transmission input damper
Discussion in 'Gen 3 Prius Technical Discussion' started by Raphael Muscarelle, Oct 10, 2019.
  1. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Anyone know if this has to be aligned like regular clutch? If so what tool is needed to do it?
  2. ChapmanF
    18,567
    I've never seen anybody emphasizing a need to do it. Maybe there isn't a pilot bearing behind it, as a regular clutch would have, as it's never really meant to spin.
  3. Raphael Muscarelle
    661
    222
    No I meant when it is taken off the engine how it it put back on.
    Is it bolted to the flywheel no slack or is there a pressure plate type of system that needs a guide to center it.
    I ask because I'm getting ready to do a engine rebuild and would like to replace rear seal which needs fly wheel taken off.
  4. ChapmanF
    18,567
    That's what I meant also. I have never seen anyone on PriusChat emphasize a need for a pilot tool.
    With a regular clutch, if you reassemble without a pilot tool, the disc might be a little off center, enough to stop you cold from reattaching the transmission, because the input shaft will go through the splines of the clutch disc but then be not exactly centered with the pilot bearing in the center of the flywheel, and won't go in.
    I was thinking maybe the reason nobody ever reports that problem reassembling a Prius tranny into the damper is that maybe the Prius flywheel doesn't have a pilot bearing in the center.
  5. Raphael Muscarelle
    661
    222
    ok then. My bad.
    In the manual doesn't say an alignment tool is needed. Since I haven't had it apart yet I don't know what to expect. I do know its impossible to put an engine together without a clutch in perfect alignment.
  6. Raphael Muscarelle
    661
    222
    Kinda looks like it might be self-centering being recessed into flywheel.
  7. Raphael Muscarelle
    661
    222
    Answer is no aligning tool needed. There is self aligning pins.
    Gen 3 and on is self contained unit that bolts to flywheel and uses guide pins
    Gen 2 is similar to assembling a clutch but it is self all aligning into the flywheel. 1570890563724.jpeg
  8. Lemon Drizzle
    Lemon Drizzle Junior Member
    Hall Green, West Midlands
    Can this be done from underneath the car I.e with car on just jack stands?
  9. Raphael Muscarelle
    661
    222
    Nope it is between transmission and engine so one of them needs to be out to have access to the damper itself. Input shaft to transmission is mostly in the transmission.
  10. Lemon Drizzle
  11. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    409
    2013 Prius Plug-in
    Well say one swapped a jdm engine in and now can't get the engine to go into the transaxle?
    I feel like it might have something to do with the disc not being aligned however I bought a universal alignment tool and everything looked like it's nicely aligned in the center and it will not go in to the transaxle
  12. Brian1954
    Brian1954 Senior Member
    2,414
    969
    South Central PA, USA
    This is a Gen 3 thread. Your engine swap is not a Gen 3, so you are posting in the wrong thread.
    ASRDogman likes this.
  13. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
    Ah yes, touché
