Transmission fluid
Discussion in 'Gen 5 Prius Technical Discussion' started by Jacklee007, Mar 3, 2024.
  1. Trollbait
    12,825
    Toyota power-split hybrids(only type in the Prius) do not have an automatic, whether step or CVT, transmission. It gets labelled as an eCVT because it behaves like a CVT, but mechanically is more like a manual/standard transmission. Manuals do not need a fluid that also works as a hydraulic fluid; they just need lubrication and perhaps cooling from the fluid.
    I believe Toyota chose ATF WS out of convenience. The available fluids for manuals were too thick, impacting efficiency, and they didn't want to invest in a dedicated fluid for one car model. With all the hybrid models, and BEVs, they finally made that investment.
    Bill Norton and Gorgonzola like this.
  2. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    I was thinking the same thing. Presently I have four quarts of Idemitsu Type H2 queued up for my son's 2016 Accord. We'll see how that goes before making any decisions on the Prius V.
  3. Hammersmith
    Hammersmith Senior Member
    2,484
    2,543
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I wonder if TE would actually work in earlier gen transaxles and give a small mpg boost? But I wouldn't want to be the one to test it. lol
    ngc4565 likes this.
  4. Trollbait
    12,825
    My guess the main difference is in heat tolerance; ATFs aren't. The gen4 got a more substantial fluid cooler. By substantial, it now runs fluid through the car's radiator like all automatic transmissions do. Before that, there was a spot where the fluid could shed some heat to the inverter coolant loop.
    Does the gen5 still have that extra cooling the gen4 got?
  5. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    No, Toyota Genuine ATF WS is for Gen 4 and older Priuses.
  6. Gokhan
    6,714
    2,672
    Paramount CA
    Here is the viscosity and other data for WS, FE, and TE. TE’s viscosity is by far lower than the other two’s.
    ATF WS or CVT fluid | Toyota Nation Forum
    With any lubricant, certifications are critical. Do not use a lubricant that does not have the required certifications, as some specs and performance benchmarks might be off.
    Typically, a higher viscosity results in less wear and a lower viscosity results in higher fuel efficiency. So, do not use a different viscosity than recommended, as it could adversely impact the wear and/or fuel economy.
  7. Trollbait
    12,825
    Don't have a warm viscosity for it though.
  8. Hammersmith
    2,484
    2,543
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Which is what he said. The post he was replying to was asking about what to use in a 2017 Prius v.
  9. Gokhan
    6,714
    2,672
    Paramount CA
    The TE KV100 is a lot lower than that of the WS and FE—no doubt—probably around 4.5 cSt. The pour point is also a lot lower—indicating a thinner and/or higher-quality base oil.
    Infineum Insight | Low-viscosity transmission fluids
  10. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    Yes - my bad for discussing two vehicles with different fluid requirements in the same thread. My thoughts on these vehicles now stand as follows:
    2017 Prius V with 51k miles: It calls for Toyota WS. I am leaning towards the Idemitsu TLS-LV as it is readily available and probably the same as the Toyota branded fluid. I plan to change it at 60k which could be close to two years down the road the way this vehicle is used.
    2023 Prius LE with 49k miles: It calls for Toyota e-Transaxle Fluid TE and will get that next fall when it hits 60k. This fluid is readily available from a nearby Toyota dealer.
    If anyone feels that these are bad choices please feel free to comment.
    douglasjre likes this.
  11. Gokhan
    6,714
    2,672
    Paramount CA
    If you read the Infineum article I linked above, you can realize how-complicated lubricants modern transmission fluids are.
    So, don't mess with it, and buy your transmission fluid from the Toyota dealer.
  12. Hammersmith
    2,484
    2,543
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Meh. It looks like Idemitsu TLS-LV is what's in the Toyota WS bottles. That's one I'd feel safe using. But I can't find it cheaper than I can get WS online at my usual Toyota parts stores. So my preference order would be WS at online Toyota stores, then Idemitsu from online retailers, and then finally WS from local Toyota dealerships.
    Idemitsu is probably making TE for Toyota, but it doesn't look like they're selling it themselves yet.
  13. Gokhan
    6,714
    2,672
    Paramount CA
    Obviously, Toyota themselves do not make any lubricants. For example, TGMO in the US is made by ExxonMobil.
    E-transaxle fluid TE is made by Eneos, not Idemitsu. Yes, it is the same thing, but unless you live in Japan, it will cost you more than the Toyota OEM label.
    Answering @Trollbait's question, KV100 is only 3.3 cSt. It uses a very thin Group III base oil (severely hydroprocessed petroleum base stocks, not the fancy Group IV or Group V laboratory-made base stocks) with new antiwear/extreme-pressure/friction-modifier additives, which I am guessing are partially organic.
    ENEOS EV/hybrid e-axle fluid TE
  14. aVeryCleverName
    aVeryCleverName New Member
    OR
    2023 Prius
    LE AWD-e
    Hey guys, recently got a 23' AWD Prius, and because of the road to our house and my wife's driving habits, I was going to use a "severe" maintenance interval and change the fluid soon at 30k miles. I see that should be Toyota Genuine E-transaxle fluid type TE, and around 3.6qts to fill, but my question is, Where are the drain fill and check bolts? I took it for it's last Toyota Care service today (because it came with it) and the service writer is seemingly trying to scare me off telling me it requires special equipment to hold specific temperatures, and "if I feel equipped to do it". I can imagine there's a temp in the operating range to check the level and possibly to drain it since it'll be thinner warm, But I'm here to be Educated! I haven't crawled under it yet because we've only had it a few weeks. We bought it to use and it's going to be seeing A LOT of miles, and quickly, so I imagine I only have a handful of weeks until we hit the 30,000 miles I want to service at. Can anyone point to a picture or a general procedure for this or let me know if it's anything out of the ordinary from what I already know having done some AT and MT transmission/diff services myself in some Honda Toyota and GM stuff in the past?
    We're really loving the car so far, and I'd like to give it the best chance I can at staying with us for Many years to come!
  15. Gokhan
    6,714
    2,672
    Paramount CA
    Subscribe to TIS for two days, which costs for about $25, and download all the relevant repair-manual pages. Others will appreciate if you then share the knowledge.
  16. Trollbait
    12,825
    Were those past AT services on models with dip sticks? The lack of a dip tube makes filling after the change a little more difficult. Will probably need to lift the car up and keep it level for that.
    Warming up the fluid will help with draining, but it is more for getting level right. Filled with cold fluid will likely be too much. A scangauge or other device could give a transmission temperature reading. The required temp is likely presented in a range. The part that might require specialized equipment will be in ensuring the system runs enough to get the fluid warmed up.
    A poster just posted a copy of the entire service manual, so you can skip the TIS subscription.
    aVeryCleverName likes this.
  17. Gokhan
    6,714
    2,672
    Paramount CA
    Wow, that’s great.
    It would take days to compile the whole thing, as you can only download one subsection at a time. Great effort by the poster!
    #37 Gokhan, Dec 30, 2024
  18. aVeryCleverName
    OR
    2023 Prius
    LE AWD-e
    Mostly with but I think at least a few without, I think I had a few without them when I was still in college and had a job doing tires and lube at a Honda dealer, but its been a few years. I'd pretty much planned on needing a transfer pump or hose of some kind... I'll seek out that service manual sometime real soon, thanks for the tip! And whoever posted that is an actual folk hero as far as I'm concerned! There has to be a special place in heaven for anyone who shares the tech/service manuals!
  19. Mendel Leisk
    42,343
    And a special place somewhere else, for car companies that put even basic biz like fluid changes behind a paywall.
  20. BiomedO1
    BiomedO1 Senior Member
    4,594
    2,410
    Left Coast
    don't need the transfer pump; use a 1 meter hose and fill from the top with a funnel. Let gravity do all the work. Dump in 3L, then go slow with the last one - until it starts flowing out the fill hole.
    Hope this helps...
    xliderider and Mendel Leisk like this.
