Transmission oil change?
Discussion in 'Gen 3 Prius Main Forum' started by PriusKyle, Aug 3, 2025.
  1. PriusKyle
    PriusKyle Junior Member
    82
    16
    Virginia
    Hey all,
    Have a 2011 Prius model 3 at 155,000.
    Never had my transmission oil changed as I don’t recall the manual ever having a maintenance schedule for it.
    Not experiencing any issues right now but is this something I need changed?
    Like to hear recommendations and experiences from people who has had it changed man’s those that haven’t.
    Also, I’ve heard that servicing transmission oils can be risky as well as putting in new oil can cause leaks and issues due to having removed broken down matters that “plugged in” areas where necessary; also I heard it might apply up out transmission as it’s CVT?
    Thanks!
  2. JC91006
    16,936
    8,647
    There is no harm in changing it at 155k miles. 4 quarts of Toyota WS fluid.
    Also these transmissions are plentiful due to their low failure rates, changing the fluid or not is up to you. But I personally don't believe in "lifetime" fluids
    Brian1954 and BiomedO1 like this.
  3. Mendel Leisk
    42,355
    I’d do it. If you’re planning to DIY, it takes about an hour, and the Toyota ATF WS plus two washers should be around $40 USD, through dealership. More info in one of my signature links. (On a phone turn it landscape to see signatures)
  4. PriusKyle
    82
    16
    Virginia
    Thanks for your response.
  5. MattFL
    MattFL Member
    195
    58
    Get yourself a big fluid syringe thing, it makes life really easy. I changed mine at 98k using an electric pump which worked, but was a bit clunky. Then I had to top it off after changing an axle and used one of these syringe things, and really this was so much simpler I think this might be my new favorite instead of the electric pump:
    Link to syringe on Amazon
  6. Mendel Leisk
    42,355
    Funnel, 3' hose extension and gravity worked for me. Keep the hose OD to 5/8" or less.
    Danno5060 and MattFL like this.
  7. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    Remove the fill plug before removing the drain plug...just in case!
  8. PriusII&C
    PriusII&C Active Member
    432
    147
    San Jose, California
  9. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    The transmission is cvt and not like the torque converter transmissions so it will be fine if it’s the first change.
  10. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    We've been using malife Low Viscosity mercon 6, 1 gal jugs from Walmart (red bottle)for years and reusing the crush washers for a decade without incident. Service more than a hundred so far without problem
  11. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    "Lifetime" for car manufacturers mean until the emissions warranty expires.
    There is no sense in using anything other than the proper transmission fluid from Toyota.
    The cost of aftermarket fluid is only a few dollars, and it may or may not be compatible.
    You also risk mixing fluids with adverse results because the oils may not be compatible.
    WHY risk it just to spend $5 less????
    Mendel Leisk and Danno5060 like this.
  12. ColoradoBoo
    ColoradoBoo Senior Member
    1,354
    982
    Monument, Colorado USA
    Yep go ahead and drain and fill. Buy a couple of crush washers for the drain/fill bolts.
    Like Mendel, I also refilled ours via a funnel with about a 3-foot hose on the bottom....just place in the rear of the engine bay, near the brake fluid canister, and snake down the hose.
    I had my wife act as my spotter as I refilled...told me when it was overflowing. (Our 2017 Prius took 3.75 quarts of Toyota WS fluid.)
    Oh, if this is the first time it's been done, expect those bolts to be TIGHT! I'd tap them a few times with a hammer before attempting to break them free and make sure you have a long handle on the wrench.
    Mendel Leisk and BiomedO1 like this.
  13. BiomedO1
    BiomedO1 Senior Member
    4,630
    2,427
    Left Coast
    Use a 1/2 inch breaker bar with a 10mm hex socket. MAKE sure the socket is 'seated' properly - you don't want to round-off that hex bolt. Always break lose the fill port FIRST! If you can't get that one loose, no point in draining the transmission, if you can't refill it.
    re: pouring. a one man job is fine. Put in 3 quarts then go slow on the last half to three-quarters quart. You should hear it dripping into a clean drain pan.
    Good Luck.
    ColoradoBoo likes this.
