Transmission Oil Change?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GeorgeMW, Sep 28, 2017.
  1. GeorgeMW
    GeorgeMW Junior Member
    57
    Georgia
    for how many miles can the transmission oil last?
    is 20k or 50k or 60k or something?
  2. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    Toyota says it's lifetime. ;)
  3. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    I did mine a 200,000 shifted better less drag but have to use there transmission fluid $$$ but easy to do
  4. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    I recomend changing at 30,000 miles, then 90,000 then every 90,000.
    For a 2007 I suspect that means every 90,000 miles, as you are past the first two.
    DIY should be under $50, my dealer charges $110.
    4 quarts of ATF WS (you use 3.5) and 2 crush washers at the parts counter.
  5. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
