Transmission Lurch.
Discussion in 'Gen 4 Prius Main Forum' started by GTBaker, Jan 4, 2017.
  1. GTBaker
    GTBaker Member
    45
    ----Canada----
    Had something weird happen the other day...well weird to me at least.
    Started the car(engine didn't start)...released the parking brake and placed it in drive. The whole time with brakes applied. Was checking a message which just dinged on my phone when the ICE started and the car lurched ahead even while brakes were applied. It moved only 3-4" but startled me nonetheless.
    Anyone have this happen before?
  2. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    Due to the engine orientation, a strong torque when the ICE starts causing the vehicle to lurch/rock a bit is most common when it happens in park. At speed, you don't notice it because the rest of the dynamics dampen the effect by transferring the torque to the rotating wheels.
    If the main brakes are moderately to firmly applied, you should notice the vibration but not any wheel motion. Perhaps the brakes were only applied lightly, allowing some slippage with the unexpected torque?
  3. GTBaker
    GTBaker Member
    45
    ----Canada----
    No as I said I was in Drive and my foot was planted.
  4. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Yep. I've had that happen several times.
    When I am in a drive-thru lane getting coffee. The ICE will suddenly start up and shake the car and startle me. If I'm not in park, with just my foot on the brake the car seems to lurch forward a few inches.
    Kramah313 likes this.
  5. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    3-4" sounds like a lot but this is "normal". As wrprice said, the torque required to start the ICE causes a counter torque at the wheels. On my car (Gen3), I also notice that when it's in park, the car will apply the brakes just before ICE start, and it still moves a tiny bit. My ScanGauge even shows a counter-torque being applied to MG2 during starup, and then to counteract the torque of MG1 acting as a generator.
    I suspect two things happened to you to cause an exaggerated movement on ICE start. First, you were in D with the brake applied, so the car probably didn't apply the brakes harder. Second, the car is likely guesstimating at the counter-torque required for starting a cold engine (inertia effects will vary based on how fast the engine spins up) and probably got it wrong. Also, unexpected movement probably seems much greater than expected movement.
    Kramah313, RCO and Coast Cruiser like this.
  6. GTBaker
    GTBaker Member
    45
    ----Canada----
    Thanks guys. Good to know.
  7. Tideland Prius
    16,680
    3-4" seems a bit far but I've had it lurch if my foot wasn't placed firmly enough on the brakes at a traffic light and the engine kicks in. A good reminder to myself to ensure my brake pedal is firmly depressed :)
    RCO likes this.
  8. bisco
    52,849
    the body, chassis and you move 3-4", but the wheels stay put.:p
    kithmo, Tideland Prius and RCO like this.
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Wherever the tyre touches the road it's always, always stationary. Only the parts not in contact with the road are moving! Think about it.
    kithmo, tpenny67 and Tideland Prius like this.
  10. bisco
    52,849
    my head hurts.
    kithmo and RCO like this.
  11. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    It's a Prius anomaly. It rocks the car, but I don't think it moved very far.
  12. tpenny67
    464
    403
    Massachusetts, USA
    Huh, I always thought the car stayed stationary while the wheels rotated the planet underneath me :)
    William Redoubt and RCO like this.
  13. Prodigyplace
    12,712
    11,848
    Central Virginia
    Apparently there is another reason to plant your foot too. If the foot is not firmly planted, the battery is still sending power to MG2 Yo can see it on the gauge too.
    See ScanGauge II – Prius Gen 4 XGauges – Observations on Hybrid Battery Current | PriusChat
  14. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I know. It's so revolutionary!
  15. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Probably more give in this new rear suspension. I've only noticed a slight lurch after I release the footbrake when I forgot I've got the foot operated parking brake on and put the car in drive, this reminds me I'm trying to drive off with the parking brake on :oops: Doh!
    bisco and RCO like this.
  16. Tideland Prius
    16,680
  17. Coast Cruiser
    2,267
    2,571
    The very first time my car lurched, it almost hit the car in front of me! (I was in the drive-thru lane getting food.) I think my Prius jumped a foot. And yes, I was too close to the vehicle in front of me, and yes my foot was barely resting on the brake. Not a good combination! :eek: :LOL:
    I went there, I conquered, I learned. :D Just another Prius oddity...
    Now I just use the (P) button when I'm stuck in those lines.
    RCO likes this.
  18. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Veni, vici, didici.
    Latin! ;)
    Coast Cruiser likes this.
  19. Prodigyplace
    12,712
    11,848
    Central Virginia
    Perhaps it was saying "Enough weight already!"
    Finally got our first snow here. 7.5 inches measured. We expect another 1.5. How is your weather, CC? Still raining?
    Keep safe, everybody.
    I will wait for the neighbors to plow the road & driveway before trying a drive. The 2 neighbors have a competition plowing with their tractor blades.
  20. Coast Cruiser
    2,267
    2,571
    My back hurts!
    Try squeezing a football player size man into a small Prius! What was I thinking when I bought that little Disneyland car!? :confused:
