Transmission fluid
Discussion in 'Gen 5 Prius Technical Discussion' started by Jacklee007, Mar 3, 2024.
  1. Mendel Leisk
    42,343
    Yeah to read it, it was most expedient to post first.
    for ref, 3rd gen attached:
  2. dagaph
    dagaph Junior Member
    55
    16
    Montreal
    2024 Prius Prime
    XSE
    It is true that procedure is unnecessarily confusing. My understanding is that 2(k) is the second time Toyota wants you to drain, refill , start the engine. And 2(l) is the last time (the third) when Toyota wants you to just drain, refill and tighten the fill and drain plugs without starting the engine. As far as I can see for Gen5 there is only replacement procedure there is no longer adjustment (simple drain/refill) procedure since now it is considered to be a non-maintenance item and therefore unwillingness by the dealer to do simple drain/refill as Hammersmith suggested. So is it general consensus that a single drain/refill is completely adequate if there is nothing wrong with the older fluid and there is no need for a complete purge of the transaxle?
    #62 dagaph, Jun 14, 2025
  3. dagaph
    55
    16
    Montreal
    2024 Prius Prime
    XSE
    By the way, I called Valvoline and Amsoil and they said they do not have a product for Toyota TE e-transaxle fluid yet.
  4. Mendel Leisk
    42,343
    I’d say so, with the caveat to measure volume of drained fluid, compare to spec capacity (amount needed to fill brand-new, dry transaxle). It should be around 90%.
    FWIW, even with their conventional automatics, where drain- and-fill replaced only about 50%, Honda still just called for a single drain/fill.
    regarding unnecessary, awkward complexity, Toyota’s 3rd gen brake fluid replacement instruction is a similar doozie. To explain the order the four brakes should be done, they more-or-less repeat the entire procedure, four times (once per corner), with sole change being the ID of which corner it is. And of course instead of saying right hand (for example) they say RH. A plan view pic of car with the numbers 1 through 4 would save about 500 tedious words.
  5. Mendel Leisk
    42,343
    But Toyota dealerships do have it? I’d be reluctant to use anything else, even if there were options. Does the owner’s manual still warn that alternative fluid may cause damage?
  6. dagaph
    55
    16
    Montreal
    2024 Prius Prime
    XSE
    The warning is still there for Gen5 but I do not believe that TE fluid is anything special. Because if you look at WS fluid - it was used in regular stepped automatic transmissions and magically it was good for hybrid transmissions when they came out. I am pretty confident Gen5 will take WS fluid and will be even better protected since WS is slightly thicker. If WS is good for Rav4 Prime it has to be good for Prius prime as well. All transmission have the same gears, the same friction materials, the same solenoids, same pumps. Even AISIN that makes supposedly "unique" fluids makes universal fluid which can be used in place of fluids which according to AISIN itself are incompatible! If you have not seen it already read the section "What about universal/multi fluids?"
    What ATF/CVTF to use for Toyota?
    I think the problem is licensing. I was taught in the university that the licensing is a form of a barrier manufacturers set up to prevent other companies from entering the market place. It makes it too expensive for many companies to acquire all the licenses.
    #66 dagaph, Jun 14, 2025
  7. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Hardly "magically" - those hybrid transmissions were designed to use it.
    There's no evidence the transmissions calling for TE were ever designed for WS, is there? It's not like they've just changed the manual for a transmission that previously called for WS.
    I mean, it's possible that they were originally designed for WS, and were tested with TE later in development, but I don't think there's anything to suggest that - so it could just as well be the case that they're relying on the lower viscosity and it will perform really badly with WS.
    Based on what logic? The common word "Prime"?
    Well, they all have gears, materials, solenoids, and pumps, sure, but obviously not the same. The moving parts are designed with particular tolerances and gaps.
    With e-Transaxle TE not among their list.
  8. Trollbait
    12,825
    In the Gen4, the transaxle now has an external cooler in the car's radiator. Any particles in the fluid will mostly settle out in the many passages of the heat exchanger before the fluid all drains out. It may not even completely drain of fluid. The multiple drain and fills is likely to flush out the exchanger in the event of contaminants.
    This may still be the case with the gen5, or it is simply a copy and paste from the gen4 manual.
    Earlier hybrids used WS because Toyota was making barrels upon barrels of it for their automatics, and the number of hybrids being didn't warrant making a power-split hybrid specific fluid.
    There is no physical shifting going on in these transaxles; no stepped gears, nor belt and cone, nor a torque converter. So no need for the fluid to also work as a hydraulic fluid, or wear from clutches. Additives needed for that aren't needed for the transaxle. Taking them out means more space for actual lubricant in a given volume of fluid. It also means the fluid can be designed to be more heat tolerant.
  9. Hammersmith
    Hammersmith Senior Member
    2,484
    2,543
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yeah, this is a really bad take.
    TE fluid is speced for the 5th gen transaxles. Those are currently the PA10, PB10(Prius), PB11, & PB12(Prius Prime). The current RAV4 Prime uses the 4th gen P810. We'll see what the 2026 RAV4 uses when it's updated to the 5th gen system later this year, but I bet it's going to be TE like the rest of the family.
  10. Mendel Leisk
    42,343
    I'm just smart enough, to not second guess them on this. From my perspective, there's zero upside and a lot of potential grief, considering how adamant they are about using only the proprietary fluid.
  11. dagaph
    55
    16
    Montreal
    2024 Prius Prime
    XSE
    Clam down, Karen. I used to work in a lab so I wanted to give you several studies and the reasons why I think WS will not only be just fine in Gen5 but probably will be better for longevity of the transmission but I really dislike your patronizing tone and your simplistic approach - Toyota knows best - masquerading as some superior knowledge. So I hope it is ok with you if I go against Toyota and change my transmission fluid although Toyota engineers say it is life time fluid? You are right we have no idea if too clean of a fluid could be detrimental to a transmission. /sarcasm I am sure there is a very good reason why Toyota does not want anybody to change it. /sarcasm
  12. dagaph
    55
    16
    Montreal
    2024 Prius Prime
    XSE
    Toyota as a corporation and you might have different objectives unless our objective is to comply with CAFE and avoid fines.
    But in general i think it is more important to change fluid than what type of fluid it is. So for average person TE fluid might be adequate.
  13. dagaph
    55
    16
    Montreal
    2024 Prius Prime
    XSE
    I bet it will be backward compatible with all the previous Toyota hybrids. In their press release Toyota basically said that TE was designed for fuel economy. WS fluid will be probably phased out.
  14. dagaph
    55
    16
    Montreal
    2024 Prius Prime
    XSE
    it is done. I have changed the TE transaxle fluid at 20000km. The unit is PB10 so it is supposed to have 3.7L total fill, but only 3100mL came out. In total I put 3350mL of the new liquid and the liquid was still not coming out from the fill hole. According to the Toyota manual for PB10 unit it is between 10mm and 0mm(0mm is when liquid coming out from the fill hole). Old liquid was very dark (the new one is sunflower oil color) but the old dark liquid was still transparent (you could see though it)! Not cloudy at all only dark. So no wear metals at all. I am used to differential fluid coming out not only dark but very cloudy (unable to see through it). I read somewhere that Toyota used high pressure additive which prevents metal to metal contact even if fluid film strength is not sufficient. So whether it is special fluid properties or special surface treatment of this e-CVT it seems the goal is to prevent electric coils being bathed in metal shaving. Whatever it is, it is working.
    The fill plug is 24mm socket (it is to the rear of the right half axel on the picture), the drain plug is 10mm hexagonal (I point at it). I measured the fluid by weight. And the conversion factor is 500mL of this fluid is 420g.
    #74 dagaph, Oct 25, 2025
    Gokhan likes this.
  15. BiomedO1
    BiomedO1 Senior Member
    4,594
    2,410
    Left Coast
    That look like the similar result I had replacing mine at 20K miles. Any ferrous material would likely stick to the two electric motors permanent magnets.
  16. dagaph
    55
    16
    Montreal
    2024 Prius Prime
    XSE
    Oh, that is interesting. So you think that most of the shavings keep on attaching to something magnetic inside this transmission.
    I have not thought of this.
  17. BiomedO1
    4,594
    2,410
    Left Coast
    Yep; Having a magnet on the end of your drain plug will capture some of it, but if the ferrous material floats by another magnetic field; It's just like gravity. IMHO - The cleaner you keep it, the less problems you'll run into.
    FWIW; later ATF changes will yield cleaner ATF; from my experience the first change is the dirtiest....
    #77 BiomedO1, Oct 27, 2025
