Transmission oil (to change or not)
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Adeel96, Feb 4, 2018.
  1. Adeel96
    Adeel96 New Member
    Karachi, Pakistan
    2014 Aqua
    Hello everyone i am new here, just joined the forum. I want to ask about the transmission fluid of Aqua/ Prius C. I just bought Aqua S package. It is an imported car from Japan. It has done 110,140 kms. I am not sure whether to change its transmission fluid or not. Here in Pakistan most Oil changers don't know the correct procedure for changing the transmission oil especially of the Japanese imported cars which have sealed transmission, so i am reluctant to change it. Also i don't know when the last transmission fluid change took place. I haven't felt any slipping of transmission or such. But now i am in a bit of a dilemma here do i need to change or not. Advise needed from fellow owners.
  2. Adeel96
    Adeel96 New Member
    Karachi, Pakistan
    2014 Aqua
    Anyone? Need advise from fellow owners
  3. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Since you aren't sure of the last fluid change, would advice you have it replaced.
    Transmission fluids, or anyotger fluids, degrades with time and usage. Yo be on a safer side, change it.
    Ensure you use the right transmission fluid(WS Toyota brand).
    as.rizvi and Adeel96 like this.
    51,950
    how many km's do you hope to keep it for? it is a simple procedure, if you can find a mechanic who will follow instructions.
    if your 'oil changers' are anything like ours, i would not let them touch it.
    Adeel96 and m.wynn like this.
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    ztanos and Adeel96 like this.
  6. Adeel96
    Adeel96 New Member
    Karachi, Pakistan
    2014 Aqua
    Thanks for the advice all. Yes will pour ATF WS. Will change it soon after finding the right mechanic !! Will follow the above mentioned intervals.
  7. Mendel Leisk
    41,464
    Sorry I don't have Aqua (aka Prius c in the North America?) transaxle fluid change instruction, but you can be fairly certain it is:
    1. Raise and level the car
    2. Remove transaxle fill, then drain bolts (just for insurance remove fill bolt first, in case you encounter difficulty)
    3. Reinstall drain bolt, preferably with new, proscribed washer (Torque value for both is 29 ft/lb, so perhaps the same)
    4. Run a hose and funnel down to fill hole from above, pour Toyota ATF WS fluid, till it overflows
    5.. Wait for overflow to subside, install fill bolt, again preferably with new washer.
    According to Prius c Owner's Manual, proscribed fluid spec and quantity:
  8. Mendel Leisk
    41,464
    Addendum to above (edit is locked out):
    29 ft/lb torque is regular 3rd gen Prius, possibly the same.
    Raytheeagle likes this.
  9. daiske99
    daiske99 Member
    70
    36
    GA, USA
    Is the washer for the transmission drain bolt the same as the engine oil drain bolt's?
  10. Mendel Leisk
    41,464
    No. Again, this is 3rd gen, not sure how much it applies to Prius c (it might well be identical), but anyway: the tranxaxle drain/fill bolt (identical) washers are bigger, p/n 90430-18008.
    And the bolt is cap screw (round headed bolt), with a 10 mm hex recess. You can get socket wrench drivers, Stanley for one.
    Honda by comparison, is also cap screw, with 3/8" square recess, so any 3/8" socket wrench extension works fine.
    bigrin, Raytheeagle and SFO like this.
  11. daiske99
    daiske99 Member
    70
    36
    GA, USA
    I'm just impressed by how kind of you... Thank you so much for the explanation.
    Raytheeagle and Mendel Leisk like this.
