lowish ramps, with the rear higher up the grade.
    Capacity is under 4 quarts. Don't overfill.
    You don't need to replace the washer, as long as it is still in good shape, you don't flip it over, and you don't leave it stupid-loose.
    PixelRogue likes this.
  3. as.rizvi
    as.rizvi New Member
    Islamabad pakistan
    My dealer poured cvt transmission oil in my Prius 2012. Next day i read user manual of Prius and then changed it to ATF WS. These nice person holes dealers are bastereds and knows nothing
  4. Sr5dude
    Sr5dude Member
    58
    55
    Gilroy,California
    Use Toyota WS trans fluid only. It is completely compatible with materials used in your trans where others may not.
    Raytheeagle and as.rizvi like this.
  5. PixelRogue
    489
    86
    US
    There are strong options that parrot the Toyota dealer line of requiring Toyota OEM fluids only, yet no one can state why (beyond the Toyota corporate line of 'specially formulated' which every bottle of fluid from every manufacturer states.)
    Toyota is not in the fluid's business. They are not creating (nor formulating for that matter) their own trans fluids, coolants, oils etc. They are rebranding it, from another vendor. The trans fluid could easily be a Valvoline or any other product w/Toyota sticker.
    For all the faithful cries insisting on Toyota fluids, no one has stated why beyond quotes from Toyota or personal beliefs.
    For all the calculations that have been projected between the extra cost of Toyota OEM fluids to the cost of damaged Prius engine equipment, no one has a story of anyone who ruined their vehicle by using a substitute fluid ~ no stories of shortened life span, performance degradation. A few folks have, though, trepidatiously jumped in to state they have been using substitutes for years w/no issue.
    Example: I use a full-synthetic oil and replace it twice a year, for over 8 years now (no issues.) Synthetic oil is synthetic oil, regardless if Toyota pushes for it's own branded oil, which likely also has its share voodoo threats and risk pushing the sale of OEM purchases.
    Status: I did use OEM and found a dealer who's price was quite close to the 3rd party. I am here, all the same, to flush out WHY. Why OEM WS only other than Toyota says so? Toyota says use only Genuine Toyota parts too, however 3rd party parts specific to the Prius work great.
    mjoo likes this.
  6. PixelRogue
    489
    86
    US
    Hmm... so this interesting. Watched a few videos which all used the same method....get the car level, fill until it starts leaking.
    I filled 3 bottles.... then every few pumps w/the 4th bottle I would wait a few seconds/minutes expecting dripping to start. Car was level.
    Eventually, the entire 4th bottle made its way to the trans fluid container...it even seemed as though there was room to spare. I removed the tube, left the plug off while started cleaning up a bit and then, all of a sudden out of no where, the fluid started leaking. Leaking as expected, however minutes after the tube was removed. I let it drip for a while, and while I was expecting the drip to slow down/stop once leveled out, it was is if that wasn't slowing so I eventually plugged it back. I expect about 10% of the bottle dripped out.
    Test drives seem fine... how would I know if it has too much (or too little)?
  7. PixelRogue
    489
    86
    US
    So what happened? Break down? Did the dealer agree to change it out?
    as.rizvi likes this.
  8. as.rizvi
    as.rizvi New Member
    Islamabad pakistan
    Yes he changed it without admitting his fault. Pathetic mechanics in Pakistan
  9. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Your auto parts store might loan you four identical jackstands so you can level the car.
  10. egn83b
    egn83b Junior Member
    59
    Rarford nc
    I changed mine at 100k it was simple used world standard atf. Same procedures as a manual transmission car.
